MAAS installation tutorial (snap/2.7/CLI)
2.7 2.8 2.9 3.0
This is the placeholder for the MAAS installation tutorial.
<!-- snap-3-0-cli snap-3-0-ui
The following demonstrates the `region+rack` mode, a popular initialisation choice for MAAS: sudo maas init region+rack `maas` will ask for the MAAS URL: MAAS URL [default=http://10.55.60.1:5240/MAAS]: http://192.168.122.1:5240/MAAS If you also need to create an admin user, you can use: sudo maas createadmin which takes you through the following exchange: Create first admin account: Username: admin Password: ****** Again: ****** Email: admin@example.com Import SSH keys [] (lp:user-id or gh:user-id): lp:petermatulis [note] You will use the username and password created above to access the web UI. If you enter a [Launchpad](https://launchpad.net/) or [GitHub](https://github.com) account name with associated SSH key, MAAS will import them automatically. [/note]
