I am installing “ubuntu-desktop” package to convert the ubuntu2204 server that I installed with MAAS to workstation, but at the end of the installation I have a low resolution problem(stuck with 1024*768) with kernel 5.15.0.73.
However, when I install ubuntu2204 server + “ubuntu-desktop” + 5.15.0.73 kernel combination via “usb”, there is no resolution problem. What are the points I should look for to solve the problem?
Thanks.
I tried these combinations:
Ubuntu 2204 Desktop(kernel 6x) then installed kernel 5.15.0-73 - OK (with USB boot)
Ubuntu 2204 Server + ubuntu-desktop + kernel 5.0.73generic - OK (with USB boot)
Ubuntu 2204 Server + ubuntu-desktop + kernel 5.0.73 - LOW Resolution (with MAAS Installed)
Additional information:
Graphics: llvmpipe(LLVM 15.0.7, 256 bits)
Windowing System : X11
HW Infos:
Motherboard: Asus x670-e
CPU : Ryzen 5 7600
OUTPUT(RESOLUTION IS OK) ubuntu2204 server(default kernel 5.15.0-83) + ubuntu-desktop + kernel 5.0.73 (usb installed): lshw -C video
sudo lshw -C video
*-display UNCLAIMED
description: VGA compatible controller
product: Advanced Micro Devices, Inc. [AMD/ATI]
vendor: Advanced Micro Devices, Inc. [AMD/ATI]
physical id: 0
bus info: pci@0000:0f:00.0
version: c6
width: 64 bits
clock: 33MHz
capabilities: pm pciexpress msi msix vga_controller bus_master cap_list
configuration: latency=0
resources: iomemory:fc0-fbf iomemory:fc0-fbf memory:fce0000000-fcefffffff memory:fcf0000000-fcf01fffff ioport:e000(size=256) memory:fce00000-fce7ffff
*-graphics
product: EFI VGA
physical id: 1
logical name: /dev/fb0
capabilities: fb
configuration: depth=32 resolution=1680,1050
OUTPUT(LOW RESOLUTION PROBLEM) ubuntu2204 server + ubuntu-desktop + kernel 5.0.73 (maas installed): lshw -C video
sudo lshw -C video
*-display UNCLAIMED
physical id: 0
version: c6
width: 64 bits
clock: 33MHz
*-graphics
product: EFI VGA
physical id: 1
capabilities: fb
configuration: depth=32 resolution=1024,768
