We have DHCP enabled for a range and also DDNS
A server will get an IP from DHCP and then assign the DDNS value.
However we get 2 reverse DDNS values
eg:
The forward is OK:
host B1-01
B1-01.maas has address 10.0.0.35
The reverse:
host 10.0.0.35
35.0.0.10.in-addr.arpa domain name pointer 10-0-0-35.maas.
35.0.0.10.in-addr.arpa domain name pointer b1-01.maas.
the problem comes that the next DNS query gets the 2 entries the other way around
host 10.0.0.35
The problem comes in that we have Dell OpenManage that imports servers for hardware inventory and firmware and other reporting.
We then see some servers listed with the correct BX-YY and then some with the D-C-B-A.maas IP notation.
Is there a way to tell MAAS to only assign the one address or if not if we can clean up the others manually (via a cron or something)? Or even no reverse would be fine as we are scanning based on BX-YY but I guessing the appliance then does a reverse lookup afterwards.
