MAAS 3.5 Problems with in-memory booting of Custom OSes
I am attempting to boot a Rocky 8 custom image using the new ‘Deploy in memory’ option of MaaS 3.5 ( installed via snap using ‘3.5/stable’) but it seems the only OSes I can get to work like that are the non-custom Ubuntu ones.
I used the packer-maas project to build the custom image and uploaded it to MaaS via the following command:
maas pnx boot-resources create name="custom/rocky8" \
  title="Rocky 8" architecture='amd64/generic' \
  base_image='rhel/8' filetype='tgz' \
  content@=rocky8.tar.gz
The custom image deploys onto a system in the ‘traditional’ manner without issue.
Encountered errors in the logs are:
Marking node failed - Missing boot image rhel/amd64/generic/8.
The deployed system just drops into what looks like a busybox shell and just sits there till I power off the VM.
Could you please open a bug on launchpad?
I’ll get a new bug report opened up and link it back here.
Searched through the bug reports and spotted one that looks pretty similar to the issue I hit
Before I cut a new one I’m going to double check I’m working on the same release (or greater) that is mentioned in that bug report.
Verified I’m using a newer version than the version reported in the above bug report.
Bug report submitted: Bug #2075555 “Custom OSes fail to deploy 'in memory'” : Bugs : MAAS
Hi @quinn. Thank you for the bug report. I was able to reproduce it on my local environment. Let’s continue the discussion to the bug itself.
