Thanks. I’ll include some info I got from logs. The most common seem to be related to the following:
In regiond.log:
2024-06-26 13:52:11 twisted.scripts: [info] twistd 22.1.0 (/snap/maas/34087/bin/python3 3.10.12) starting up.
2024-06-26 13:52:11 twisted.scripts: [info] reactor class: twisted.internet.asyncioreactor.AsyncioSelectorReactor.
2024-06-26 13:52:11 maasserver.eventloop_1308.master: [info] Calling start_up to start region process
2024-06-26 13:52:18 maasserver.regiondservices.active_discovery: [info] Active network discovery: Discovery interval set to 3600 seconds.
2024-06-26 13:52:18 maasserver: [error] Error while calling ScanNetworks: Unable to get RPC connection for rack controller '<maas_hostname>' (mhq6xb).
2024-06-26 13:52:18 maasserver.regiondservices.active_discovery: [info] Active network discovery: Unable to initiate network scanning on any rack controller. Verify that the rack controllers are started and have connected to the region.
In rackd.log:
2024-06-26 13:52:14 provisioningserver.rpc.clusterservice: [info] Region is not advertising RPC endpoints. (While requesting RPC info at http://<maas_server_ip>:5240/MAAS)
2024-06-26 13:52:15 provisioningserver.rpc.clusterservice: [info] Region is not advertising RPC endpoints. (While requesting RPC info at http://<maas_server_ip>:5240/MAAS)
2024-06-26 13:52:16 provisioningserver.rpc.clusterservice: [info] Region is not advertising RPC endpoints. (While requesting RPC info at http://<maas_server_ip>:5240/MAAS)
2024-06-26 13:52:17 provisioningserver.rpc.clusterservice: [info] Region is not advertising RPC endpoints. (While requesting RPC info at http://<maas_server_ip>:5240/MAAS)
2024-06-26 13:52:18 provisioningserver.rpc.clusterservice: [info] Region is not advertising RPC endpoints. (While requesting RPC info at http://<maas_server_ip>:5240/MAAS)
2024-06-26 13:52:18 provisioningserver.rpc.clusterservice: [info] Region not available: Connection was refused by other side: 111: Connection refused. (While requesting RPC info at http://<maas_server_ip>:5240/MAAS).
2024-06-26 13:52:29 provisioningserver.rpc.clusterservice: [info] Making connections to event-loops: <maas_hostname>:pid=1554, <maas_hostname>:pid=1555, <maas_hostname>:pid=1556, <maas_hostname>:pid=1557
2024-06-26 13:52:29 Uninitialized: [info] ClusterClient connection established (HOST:IPv6Address(type='TCP', host='::ffff:<maas_server_ip>', port=44422, flowInfo=0, scopeID=0) PEER:IPv6Address(type='TCP', host='::ffff:<maas_server_ip>', port=5251, flowInfo=0, scopeID=0))
2024-06-26 13:52:29 Uninitialized: [info] ClusterClient connection established (HOST:IPv6Address(type='TCP', host='::ffff:<maas_dhcp_interface_ip>', port=46712, flowInfo=0, scopeID=0) PEER:IPv6Address(type='TCP', host='::ffff:<maas_dhcp_interface_ip>', port=5250, flowInfo=0, scopeID=0))
2024-06-26 13:52:29 Uninitialized: [info] ClusterClient connection established (HOST:IPv6Address(type='TCP', host='::ffff:<maas_server_ip>', port=45196, flowInfo=0, scopeID=0) PEER:IPv6Address(type='TCP', host='::ffff:<maas_server_ip>', port=5253, flowInfo=0, scopeID=0))
2024-06-26 13:52:29 Uninitialized: [info] ClusterClient connection established (HOST:IPv6Address(type='TCP', host='::ffff:<maas_server_ip>', port=33558, flowInfo=0, scopeID=0) PEER:IPv6Address(type='TCP', host='::ffff:<maas_server_ip>', port=5252, flowInfo=0, scopeID=0))
2024-06-26 13:52:29 provisioningserver.rpc.clusterservice: [info] Event-loop '<maas_hostname>:pid=1555' authenticated.
2024-06-26 13:52:29 provisioningserver.rpc.clusterservice: [info] Event-loop '<maas_hostname>:pid=1554' authenticated.
2024-06-26 13:52:29 provisioningserver.rpc.clusterservice: [info] Event-loop '<maas_hostname>:pid=1557' authenticated.
2024-06-26 13:52:30 provisioningserver.rpc.clusterservice: [info] Event-loop '<maas_hostname>:pid=1556' authenticated.
2024-06-26 13:52:30 provisioningserver.rpc.clusterservice: [info] Rack controller 'mhq6xb' registered (via <maas_hostname>:pid=1555) with MAAS version 3.4.1-14343-g.a552d2522.
2024-06-26 13:52:30 provisioningserver.rpc.clusterservice: [info] Fully connected to all 4 event-loops on all 1 region controllers (<maas_hostname>).
2024-06-26 13:52:30 HTTP11ClientProtocol,client: [critical] Unhandled Error
In maas.log:
2024-06-26T13:52:23.708334+00:00 <maas_hostname> maas.bootsources: [info] Updated boot sources cache.
2024-06-26T13:52:26.487103+00:00 <maas_hostname> maas.networks.monitor: [info] networks-monitoring: Process ID 1307 assumed responsibility.
2024-06-26T13:52:26.487110+00:00 <maas_hostname> maas.networks.monitor: [info] version-update-check: Process ID 1307 assumed responsibility.
2024-06-26T13:52:26.487124+00:00 <maas_hostname> maas.dhcp.probe: [error] Can't initiate DHCP probe; no RPC connection to region.
2024-06-26T13:52:28.728396+00:00 <maas_hostname> maas.service_monitor: [info] Service 'maas-http' has been restarted. Its current state is 'on' and 'running'.
2024-06-26T13:52:28.739469+00:00 <maas_hostname> maas.networks.monitor: [info] certificate-expiration-check: Process ID 1308 assumed responsibility.
2024-06-26T13:52:28.739474+00:00 <maas_hostname> maas.networks.monitor: [info] vault-secrets-cleanup: Process ID 1308 assumed responsibility.
2024-06-26T13:52:28.739478+00:00 <maas_hostname> maas.service_monitor: [info] Service 'maas-syslog' is not on, it will be started.
2024-06-26T13:52:28.739482+00:00 <maas_hostname> maas.service_monitor: [error] Service 'maas-syslog' failed to start. Its current state is 'off' and 'dead'.
2024-06-26T13:52:28.739485+00:00 <maas_hostname> maas.service_monitor: [info] Service 'maas-http' has been restarted. Its current state is 'on' and 'running'.
2024-06-26T13:52:29.523940+00:00 <maas_hostname> maas.rpc.rackcontrollers: [info] Existing rack controller '<maas_hostname>' running version 3.4.1-14343-g.a552d2522 has connected to region '<maas_hostname>'.
2024-06-26T13:52:29.639829+00:00 <maas_hostname> maas.service_monitor: [info] Service 'chrony' has been restarted. Its current state is 'on' and 'running'.
2024-06-26T13:52:30.563655+00:00 <maas_hostname> maas.rpc.rackcontrollers: [info] Existing rack controller '<maas_hostname>' running version 3.4.1-14343-g.a552d2522 has connected to region '<maas_hostname>'.
2024-06-26T13:52:30.739649+00:00 <maas_hostname> maas.rpc.rackcontrollers: message repeated 2 times: [ [info] Existing rack controller '<maas_hostname>' running version 3.4.1-14343-g.a552d2522 has connected to region '<maas_hostname>'.]
2024-06-26T13:52:30.748235+00:00 <maas_hostname> maas.refresh: [info] Refreshing rack controller hardware information.
2024-06-26T13:52:39.537586+00:00 <maas_hostname> maas.service_monitor: [info] Service 'maas-syslog' has been restarted. Its current state is 'on' and 'running'.
2024-06-26T13:52:42.787912+00:00 <maas_hostname> maas.service_monitor: [info] Service 'maas-http' has been restarted. Its current state is 'on' and 'running'.
Several errors in http/error.log like this:
2024/06/26 13:52:12 [error] 1323#1323: *1 connect() to unix:/var/snap/maas/34087/maas-regiond-webapp.sock.0 failed (111: Unknown error) while connecting to upstream, client: <maas_ip>, server: , request: "GET /MAAS/rpc/ HTTP/1.1", upstream: "http://unix:/var/snap/maas/34087/maas-regiond-webapp.sock.0:/MAAS/rpc/", host: "<maas_ip>"
2024/06/26 13:52:12 [error] 1323#1323: *1 connect() to unix:/var/snap/maas/34087/maas-regiond-webapp.sock.1 failed (111: Unknown error) while connecting to upstream, client: <maas_ip>, server: , request: "GET /MAAS/rpc/ HTTP/1.1", upstream: "http://unix:/var/snap/maas/34087/maas-regiond-webapp.sock.1:/MAAS/rpc/", host: "<maas_ip>"
2024/06/26 13:52:12 [error] 1323#1323: *1 connect() to unix:/var/snap/maas/34087/maas-regiond-webapp.sock.2 failed (111: Unknown error) while connecting to upstream, client: <maas_ip>, server: , request: "GET /MAAS/rpc/ HTTP/1.1", upstream: "http://unix:/var/snap/maas/34087/maas-regiond-webapp.sock.2:/MAAS/rpc/", host: "<maas_ip>"
2024/06/26 13:52:12 [error] 1323#1323: *1 connect() to unix:/var/snap/maas/34087/maas-regiond-webapp.sock.3 failed (111: Unknown error) while connecting to upstream, client: <maas_ip>, server: , request: "GET /MAAS/rpc/ HTTP/1.1", upstream: "http://unix:/var/snap/maas/34087/maas-regiond-webapp.sock.3:/MAAS/rpc/", host: "<maas_ip>"
2024/06/26 13:52:12 [error] 1325#1325: *6 connect() to unix:/var/snap/maas/34087/maas-regiond-webapp.sock.0 failed (111: Unknown error) while connecting to upstream, client: <maas_ip>, server: , request: "GET /MAAS/rpc/ HTTP/1.1", upstream: "http://unix:/var/snap/maas/34087/maas-regiond-webapp.sock.0:/MAAS/rpc/", host: "<maas_ip>"
2024/06/26 13:52:12 [error] 1325#1325: *6 connect() to unix:/var/snap/maas/34087/maas-regiond-webapp.sock.1 failed (111: Unknown error) while connecting to upstream, client: <maas_ip>, server: , request: "GET /MAAS/rpc/ HTTP/1.1", upstream: "http://unix:/var/snap/maas/34087/maas-regiond-webapp.sock.1:/MAAS/rpc/", host: "<maas_ip>"
2024/06/26 13:52:12 [error] 1325#1325: *6 connect() to unix:/var/snap/maas/34087/maas-regiond-webapp.sock.2 failed (111: Unknown error) while connecting to upstream, client: <maas_ip>, server: , request: "GET /MAAS/rpc/ HTTP/1.1", upstream: "http://unix:/var/snap/maas/34087/maas-regiond-webapp.sock.2:/MAAS/rpc/", host: "<maas_ip>"
2024/06/26 13:52:12 [error] 1325#1325: *6 connect() to unix:/var/snap/maas/34087/maas-regiond-webapp.sock.3 failed (111: Unknown error) while connecting to upstream, client: <maas_ip>, server: , request: "GET /MAAS/rpc/ HTTP/1.1", upstream: "http://unix:/var/snap/maas/34087/maas-regiond-webapp.sock.3:/MAAS/rpc/", host: "<maas_ip>"
2024/06/26 13:52:12 [error] 1325#1325: *7 no live upstreams while connecting to upstream, client: <maas_dhcp_interface_ip>, server: , request: "GET /MAAS/rpc/ HTTP/1.1", upstream: "http://regiond-webapp/MAAS/rpc/", host: "<maas_dhcp_interface_ip>"
2024/06/26 13:52:13 [error] 1359#1359: *1 connect() to unix:/var/snap/maas/34087/maas-regiond-webapp.sock.0 failed (111: Unknown error) while connecting to upstream, client: <maas_ip>, server: , request: "GET /MAAS/rpc/ HTTP/1.1", upstream: "http://unix:/var/snap/maas/34087/maas-regiond-webapp.sock.0:/MAAS/rpc/", host: "<maas_ip>"
2024/06/26 13:52:13 [error] 1359#1359: *1 connect() to unix:/var/snap/maas/34087/maas-regiond-webapp.sock.1 failed (111: Unknown error) while connecting to upstream, client: <maas_ip>, server: , request: "GET /MAAS/rpc/ HTTP/1.1", upstream: "http://unix:/var/snap/maas/34087/maas-regiond-webapp.sock.1:/MAAS/rpc/", host: "<maas_ip>"
2024/06/26 13:52:13 [error] 1359#1359: *1 connect() to unix:/var/snap/maas/34087/maas-regiond-webapp.sock.2 failed (111: Unknown error) while connecting to upstream, client: <maas_ip>, server: , request: "GET /MAAS/rpc/ HTTP/1.1", upstream: "http://unix:/var/snap/maas/34087/maas-regiond-webapp.sock.2:/MAAS/rpc/", host: "<maas_ip>"
2024/06/26 13:52:13 [error] 1359#1359: *1 connect() to unix:/var/snap/maas/34087/maas-regiond-webapp.sock.3 failed (111: Unknown error) while connecting to upstream, client: <maas_ip>, server: , request: "GET /MAAS/rpc/ HTTP/1.1", upstream: "http://unix:/var/snap/maas/34087/maas-regiond-webapp.sock.3:/MAAS/rpc/", host: "<maas_ip>"
I’m not sure if I can upload the full logs or not, but let me know if that would help.
