Add a tag to an interface
maas $PROFILE interface add-tag [--help] [-d] [-k] system_id id [data ...]
Positional arguments
- system_id
- id
Add a tag to an interface with the given system_id and interface id.
Keyword “tag”
Optional String. The tag to add.
Command-line options
| Option | Effect |
Delete an interface
maas $PROFILE interface delete [--help] [-d] [-k] system_id id [data ...]
- system_id
- id
Delete an interface with the given system_id and interface id.
| Option | Effect |
Disconnect an interface
maas $PROFILE interface disconnect [--help] [-d] [-k] system_id id [data ...]
- system_id
- id
Disconnect an interface with the given system_id and interface id.
Deletes any linked subnets and IP addresses, and disconnects the interface from any associated VLAN.
| Option | Effect |
Link interface to a subnet
maas $PROFILE interface link-subnet [--help] [-d] [-k] system_id id [data ...]
- system_id
- id
Link an interface with the given system_id and interface id to a subnet.
Keyword “mode”
Required String. AUTO,DHCP, STATIC or LINK_UP connection to subnet.
Mode definitions:
AUTO: Assign this interface a static IP address from the provided subnet. The subnet must be a managed subnet. The IP address will not be assigned until the node goes to be deployed. -
DHCP: Bring this interface up with DHCP on the given subnet. Only one subnet can be set toDHCP. If the subnet is managed this interface will pull from the dynamic IP range. -
STATIC: Bring this interface up with a static IP address on the given subnet. Any number of static links can exist on an interface. -
LINK_UP: Bring this interface up only on the given subnet. No IP address will be assigned to this interface. The interface cannot have any currentAUTO,DHCPorSTATIClinks.
Keyword “subnet”
Required Int. Subnet id linked to interface.
Keyword “ip_address”
Optional String. IP address for the interface in subnet. Only used when mode is STATIC. If not provided an IP address from subnet will be auto selected.
Keyword “force”
Optional Boolean. If True, allows LINK_UP to be set on the interface even if other links already exist. Also allows the selection of any VLAN, even a VLAN MAAS does not believe the interface to currently be on. Using this option will cause all other links on the interface to be deleted. (Defaults to False.)
Keyword “default_gateway”
Optional String. True sets the gateway IP address for the subnet as the default gateway for the node this interface belongs to. Option can only be used with the AUTO and STATIC modes.
| Option | Effect |
Read an interface
maas $PROFILE interface read [--help] [-d] [-k] system_id id [data ...]
- system_id
- id
Read an interface with the given system_id and interface id.
| Option | Effect |
Remove a tag from an interface
maas $PROFILE interface remove-tag [--help] [-d] [-k] system_id id [data ...]
- system_id
- id
Remove a tag from an interface with the given system_id and interface id.
Keyword “tag”
Optional String. The tag to remove.
| Option | Effect |
Set the default gateway on a machine
maas $PROFILE interface set-default-gateway [--help] [-d] [-k] system_id id [data ...]
- system_id
- id
Set the given interface id on the given system_id as the default gateway.
If this interface has more than one subnet with a gateway IP in the same IP address family then specifying the ID of the link on this interface is required.
Keyword “link_id”
Optional Int. ID of the link on this interface to select the default gateway IP address from.
| Option | Effect |
Unlink interface from subnet
maas $PROFILE interface unlink-subnet [--help] [-d] [-k] system_id id [data ...]
- system_id
- id
Unlink an interface with the given system_id and interface id from a subnet.
Keyword “id”
Optional Int. ID of the subnet link on the interface to remove.
| Option | Effect |
Update an interface
maas $PROFILE interface update [--help] [-d] [-k] system_id id [data ...]
- system_id
- id
Update an interface with the given system_id and interface id.
Note: machines must have a status of Ready or Broken to have access to all options. Machines with Deployed status can only have the name and/or mac_address updated for an interface. This is intented to allow a bad interface to be replaced while the machine remains deployed.
Keyword “name”
Optional String. (Physical interfaces) Name of the interface.
Keyword “mac_address”
Optional String. (Physical interfaces) MAC address of the interface.
Keyword “tags”
Optional String. (Physical interfaces) Tags for the interface.
Keyword “vlan”
Optional Int. (Physical interfaces) Untagged VLAN id the interface is connected to. If not set then the interface is considered disconnected.
Keyword “name”
Optional String. (Bond interfaces) Name of the interface.
Optional String. (Bond interfaces) MAC address of the interface.
Keyword “tags”
Optional String. (Bond interfaces) Tags for the interface.
Keyword “vlan”
Optional Int. (Bond interfaces) Untagged VLAN id the interface is connected to. If not set then the interface is considered disconnected.
Keyword “parents”
Optional Int. (Bond interfaces) Parent interface ids that make this bond.
Keyword “tags”
Optional String. (VLAN interfaces) Tags for the interface.
Keyword “vlan”
Optional Int. (VLAN interfaces) Tagged VLAN id the interface is connected to.
Keyword “parent”
Optional Int. (VLAN interfaces) Parent interface ids for the VLAN interface.
Keyword “name”
Optional String. (Bridge interfaces) Name of the interface.
Optional String. (Bridge interfaces) MAC address of the interface.
Keyword “tags”
Optional String. (Bridge interfaces) Tags for the interface.
Keyword “vlan”
Optional Int. (Bridge interfaces) VLAN id the interface is connected to.
Keyword “parent”
Optional Int. (Bridge interfaces) Parent interface ids for this bridge interface.
Keyword “bridge_type”
Optional String. (Bridge interfaces) Type of bridge to create. Possible values are: standard, ovs.
Keyword “bridge_stp”
Optional Boolean. (Bridge interfaces) Turn spanning tree protocol on or off. (Default: False).
Keyword “bridge_fd”
Optional Int. (Bridge interfaces) Set bridge forward delay to time seconds. (Default: 15).
Keyword “bond_miimon”
Optional Int. (Bonds) The link monitoring freqeuncy in milliseconds. (Default: 100).
Keyword “bond_downdelay”
Optional Int. (Bonds) Specifies the time, in milliseconds, to wait before disabling a slave after a link failure has been detected.
Keyword “bond_updelay”
Optional Int. (Bonds) Specifies the time, in milliseconds, to wait before enabling a slave after a link recovery has been detected.
Keyword “bond_lacp_rate”
Optional String. (Bonds) Option specifying the rate in which we’ll ask our link partner to transmit LACPDU packets in 802.3ad mode. Available options are fast or slow. (Default: slow).
Keyword “bond_xmit_hash_policy”
Optional String. (Bonds) The transmit hash policy to use for slave selection in balance-xor, 802.3ad, and tlb modes. Possible values are: layer2, layer2+3, layer3+4, encap2+3, encap3+4.
Keyword “bond_mode”
The operating mode of the bond. (Default: active-backup).
Supported bonding modes (bond-mode):
balance-rr: Transmit packets in sequential order from the first available slave through the last. This mode provides load balancing and fault tolerance. -
active-backup: Only one slave in the bond is active. A different slave becomes active if, and only if, the active slave fails. The bond’s MAC address is externally visible on only one port (network adapter) to avoid confusing the switch. -
balance-xor: Transmit based on the selected transmit hash policy. The default policy is a simple [(source MAC address XOR’d with destination MAC address XOR packet type ID) modulo slave count]. -
broadcast: Transmits everything on all slave interfaces. This mode provides fault tolerance. -
802.3ad: IEEE 802.3ad Dynamic link aggregation. Creates aggregation groups that share the same speed and duplex settings. Utilizes all slaves in the active aggregator according to the 802.3ad specification. -
balance-tlb: Adaptive transmit load balancing: channel bonding that does not require any special switch support. -
balance-alb: Adaptive load balancing: includes balance-tlb plus receive load balancing (rlb) for IPV4 traffic, and does not require any special switch support. The receive load balancing is achieved by ARP negotiation.
Keyword “mtu”
Optional String. Maximum transmission unit.
Keyword “accept_ra”
Optional String. Accept router advertisements. (IPv6 only)
Keyword “link_connected”
Optional Boolean. (Physical interfaces) Whether or not the interface is physically conntected to an uplink. (Default: True).
Keyword “interface_speed”
Optional Int. (Physical interfaces) The speed of the interface in Mbit/s. (Default: 0).
Keyword “link_speed”
Optional Int. (Physical interfaces) The speed of the link in Mbit/s. (Default: 0).
| Option | Effect |
Create a bond interface
maas $PROFILE interfaces create-bond [--help] [-d] [-k] system_id [data ...]
- system_id
Create a bond interface on a machine.
Keyword “name”
Required String. Name of the interface.
Optional String. MAC address of the interface.
Keyword “tags”
Optional String. Tags for the interface.
Keyword “vlan”
Optional String. VLAN the interface is connected to. If not provided then the interface is considered disconnected.
Keyword “parents”
Required Int. Parent interface ids that make this bond.
Keyword “bond_mode”
Optional String. The operating mode of the bond. (Default: active-backup).
Supported bonding modes:
802.3ad: IEEE 802.3ad dynamic link aggregation. Creates aggregation groups that share the same speed and duplex settings. Uses all slaves in the active aggregator according to the 802.3ad specification. -
Optional Int. The link monitoring freqeuncy in milliseconds. (Default: 100).
Optional Int. Specifies the time, in milliseconds, to wait before disabling a slave after a link failure has been detected.
Optional Int. Specifies the time, in milliseconds, to wait before enabling a slave after a link recovery has been detected.
Optional String. Option specifying the rate at which to ask the link partner to transmit LACPDU packets in 802.3ad mode. Available options are fast or slow. (Default: slow).
Optional String. The transmit
modes. Possible values are: layer2, layer2+3, layer3+4, encap2+3, encap3+4. (Default: layer2)
Keyword “bond_num_grat_arp”
Optional Int. The number of peer notifications (IPv4 ARP or IPv6 Neighbour Advertisements) to be issued after a failover. (Default: 1)
Keyword “mtu”
Optional Int. Maximum transmission unit.
Keyword “accept_ra”
Optional Boolean. Accept router advertisements. (IPv6 only)
| Option | Effect |
Create a bridge interface
maas $PROFILE interfaces create-bridge [--help] [-d] [-k] system_id [data ...]
- system_id
Create a bridge interface on a machine.
Keyword “name”
Optional String. Name of the interface.
Keyword “tags”
Keyword “vlan”
Keyword “parent”
Optional Int. Parent interface id for this bridge interface.
Optional String. The type of bridge to create. Possible values are: standard, ovs.
Optional Boolean. Turn spanning tree protocol on or off. (Default: False).
Keyword “bridge_fd”
Optional Int. Set bridge forward delay to time seconds. (Default: 15).
Keyword “mtu”
Keyword “accept_ra”
| Option | Effect |
Create a physical interface
maas $PROFILE interfaces create-physical [--help] [-d] [-k] system_id [data ...]
- system_id
Create a physical interface on a machine and device.
Keyword “name”
Required String. MAC address of the interface.
Keyword “tags”
Keyword “vlan”
Optional String. Untagged VLAN the interface is connected to. If not provided then the interface is considered disconnected.
Keyword “mtu”
Keyword “accept_ra”
| Option | Effect |
Create a VLAN interface
maas $PROFILE interfaces create-vlan [--help] [-d] [-k] system_id [data ...]
- system_id
Create a VLAN interface on a machine.
Keyword “tags”
Keyword “vlan”
Required String. Tagged VLAN the interface is connected to.
Keyword “parent”
Required Int. Parent interface id for this VLAN interface.
Keyword “mtu”
Keyword “accept_ra”
| Option | Effect |
List interfaces
maas $PROFILE interfaces read [--help] [-d] [-k] system_id [data ...]
- system_id
List all interfaces belonging to a machine, device, or rack controller.
| Option | Effect |
