So I am trying to follow some guides from Canonical/Ubuntu about MAAS, Juju, Openstack. One of the examples is https://maas.io/docs/how-to-use-the-maas-cli Here in the instructions it says:
sudo maas apikey --username=admin > api-key-file
maas login admin http://192.168.43.251:5240/MAAS/api/2.0/ < api-key-file
When I try this with 3.2.2 or 3.2.4, it will:
a.) not accept the redirect from the file, but will prompt me with:
provsvc@lab-ubnt-maas-01-a:~$ maas login admin http://10.241.96.21:5240/MAAS/api/2.0/ < api-key-file
API key (leave empty for anonymous access):
b.) When I paste the api key in, I get:
usage: maas [-h] COMMAND ...
optional arguments:
[Errno 104] Connection reset by peer
When I try to run
juju bootstrap --bootstrap-series=focal --constraints tags=juju maas-one maas-controller
I also get
ERROR Forbidden
I am pretty sure the Juju problem is the same problem the above maas login has
How can I further debug this?
