MAAS commissioning script '50-maas-01-commissioning' failed during post-processing in 3.2.6
Hi Team,
We are using MAAS 3.2.6 and tried to commission a node(physical machine) and it always fails on 50-maas-01-commissioning
Please find the exception below in the regiond logs.
2023-02-04 06:19:45 metadataserver.api: [critical] enough-bull.drut(yrcey3): commissioning script ‘50-maas-01-commissioning’ failed during post-processing.
File “/snap/maas/x1/lib/python3.8/site-packages/metadataserver/api.py”, line 866, in signal
target_status = process(node, request, status)
File “/snap/maas/x1/lib/python3.8/site-packages/metadataserver/api.py”, line 690, in _process_commissioning
self._store_results(
File “/snap/maas/x1/lib/python3.8/site-packages/metadataserver/api.py”, line 575, in _store_results
script_result.store_result(
File “/snap/maas/x1/lib/python3.8/site-packages/metadataserver/models/scriptresult.py”, line 372, in store_result
signal_status = try_or_log_event(
File “/snap/maas/x1/lib/python3.8/site-packages/metadataserver/api.py”, line 493, in try_or_log_event
func(*args, **kwargs)
File “/snap/maas/x1/lib/python3.8/site-packages/metadataserver/builtin_scripts/hooks.py”, line 1092, in process_lxd_results
_process_lxd_resources(node, data)
File “/snap/maas/x1/lib/python3.8/site-packages/metadataserver/builtin_scripts/hooks.py”, line 611, in _process_lxd_resources
network_devices = update_node_network_information(node, data, numa_nodes)
File “/snap/maas/x1/lib/python3.8/site-packages/metadataserver/builtin_scripts/hooks.py”, line 227, in update_node_network_information
update_node_interfaces(node, data)
File “/snap/maas/x1/lib/python3.8/site-packages/provisioningserver/utils/twisted.py”, line 202, in wrapper
File “/snap/maas/x1/lib/python3.8/site-packages/maasserver/utils/orm.py”, line 740, in call_within_transaction
return func_within_txn(*args, **kwargs)
File “/usr/lib/python3.8/contextlib.py”, line 75, in inner
return func(*args, **kwds)
File “/snap/maas/x1/lib/python3.8/site-packages/metadataserver/builtin_scripts/network.py”, line 116, in update_node_interfaces
interface = update_interface(
File “/snap/maas/x1/lib/python3.8/site-packages/metadataserver/builtin_scripts/network.py”, line 195, in update_interface
return update_physical_interface(
File “/snap/maas/x1/lib/python3.8/site-packages/metadataserver/builtin_scripts/network.py”, line 236, in update_physical_interface
interface, created = PhysicalInterface.objects.get_or_create(
File “/snap/maas/x1/lib/python3.8/site-packages/maasserver/models/interface.py”, line 436, in get_or_create
interface, created = super().get_or_create(*args, **kwargs)
File “/snap/maas/x1/usr/lib/python3/dist-packages/django/db/models/manager.py”, line 82, in manager_method
return getattr(self.get_queryset(), name)(*args, **kwargs)
File “/snap/maas/x1/usr/lib/python3/dist-packages/django/db/models/query.py”, line 538, in get_or_create
return self.get(**kwargs), False
File “/snap/maas/x1/usr/lib/python3/dist-packages/django/db/models/query.py”, line 410, in get
raise self.model.MultipleObjectsReturned(
maasserver.models.interface.MultipleObjectsReturned: get() returned more than one PhysicalInterface – it returned 2!
From the exception, I understood that two records were found in the maasserver_interface table for the mac_address of the machine.
I checked the maasserver_interface table by filtering with the mac_address of the machine and could see only one entry for the mac_address.
This is the first-time commissioning the machine.
Could you please have a look and let us know the reason for the failure and provide a solution or workaround?
Regards,
Rohit
We are receiving a very similar error, seemingly happening after the update to 3.3.3-13184-g.3e9972c19
Failed processing commissioning data: get() returned more than one PhysicalInterface -- it returned 2!
This is preventing us from commissioning machines.
Anyone have any hints on how to fix this?
If you have access to the DB, could you run the following query select count(*) from maasserver_interface where mac_address='<the MAC address>';?
Hello! We also get those errors on MAAS 3.3.3 when commissioning a server with multiple network interfaces. I have executed the SQL query, revealing only one record for the MAC address of LAN1, while the MAC address of LAN2 is not present in the database.
As a consequence, we are unable to commission our machine in MAAS. I would be glad to help you troubleshoot this issue if you provide me with instructions to follow.
@tfable: were you able to find a workaround or fix it in any way?
Cheers!
Hello, we have found out what caused this issue. While this is a workaround (MAAS should certainly properly handles it), disabling the Host Interface of the BMC of our Supermicro server solved the failing commissioning.
Hey there.
Sorry for the delay after the long weekend.
I came here to post exactly this! We found the issue to be the BMC host interface throwing off MAAS. Once we disabled the host interface on one of the problematic servers and re-ran commissioning, the issue never re-appeared on any other server even after re-enabling the host interface.
This seems to have been some sort of bug that tripped MAAS on any server that had a host interface enabled and the bug, apparently, was cleared one one of those servers had its host interface turned off and was recommissioned.
Very weird but I’m happy we got through it as this was preventing us from commissioning/deploying ANY server.
Confirmed bug still exists on 3.5.8 version of MAAS. What’s interesting: I went trough same 35 systems, with same BMC, BIOS configs and so far and only 8 of them had this issue. As in comments above the DB query returned only one entry, but logs stated 3 entries exist already. Disabling Host interface resolved this, but is a big inconvenience since have to disable-enable on system just for commission.
