I have a dozen HP ProLiant DL360 G7. Four of them are failing to commission with the following error:
/tmp/user_data.sh.SIeaSC/scripts/commissioning/00-maas-01-lshw: line 6: 2845 Segmentation fault sudo -n /usr/bin/lshw -xml
I’m running MAAS version: 2.7.0 (8235-g.fea3a1678)
I manually installed Ubuntu server 18.04.4 and ran sudo -n /usr/bin/lshw -xml, worked fine. I am not sure where to go from here. Any ideas?
