I’ve replicated the issue on 3.3.4. Here’s the full solution to disable periodic hardware sync by editing the database entries for the hosts on MaaS. (use at your own risk)
First, ssh to your MaaS controller. Then connect to the maasdb as the postgres user.
sudo su postgres
psql
postgres=# \c maasdb;
Then select the hosts by id and enable_hw_sync from the maasserver_node table to see what the current status is.
maasdb=# select id,enable_hw_sync from maasserver_node;
 id | enable_hw_sync
  1 | f
  2 | f
  7 | f
  5 | t
  6 | t
  8 | t
(6 rows)
In my case, I want to disable hardware sync (set enable_hw_sync to false) for all of my hosts, so I used an UPDATE statement for all records in maasserver_node.
UPDATE maasserver_node SET enable_hw_sync = false;
There is also a system timer named maas_hardware_sync on each host to clean up. (I found that out by watching the fabrics get added in real-time after I thought I had cleaned them up.)
$ sudo systemctl list-units --type=timer maas_hardware_sync.timer
  UNIT                     LOAD   ACTIVE SUB     DESCRIPTION
  maas_hardware_sync.timer loaded active waiting Timer for periodically running MAAS hardware sync
On each host, disable and remove the timer.
sudo systemctl disable maas_hardware_sync.timer
sudo systemctl stop maas_hardware_sync.timer
sudo rm /lib/systemd/system/maas_hardware_sync.timer
In my case, they were non-production hosts used for testing the infrastructure deployment; I chose to redeploy the nodes. Same affect.
Then, clean up the fabrics and VLANs. Using these SQL commands, two DELETE statements intended to remove records from the maasserver_vlan and maasserver_fabric tables.
maasdb=# DELETE FROM maasserver_vlan
	WHERE maasserver_vlan.id NOT IN (
	    SELECT maasserver_vlan.id
	    LEFT JOIN maasserver_interface ON maasserver_vlan.id = maasserver_interface.vlan_id
	    WHERE maasserver_interface.vlan_id IS NOT NULL
	AND maasserver_vlan.id NOT IN (
	    JOIN maasserver_subnet ON maasserver_vlan.id = maasserver_subnet.vlan_id
	DELETE FROM maasserver_fabric
	WHERE maasserver_fabric.id NOT IN (
	    SELECT maasserver_fabric.id
	    LEFT JOIN maasserver_vlan ON maasserver_vlan.fabric_id = maasserver_fabric.id
	    WHERE maasserver_vlan.fabric_id IS NOT NULL
Let’s break down each DELETE statement:
DELETE FROM maasserver_vlan: This statement deletes VLANs (from the table maasserver_vlan) that are not associated with a network interface of a server (left join with maasserver_interface on the vlan_id) or used by a subnet (inner join with maasserver_subnet on the vlan_id).
DELETE FROM maasserver_fabric: This statement deletes fabrics (from the table maasserver_fabric) that are not associated with a VLAN (left join with maasserver_vlan on the fabric_id).
In my case, that was 23902 VLANs and 23899 fabrics.
DELETE 23902
DELETE 23899
I had a few fabrics left over that I had to delete the subnet for first, but once I did and ran the DELETE statements again, my list was clear of extra fabrics.
