Hi!
I don’t know why, but If I assign the LVM storage template to a server that will be installed with 20.04 hwe kernel, the installation process fails with:
finish: cmd-install/stage-curthooks/builtin/cmd-curthooks: FAIL: curtin command curthooks
File "/curtin/curtin/commands/main.py", line 202, in main
ret = args.func(args)
File "/curtin/curtin/commands/curthooks.py", line 1886, in curthooks
builtin_curthooks(cfg, target, state)
File "/curtin/curtin/commands/curthooks.py", line 1851, in builtin_curthooks
setup_grub(cfg, target, osfamily=osfamily,
File "/curtin/curtin/commands/curthooks.py", line 804, in setup_grub
install_grub(instdevs, target, uefi=uefi_bootable, grubcfg=grubcfg)
File "/curtin/curtin/commands/install_grub.py", line 398, in install_grub
in_chroot.subp(cmd, env=env, capture=True)
File "/curtin/curtin/util.py", line 780, in subp
return subp(*args, **kwargs)
File "/curtin/curtin/util.py", line 275, in subp
return _subp(*args, **kwargs)
File "/curtin/curtin/util.py", line 139, in _subp
raise ProcessExecutionError(stdout=out, stderr=err,
Command: ['unshare', '--fork', '--pid', '--', 'chroot', '/tmp/tmpi6ddcgfl/target', '/usr/lib/grub/grub-multi-install']
Exit code: 1
Reason: -
Stdout: ''
Stderr: Installing grub to /boot/efi.
Installing for x86_64-efi platform.
Installation finished. No error reported.
Installing grub to /var/lib/grub/esp.
grub-install: error: /var/lib/grub/esp doesn't look like an EFI partition.
I have other servers like this one (slight previous HW version) installed with 18.04.
Any idea why this could be happening?
