I have a bare-metal server that I want to use as a KVM host. I was able to deploy a custom RHEL 9.6 image (based almost exactly off of this - packer-maas/rhel9 at main · canonical/packer-maas · GitHub), and in my cloud-init user-data install the virtualization packages (see below). I then manually added the machine as a virsh KVM host. When I try and compose a VM, I get the following error -
Pod unable to compose machine: Unable to compose machine because: Failed talking to pod: Virsh command [‘define’, ‘/tmp/tmps_frvhfz’] failed: Failed to define domain from /tmp/tmps_frvhfz error: unsupported configuration: spice graphics are not supported with this QEMU. I know that RHEL 9 doesn’t support spice graphics, is this something that MAAS is specifying in the underlying virt-install command it executes and/or does anyone know why I am getting this error?
Thanks!
#cloud-config
package_update: true
packages:
- qemu-kvm
- libvirt
- virt-install
- virt-viewer
runcmd:
- systemctl enable --now libvirtd.socket
- systemctl enable --now virtlockd.socket
- systemctl enable --now virtlogd.socket
- virt-host-validate
