MAAS 2.5.0 beta4 released!
MAAS 2.5.0 (beta4)
We are happy to announce MAAS 2.5.0 beta4. This release is mostly focused on stabilization, bug fixes and improvements.
Bug fixes
Issues fixed in this release include:
  • LP: #1788530 - [UI] Cannot add a logical volume on top of partition if the disk has been previously partitioned
  • LP: #1796161 - [2.4] 2018-10-04 18:32:34 maasserver.listener: [critical] Failure while handling notification to ‘resourcepool’: ‘’
  • LP: #1797632 - [2.5] MAAS uses observed IP address that doesn’t exist in a controller to configure internal DNS
  • LP: #1798479 - [2.5b3] Unable to deploy server - curtin config SERVER_ROOT
  • LP: #1411023 - Scripts using /bin/sh
  • LP: #1772511 - [2.3,2.4] op=netboot_off no longer logged in regiond.log
  • LP: #1778916 - [2.5, UI] Metrics are being shown as one column
  • LP: #1792409 - [2.5] Machine subnet links removed after release after deployment using bridge_all=true
  • LP: #1797484 - [2.5] KVM pod deployment does not support ppc64
  • LP: #1797596 - [2.5, UI] Storage pool UI bar incorrectly shows used space
  • LP: #1797659 - [2.5, UI] maas 2.5 pods webUI used memory calculation is incorrect
  • LP: #1798431 - [2.5b3, UI] Branding should be Canonical not Ubuntu
  • LP: #1798978 - Register as MAAS KVM host
  • LP: #1786193 - [enhancement] Create / import SSH keys for other user
  • LP: #1787646 - Switch localboot to chain to the shim
  • LP: #1796085 - [2.5.0-beta2,UI, UX] The sliders for updating overcommit values should not allow for values less than 1
  • LP: #1713556 - [pod, feature, b1] Enable console logging to disk by default on KVM Pod VM’s.
  • LP: #1735950 - ValueError: Old and New apt format defined with unequal values True vs False @ apt_preserve_sources_list
For a full list of bug fixes, please refer to the following milestone link.
https://launchpad.net/maas/+milestone/2.5.0beta4
Installation
MAAS 2.5.0 beta 3 is available for Ubuntu Cosmic & Bionic and can be installed from our PPA as follows:
sudo apt install maas
thanks for the update! I’ll spin up an instance with the ppa whilst I await a new snap package for my dev cluster…
Should be available now too!
Other than the new features and fixes, what are the general differences between the edge, beta and stable channels in snap? IE is there additional instrumentation and tooling related to logging and so on? As all the channels need --devmode at the moment I assume there’s no security changes currently between them.
