Hello!
I’m currently trying to setup some servers using MAAS in an IPv6 - only network.
I’m using the MAAS API to set up servers and provide IPMI configuration (IP address, username, password). Everything works fine until the end of the commission. Then ‘suddenly’ the valid and working IPv6 link local address is overwritten by an (unusable) IPv4 address, like:
# maas maas_user machines power-parameters
"asw77q": {
"k_g": "",
"power_pass": "XYZ",
"power_user": "maas",
"power_driver": "LAN_2_0",
"power_address": "192.168.0.120",
"cipher_suite_id": "3",
"power_boot_type": "efi",
"privilege_level": "ADMIN",
"mac_address": "B0:8B:35:AE:B4:56"
BTW: IPv4 is explicitly disabled on the IMPI.
Does somebody know where / when / why this change happens? Is there a way to switch off this automatic update of the IPMI IP address as the original perfectly works? (Manually (via GUI) changing the IP back to the IPv6 address enables me to install the servers.)
Using Ubuntu 20.04 LTS and MAAS 2.9.2
Kind regards - Andre
