maas.io/docs/install-from-a-snap says that maas init --mode all
is depreciated in 2.8 and will be removed in 2.9. However, installing the snap as above, the result is the usage message, with the assertion that the only valid modes are region+rack, region, rack and none. Plans changed, or just a little fast on the deletion trigger?
