here is exact error messags in /var/snap/maas/common/log/regiond.log.
2021-12-23 03:43:14 maasserver.websockets.protocol: [critical] Error on request (36) pod.create: invalid input syntax for type macaddr: “00:00:11:0f:fe:80:00:00:00:00:00:00:7c:fe:90:03:00:5d:7c:06”
LINE 1: …38:67’, ‘52:54:00:e5:36:44’, ‘fe:54:00:34:15:b9’, ‘00:00:11:…
File “/snap/maas/17913/usr/lib/python3/dist-packages/twisted/internet/defer.py”, line 501, in errback
self._startRunCallbacks(fail)
File “/snap/maas/17913/usr/lib/python3/dist-packages/twisted/internet/defer.py”, line 568, in _startRunCallbacks
self._runCallbacks()
File “/snap/maas/17913/usr/lib/python3/dist-packages/twisted/internet/defer.py”, line 654, in _runCallbacks
File “/snap/maas/17913/usr/lib/python3/dist-packages/twisted/internet/defer.py”, line 1475, in gotResult
_inlineCallbacks(r, g, status)
File “/snap/maas/17913/usr/lib/python3/dist-packages/twisted/internet/defer.py”, line 1416, in _inlineCallbacks
result = result.throwExceptionIntoGenerator(g)
File “/snap/maas/17913/usr/lib/python3/dist-packages/twisted/python/failure.py”, line 491, in throwExceptionIntoGenerator
File “/snap/maas/17913/lib/python3.8/site-packages/maasserver/websockets/handlers/pod.py”, line 209, in create
pod = await deferToDatabase(self._try_sync_and_save, pod)
File “/snap/maas/17913/usr/lib/python3/dist-packages/twisted/python/threadpool.py”, line 250, in inContext
result = inContext.theWork()
File “/snap/maas/17913/usr/lib/python3/dist-packages/twisted/python/threadpool.py”, line 266, in
File “/snap/maas/17913/usr/lib/python3/dist-packages/twisted/python/context.py”, line 122, in callWithContext
File “/snap/maas/17913/usr/lib/python3/dist-packages/twisted/python/context.py”, line 85, in callWithContext
return func(*args,**kw)
File “/snap/maas/17913/lib/python3.8/site-packages/provisioningserver/utils/twisted.py”, line 870, in callInContext
return func(*args, **kwargs)
File “/snap/maas/17913/lib/python3.8/site-packages/provisioningserver/utils/twisted.py”, line 202, in wrapper
File “/snap/maas/17913/lib/python3.8/site-packages/maasserver/utils/orm.py”, line 756, in call_within_transaction
File “/snap/maas/17913/lib/python3.8/site-packages/maasserver/utils/orm.py”, line 559, in retrier
File “/usr/lib/python3.8/contextlib.py”, line 75, in inner
return func(*args, **kwds)
File “/snap/maas/17913/lib/python3.8/site-packages/maasserver/websockets/handlers/pod.py”, line 330, in _try_sync_and_save
discover_and_sync_vmhost(pod, self.user)
File “/snap/maas/17913/lib/python3.8/site-packages/maasserver/vmhost.py”, line 87, in discover_and_sync_vmhost
vmhost = _update_db(discovered_pod, discovered, vmhost, user)
File “/snap/maas/17913/lib/python3.8/site-packages/maasserver/vmhost.py”, line 296, in _update_db
vmhost.sync(discovered_pod, user, cluster=cluster)
File “/snap/maas/17913/lib/python3.8/site-packages/maasserver/models/bmc.py”, line 1567, in sync
Node.objects.filter(
File “/snap/maas/17913/usr/lib/python3/dist-packages/django/db/models/query.py”, line 653, in first
for obj in (self if self.ordered else self.order_by(‘pk’))[:1]:
File “/snap/maas/17913/usr/lib/python3/dist-packages/django/db/models/query.py”, line 274, in iter
self._fetch_all()
File “/snap/maas/17913/usr/lib/python3/dist-packages/django/db/models/query.py”, line 1242, in _fetch_all
self._result_cache = list(self._iterable_class(self))
File “/snap/maas/17913/usr/lib/python3/dist-packages/django/db/models/query.py”, line 55, in iter
results = compiler.execute_sql(chunked_fetch=self.chunked_fetch, chunk_size=self.chunk_size)
File “/snap/maas/17913/usr/lib/python3/dist-packages/django/db/models/sql/compiler.py”, line 1140, in execute_sql
cursor.execute(sql, params)
File “/snap/maas/17913/usr/lib/python3/dist-packages/django/db/backends/utils.py”, line 67, in execute
return self._execute_with_wrappers(sql, params, many=False, executor=self._execute)
File “/snap/maas/17913/usr/lib/python3/dist-packages/django/db/backends/utils.py”, line 76, in _execute_with_wrappers
return executor(sql, params, many, context)
File “/snap/maas/17913/usr/lib/python3/dist-packages/django/db/backends/utils.py”, line 84, in _execute
return self.cursor.execute(sql, params)
File “/snap/maas/17913/usr/lib/python3/dist-packages/django/db/utils.py”, line 89, in exit
raise dj_exc_value.with_traceback(traceback) from exc_value
django.db.utils.DataError: invalid input syntax for type macaddr: “00:00:11:0f:fe:80:00:00:00:00:00:00:7c:fe:90:03:00:5d:7c:06”
LINE 1: …38:67’, ‘52:54:00:e5:36:44’, ‘fe:54:00:34:15:b9’, '00:00:11:…
