Hi guys,
I am sorry for the late reply but we had a ton of servers to upgrade to fix VITs and Maas upgrade had to be moved.
I am back on it and I have more information.
I am back at step 1 because I did a snapshot when it’s working, ubuntu 18.04 and Maas 2.8.7.
My goal is Ubuntu 22 and Maas 3.X
After upgrading to Ubuntu 20.04 here is the status:
DISTRIB_ID=Ubuntu
DISTRIB_RELEASE=20.04
DISTRIB_CODENAME=focal
DISTRIB_DESCRIPTION="Ubuntu 20.04.6 LTS"
$ dpkg -l|grep maas
ii maas 1:0.7 all Transitional package to the maas snap
rc maas-common 2.8.7-8611-g.f2514168f-0ubuntu1~18.04.1 all MAAS server common files
rc maas-dhcp 2.8.7-8611-g.f2514168f-0ubuntu1~18.04.1 all MAAS DHCP server
rc maas-proxy 2.8.7-8611-g.f2514168f-0ubuntu1~18.04.1 all MAAS Caching Proxy
ii maas-rack-controller 1:0.7 all Transitional package to the maas snap
ii maas-region-api 1:0.7 all Transitional package to the maas snap
ii maas-region-controller 1:0.7 all Transitional package to the maas snap
ii python3-django-maas 2.8.7-8611-g.f2514168f-0ubuntu1~18.04.1 all MAAS server Django web framework (Python 3)
ii python3-maas-client 2.8.7-8611-g.f2514168f-0ubuntu1~18.04.1 all MAAS python API client (Python 3)
ii python3-maas-provisioningserver 2.8.7-8611-g.f2514168f-0ubuntu1~18.04.1 all MAAS server provisioning libraries (Python 3)
Is it normal some packages are already in rc state here ?
I am now trying to install 2.9:
$ sudo add-apt-repository ppa:maas/2.9
And then:
$ apt list --upgradable
Listing... Done
curtin-common/focal 21.2-0ubuntu1~20.04.1 all [upgradable from: 21.2-0ubuntu1~18.04.1]
maas-rack-controller/focal 1:2.9.2-9164-g.ac176b5c4-0ubuntu1~20.04.1 all [upgradable from: 1:0.7]
maas-region-api/focal 1:2.9.2-9164-g.ac176b5c4-0ubuntu1~20.04.1 all [upgradable from: 1:0.7]
maas-region-controller/focal 1:2.9.2-9164-g.ac176b5c4-0ubuntu1~20.04.1 all [upgradable from: 1:0.7]
maas/focal 1:2.9.2-9164-g.ac176b5c4-0ubuntu1~20.04.1 all [upgradable from: 1:0.7]
python3-curtin/focal 21.2-0ubuntu1~20.04.1 all [upgradable from: 21.2-0ubuntu1~18.04.1]
python3-django-maas/focal 1:2.9.2-9164-g.ac176b5c4-0ubuntu1~20.04.1 all [upgradable from: 2.8.7-8611-g.f2514168f-0ubuntu1~18.04.1]
python3-maas-client/focal 1:2.9.2-9164-g.ac176b5c4-0ubuntu1~20.04.1 all [upgradable from: 2.8.7-8611-g.f2514168f-0ubuntu1~18.04.1]
python3-maas-provisioningserver/focal 1:2.9.2-9164-g.ac176b5c4-0ubuntu1~20.04.1 all [upgradable from: 2.8.7-8611-g.f2514168f-0ubuntu1~18.04.1]
python3-pylxd/focal 2.2.11~ubuntu20.04-1 all [upgradable from: 2.2.11~ubuntu18.04-1]
$ sudo apt upgrade
Reading package lists... Done
Building dependency tree
Calculating upgrade... Done
Some packages could not be installed. This may mean that you have
requested an impossible situation or if you are using the unstable
distribution that some required packages have not yet been created
or been moved out of Incoming.
The following information may help to resolve the situation:
The following packages have unmet dependencies:
maas : Conflicts: bind9
Conflicts: isc-dhcp-server
Conflicts: maas-cli
Conflicts: maas-common
Conflicts: maas-dhcp
Conflicts: maas-proxy
E: Broken packages
I still can upgrade with:
$ sudo apt full-upgrade -y
It does:
maas maas-rack-controller maas-region-api maas-region-controller
The following NEW packages will be installed:
freeipmi-tools libipmiconsole2 libipmidetect0 python3-pypureomapi
The following packages will be upgraded:
curtin-common python3-curtin python3-django-maas python3-maas-client python3-maas-provisioningserver python3-pylxd
6 upgraded, 4 newly installed, 4 to remove and 0 not upgraded.
After a reboot:
$ dpkg -l|grep maas
rc maas 1:0.7 all Transitional package to the maas snap
rc maas-rack-controller 1:0.7 all Transitional package to the maas snap
rc maas-region-api 1:0.7 all Transitional package to the maas snap
ii python3-django-maas 1:2.9.2-9164-g.ac176b5c4-0ubuntu1~20.04.1 all MAAS server Django web framework (Python 3)
ii python3-maas-client 1:2.9.2-9164-g.ac176b5c4-0ubuntu1~20.04.1 all MAAS python API client (Python 3)
ii python3-maas-provisioningserver 1:2.9.2-9164-g.ac176b5c4-0ubuntu1~20.04.1 all MAAS server provisioning libraries (Python 3)
I now try to upgrade to 3.0
$ sudo apt-add-repository ppa:maas/3.0
And if I try to upgrade following the doc:
Listing... Done
python3-django-maas/focal 1:3.0.1-10052-g.82c730c57-0ubuntu1~20.04.1 all [upgradable from: 1:2.9.2-9164-g.ac176b5c4-0ubuntu1~20.04.1]
python3-maas-client/focal 1:3.0.1-10052-g.82c730c57-0ubuntu1~20.04.1 all [upgradable from: 1:2.9.2-9164-g.ac176b5c4-0ubuntu1~20.04.1]
python3-maas-provisioningserver/focal 1:3.0.1-10052-g.82c730c57-0ubuntu1~20.04.1 all [upgradable from: 1:2.9.2-9164-g.ac176b5c4-0ubuntu1~20.04.1]
python3-pylxd/focal 2.3.1~alpha1-386-8-g.b36a7ac~ubuntu20.04.1 all [upgradable from: 2.2.11~ubuntu20.04-1]
$ sudo apt upgrade maas
maas : Depends: maas-rack-controller (= 1:3.0.1-10052-g.82c730c57-0ubuntu1~20.04.1)
Depends: maas-region-controller (= 1:3.0.1-10052-g.82c730c57-0ubuntu1~20.04.1)
E: Broken packages
Should I install again those packages ? When I do I get new errors:
$ sudo apt install maas-rack-controller maas-region-controller
Preparing to unpack .../31-maas-region-controller_1%3a3.0.1-10052-g.82c730c57-0ubuntu1~20.04.1_all.deb ...
Unpacking maas-region-controller (1:3.0.1-10052-g.82c730c57-0ubuntu1~20.04.1) ...
Errors were encountered while processing:
/tmp/apt-dpkg-install-qIEpI2/19-maas-common_1%3a3.0.1-10052-g.82c730c57-0ubuntu1~20.04.1_all.deb
E: Sub-process /usr/bin/dpkg returned an error code (1)
You might want to run 'apt --fix-broken install' to correct these.
maas-rack-controller : Depends: maas-common (= 1:3.0.1-10052-g.82c730c57-0ubuntu1~20.04.1)
maas-region-api : Depends: maas-common (= 1:3.0.1-10052-g.82c730c57-0ubuntu1~20.04.1)
E: Unmet dependencies. Try 'apt --fix-broken install' with no packages (or specify a solution).
I think I am totally in the wrong way now…
Thanks!
I don’t have the option of reinstalling Maas because we have to many servers deployed on it.
Edit, just saw this:
ERROR: The MAAS Debian packages may not be installed alongside the MAAS Snap!
I am not familiar with snap and I thought I only used the package repositories…
