MAAS 2.5.0 beta3 released!
MAAS 2.5.0 (beta3)
We are happy to announce MAAS 2.5.0 beta 3. This release is mostly focused on stabilization, bug fixes and improvements.
Bug fixes
Issues fixed in this release include:
  • LP: #1796224 - Enabling system’s nginx service breaks MAAS
  • LP: #1797135 - [21.5b2] ERROR ‘NoneType’ object has no attribute ‘relay_vlan’
  • LP: #1787632 - [2.5, UI] IP address only shown when auto-assign is used for physical interfaces (not when DHCP/static or vlans/bonds/etc)
  • LP: #1794560 - [2.5] KVM pod deployment does not support ARM64
  • LP: #1795013 - [2.5, UI] No UI option to deploy machine as a pod
  • LP: #1795759 - [2.5, websocket] Insufficient data about pod host attachments
  • LP: #1795890 - [2.5b2, UI] No storage pool selected by default - causes ‘storage: Malformed storage constraint, “0:8()”’ error
  • LP: #1795893 - [2.5b2, UI] Links for machines vs devices/controllers on listing page is inconsistent
  • LP: #1795904 - [2.5b2, UI] Under Take Actions don’t auto-aupdate
  • LP: #1796426 - [2.5] Pod websocket not notified if host interfaces change
  • LP: #1729649 - Initial delete of secondary rack controller fails
  • LP: #1795051 - [enhacement] Add MegaRAID support to smartctl tests
  • LP: #1795810 - [2.5] custom interface name editing in kvm compose pane focus doesn’t stick
  • LP: #1795931 - [2.5b2, UI] Mobile menu in base.html not working.
  • LP: #1796672 - [2.5b2, UI] Device filter not working
  • LP: #1797093 - [2.5b2, UI] Checkboxes have inconsistent alignment
For a full list of bug fixes, please refer to the following milestone link.
https://launchpad.net/maas/+milestone/2.5.0beta3
Installation
MAAS 2.5.0 beta 3 is available for Ubuntu Cosmic & Bionic and can be installed from our PPA as follows:
sudo apt install maas
