00-maas-00-support-info: MAAS gathers information that helps to identify and characterize the machine for debugging purposes, such as the kernel, versioning of various components, etc.
00-maas-01-lshw: this script pulls system BIOS and vendor info, and generates user-defined tags for later use.
00-maas-02-virtuality: this script checks whether the machine being commissioning is a virtual machine, which may affect how MAAS interacts with it.
00-maas-03-install-lldpd: this script installs the link layer discovery protocol (LLDP) daemon, which will later capture networking information about the machine. The lldpd needs to be installed early because it requires about a 60-second delay before running.
00-maas-04-list-modaliases: this script figures out what hardware modules are loaded, providing a way to autorun certain scripts based on which modules are loaded.
00-maas-05-dhcp-unconfigured-ifaces: MAAS will want to know all the ways the machine is connected to the network. Only PXE comes online during boot; this script brings all the other networks online so they can be recognized.
00-maas-06-get-fruid-api-data: this script gathers information for the Facebook wedge power type.
00-maas-08-serial-ports: this script lists what serial ports are available on the machine.
40-maas-01-network-interfaces: this script is just used to get the IP address, which can then be associated with a VLAN/subnet.
50-maas-01-commissioning: this script is the main MAAS tool, gathering information on machine resources, such as storage, network devices, CPU, RAM, etc. We currently pull this data using lxd: We use a Go binary built from lxd source that just contains the minimum source to gather the resource information we need.
99-maas-01-capture-lldp: this script gathers LLDP network information to be presented on the logs page; this data is not used by MAAS at all.
99-maas-05-kernel-cmdline: this script is used to update the boot devices; it double-checks that the right boot interface is selected.
Commissioning runs the same dozen or so scripts as enlistment, gathering all the same information, but with some additional caveats:
Commissioning also runs user-supplied commissioning scripts, if present. Be aware that these scripts run as root, so they can execute any system command.
Commissioning runs test scripts which are not run during enlistment.
