Hi all,
We are trying snap MAAS 3.2-beta3 (beta2 has the same issues) and we encounter two problems.
The first one is related to TLS/Apache proxy.
After the update, If you had configured the TLS using the guide on the docs. When you acces to maas using the port 443 (apache configured) maas will replay with a redirect using the snap port were it’s listening.
curl -i https://maas.mydomain.com/
HTTP/1.1 301 Moved Permanently
Date: Mon, 25 Apr 2022 10:44:48 GMT
Server: nginx/1.18.0 (Ubuntu)
Content-Type: text/html; charset=UTF-8
Content-Length: 178
Strict-Transport-Security: max-age=86400; includeSubdomains
<html>
<head><title>301 Moved Permanently</title></head>
<body>
<center><h1>301 Moved Permanently</h1></center>
<hr><center>nginx/1.18.0 (Ubuntu)</center>
</body>
</html>
There is any way to configure the maas url, so the snap nginx will return right ?
The second one is related with candid.
If you had configured the authentication with candid, when you acces to maas trough the web UI, you can’t open candid to authenticated. The web browser do a POST to /discharge with a corrupted “id”. This doesn’t happend with the API.
It seems to by a wrong encoded/charset.
