I’m having a little trouble getting the op-set_storage_layout call to work.
I’m using Ansibles URI module to make the call.
- name: Change Storage Layout to flat
uri:
url: "{{ maas_url }}/MAAS/api/2.0/machines/{{ system_id }}/op-set_storage_layout"
method: POST
headers:
Content-Type: "application/json"
Authorization: "OAuth oauth_version=1.0, oauth_signature_method=PLAINTEXT, oauth_consumer_key={{ consumer_key }}, oauth_token={{ token }}, oauth_signature={{ signature }}, oauth_nonce={{ lookup('pipe', 'uuidgen') }}, oauth_timestamp={{ lookup('pipe', 'date +%s') }}"
body_format: json
body: |
"storage_layout":"flat"
status_code:
- 200
register: block_devices_result
delegate_to: 192.168.0.100
I’m getting an error 400 which also states in the body: “Failed to configure storage layout ‘f’: Unknown storage layout: f”.
I’m unsure as to why its cutting off the lat…
Hi @ryans17 and welcome to MAAS discourse.
What version of MAAS are you using?
Are you able to reproduce the error using the MAAS API or CLI?
r00ta
3
The content type is not json, it’s multipart/form-data. See https://maas.io/docs/api
Yes my bad! Thank you for the assist.
All of my other calls were like the previous one and I didn’t have an issue.
uri:
method: POST
headers:
Content-Type: "multipart/form-data"
body_format: form-multipart
body:
storage_layout: "flat"
status_code:
- 200
I’m using version 3.3.5
My issue is now resolved. Thank you for taking the time to offer assistance.
system
Closed
6
