The following demonstrates the `region+rack` mode, a popular initialisation choice for MAAS:
sudo maas init region+rack
`maas` will ask for the MAAS URL:
sudo maas createadmin
Create first admin account:
Username: admin
Password: ******
Again: ******
Email: admin@example.com
[note]
You will use the username and password created above to access the web UI. If you enter a [Launchpad](https://launchpad.net/) or [GitHub](https://github.com) account name with associated SSH key, MAAS will import them automatically.
[/note]
