Ip ranges (CLI)
Create a range
Choose ‘Reserve range’ or ‘Reserve dynamic range’. If you choose the latter, MAAS will automatically provide DHCP for enlistment and commissioning provided that the associated VLAN has DHCP enabled. Read the DHCP page.
See MAAS CLI for doing this with the CLI.
Edit a range
Delete a range
