Hi Maas’ers,
I’m setting up a MAAS 2.3.5 cluster with some HP machines (ProLiant DL360p Gen8) (iLo 2.61) and I’m running into a few issues getting the BMC power configuration to function correctly.
Cloud-init returns IPMI power type, rather than HP Moonshot, which means I can’t commission the device as it can’t turn it on
Using the web UI, when I set the Power configuration to HP Moonshot I get an error stating that ipmitool is not installed, I installed ipmitool and now I have a new issue.
Here’s the rackd log message :
provisioningserver.drivers.power.PowerActionError: Failed to execute (‘ipmitool’, ‘-I’, ‘lanplus’, ‘-H’, ‘10.0.0.25’, ‘-U’, ‘maas’, ‘-P’, ‘exra3TyjSmdc6u’, ‘10.0.0.25’, ‘chassis’, ‘bootdev’, ‘pxe’) for cartridge 10.0.0.25 at 10.0.0.25: Error: Unable to establish IPMI v2 / RMCP+ session
2019-03-14 13:41:51 provisioningserver.rpc.power: [critical] free-dove: Power on failed.
File “/usr/lib/python3/dist-packages/twisted/internet/defer.py”, line 393, in callback
self._startRunCallbacks(result)
File “/usr/lib/python3/dist-packages/twisted/internet/defer.py”, line 501, in _startRunCallbacks
self._runCallbacks()
File “/usr/lib/python3/dist-packages/twisted/internet/defer.py”, line 588, in _runCallbacks
File “/usr/lib/python3/dist-packages/twisted/internet/defer.py”, line 1184, in gotResult
_inlineCallbacks(r, g, deferred)
File “/usr/lib/python3/dist-packages/twisted/internet/defer.py”, line 1126, in _inlineCallbacks
result = result.throwExceptionIntoGenerator(g)
File “/usr/lib/python3/dist-packages/twisted/python/failure.py”, line 389, in throwExceptionIntoGenerator
File “/usr/lib/python3/dist-packages/provisioningserver/rpc/power.py”, line 285, in change_power_state
system_id, hostname, power_type, power_change, context)
File “/usr/lib/python3/dist-packages/twisted/internet/defer.py”, line 1128, in _inlineCallbacks
result = g.send(result)
File “/usr/lib/python3/dist-packages/provisioningserver/drivers/power/init.py”, line 422, in perform_power
raise exc_info0.with_traceback(exc_info[2])
File “/usr/lib/python3/dist-packages/provisioningserver/drivers/power/init.py”, line 379, in perform_power
power_func, system_id, context)
File “/usr/lib/python3/dist-packages/twisted/python/threadpool.py”, line 246, in inContext
result = inContext.theWork()
File “/usr/lib/python3/dist-packages/twisted/python/threadpool.py”, line 262, in
File “/usr/lib/python3/dist-packages/twisted/python/context.py”, line 118, in callWithContext
File “/usr/lib/python3/dist-packages/twisted/python/context.py”, line 81, in callWithContext
return func(*args,**kw)
File “/usr/lib/python3/dist-packages/provisioningserver/utils/twisted.py”, line 232, in wrapper
File “/usr/lib/python3/dist-packages/provisioningserver/drivers/power/ipmi.py”, line 333, in power_on
self._issue_ipmi_command(‘on’, **context)
File “/usr/lib/python3/dist-packages/provisioningserver/drivers/power/ipmi.py”, line 330, in _issue_ipmi_command
ipmipower_command, power_change, power_address)
File “/usr/lib/python3/dist-packages/provisioningserver/drivers/power/ipmi.py”, line 265, in _issue_ipmipower_command
raise error_info.get(‘exception’)(error_info.get(‘message’))
provisioningserver.drivers.power.PowerConnError: Connection timed out while performing power action. Check BMC configuration and connectivity and try again.
2019-03-14 13:46:51 provisioningserver.rackdservices.dhcp_probe_service: [info] Probe for external DHCP servers started on interfaces: enp3s0, enp2s0.
2019-03-14 13:47:02 provisioningserver.dhcp.detect: [info] External DHCP server(s) discovered on interface ‘enp3s0’: 10.0.0.1
2019-03-14 13:47:12 provisioningserver.rackdservices.dhcp_probe_service: [info] External DHCP probe complete.
I’ve tried to manually run the command myself and I get the same error.
If there’s more information I need to supply, just shout. I tried this exact setup about a month back and it worked a treat, however I can’t recall the versions I was using.
Any help gratefully received.
–Jools
