I found a annoying issue with MaaS as a DNS server for the local .maas domain.
I have an example quite easy to reproduce :
- I have 2 machines with 1 interface
- this interface has the default untagged network used for PXE (subnet 10.0.0.0/24)
- this interface also support a vlan network (let’s call it vlan1000, subnet 10.10.10.0/24)
- pxe network is unconfigured after deployment, I don’t want this network to be up and configured once deployed, I only want an IP on the vlan1000 network.
- an IP is set (auto) by MaaS for the vlan1000 network.
I deploy these 2 machines (machine1/machine2) and after a while, they are up and running with Ubuntu Focal 20.04.
I ssh machine1 and I do a “host machine2” and the IP I get is the IP that MaaS gave during PXE boot and not the IP the machine gets once deployed.
This is very annoying because, for example, here is the flow for one machine :
- machine1 starts
- machine1 gets an IP on the PXE network (10.0.0.150)
- machine1 gets registered to MaaS DNS with IP 10.0.0.150
- machine1 is configured with only 1 IP on vlan1000 (10.10.10.10), pxe subnet is unconfigured
- machine1 is still configured with IP 10.0.0.150 in the MaaS DNS
- after a while (maybe 10mn), the DNS cache is refreshed and the machine is registered with the good IP
This is annoying because this machine is not responding with its hostname by that time which can lead to strange behaviors during deployments with things like juju.
Just FYI, I reduced MaaS DNS TTL to the minimum (which is 1) but that doesn’t change anything, I have the impression that this 10mn delay is due to the DNS caching done at the client level by systemd-resolved
