Just installed 2.7 and notice that I can’t add a virsh pod manually with qemu+ssh://admin@172.166.10.44/system keep getting ( Failed talking to pod: Failed to login to virsh console) but it works fine with 2.6 anyone knows if the syntax change on how to add the pods with 2.7 ?
Hey @rafise,
Could you please file a bug with any relevant logs and the steps you take to add a pod?
Lily
I’m hitting the same thing, but couldn’t find a bug…
https://bugs.launchpad.net/maas/+bug/1874847
The magic is:
ssh-keygen -f id_rsa
mkdir -p /var/snap/maas/current/root/.ssh
sudo cp id_rsa /var/snap/current/root/.ssh
cat id_rsa.pub >> ~/.ssh/authorized_keys
That maybe correct because I wan’t able to find the maas user at all under /etc/maas
