I have two subnets, both of which have valid gateways configured in the Subnets configuration area:
10.51.0.0/24 with gateway 10.51.0.1
192.168.243.128/25 with gateway 192.168.243.129
Many servers will either be connected to one or the other but some will need connectivity to both.
In those cases, I need to be able to make sure the default gateway is kept/set for the 10.51.0.0/24 subnet and no default gateway set for the 192.168.243.128/25 subnet.
So the end result for the machine would be something like:
eno1: 10.51.0.89/24 with default gateway 10.51.0.1
eno3: 192.168.243.160/25 with no default gateway
I am struggling to work out how this is possible in MAAS - is it?
