Hi I was trying Install Openstack Charm, duting which i installed MaaS 2.7.
Once, i configured the MaaS it ddint auto idenfiy the nodes but i tried adding manually and triggerd "Commision " . Here everytime commision is failing with 2 failures.
1.00-maas-03-install-lldpd : " E: Unable to locate package lldpd "
2., 99-maas-02-capture-lldp:
Traceback (most recent call last): File “/tmp/user_data.sh.NCcaeA/scripts/commissioning/99-maas-02-capture-lldp”, line 29, in lldpd_capture(*args, **kwargs) File “/tmp/user_data.sh.NCcaeA/scripts/commissioning/99-maas-02-capture-lldp”, line 16, in lldpd_capture time_ref = getmtime(reference_file) File “/usr/lib/python3.6/genericpath.py”, line 55, in getmtime return os.stat(filename).st_mtimeFileNotFoundError: [Errno 2] No such file or directory: ‘/var/run/lldpd.socket’
My setup is behind a proxy and i specified that in the "Settings -> Network Services -> Proxy -> "
@yrishi555: like @billwear said, the issue is with the comissioned machine not being able to access the repos. I had the exact same issue.
Not sure how your network is setup, but if you have the typical separate subnet for MAAS nodes, you need to make sure that the nodes on that subnet can reach the internet. In my case, Maas had the wrong gateway for the subnet and my gateway machine was not forwarding the packets correctly.
Thanks for your response. And sorry for the delay.
I have re-deployed the MaaS Server is different environment which has direct internt conection and also i set the servers to Legacy bios mode. Now, the issue got resolved.
But, currently i am facing one issue, while deploying openstack using “juju deploy …”.
i have 2 servers 1 -controller and 1-compute and have customized my yaml file to find for my env.
When i trigger the juju deploy , it shows some logs and said deployment comeplted. But, no node was auto-triggerd with this command.
When i see the juju status,
root@maas:~# juju show-status
Model Controller Cloud/Region Version SLA Timestamp
openstack maas-controller mymaas/default 2.8.1 unsupported 20:36:38Z
