Hello everyone! I have booted 9 nodes successfully, however the last one wont succeed. When deploying, it fails after reboot due to MaaS not being able to connect to node (node does not respond to ping either). I saw during boot that instead of using default gateway I have setup in MaaS UI, it has set 0.0.0.0 as gateway… Anyone experienced something similar before?
Using a bonded interface (2 NICs) untagged for PXE boot, and then 3 vlans tagged on the bond in addition
