Hi @arnsong
Can you send us some information?
Identify your version and build
We need to know the version and build (and packaging format) that you’re running. You mentioned 3.1, but we need a little more information.
If you’re using a snap
If you’re using a snap, execute snap list maas at the command line, which will return some lines like this:
$ snap list maas
maas 3.0.0~beta2-9796-g.2182ab55f 13292 latest/edge canonical✓ -
Please add the output of that command to a comment on this post.
If you’re using a Debian package
If you’re using a deb, execute apt list maas at the command line, and enter whatever it returns into a comment to this post, as in the snap example above.
Using CLI, UI, or API?
Next, you’ll need to specify which interface you’re using, and generally what command(s) you were attempting.
Explain what happens
Being as concise and specific as you can, please explain a little more about what seemed to go wrong. You mentioned that commissioned machines don’t show any storage. You also mentioned that you can “unstick” the controllers from waiting for a rack controller sync. Can you show us some screenshots of the machines that commission with no storage, for example?
Explain how to reproduce your issue
In addition to the explanation above, you should create a step-by-step list of what you did to reproduce the problem. Sounds like it’s pretty simple – just try to commission a machine – but we’d like to be sure.
Take relevant screenshots
If you think it will help – especially when using the UI – try and capture screenshots of any unexpected results or ambiguous actions. Your goal isn’t to document your experience in pictures, but to provide a visual reference where verbal descriptions fall short. Name these so you can sync them with your explanation (e.g., “screenshot-1”). You can just upload them into your comment.
Locate and capture logfiles
If at all possible, capture logfiles for the time period surrounding your error situation. On snap, these files are located as follows:
/var/snap/maas/common/log/maas.log
/var/snap/maas/common/log/regiond.log
/var/snap/maas/common/log/rackd.log
/var/snap/maas/common/log/rsyslog/$MACHINE_NAME/$RELEVANT_DATE/messages
If you’re using packages, you’ll find the files in these locations:
/var/log/maas/maas.log
/var/log/maas/regiond.log
/var/log/maas/rackd.log
/var/log/maas/rsyslog/$MACHINE_NAME/$RELEVANT_DATE/messages
Ideally, you’d want to put these in a pastebin and link its location in your comment.
Thanks for this. We’ll need this additional information in order to try and figure out what’s going on.
