- What are boot sources, and why do they matter?
- How do I select and import an image?
- How do I set up and use a local image mirror?
- How do I use and manage VMWare images?
- How do I manage images with the CLI?
MAAS stores images in the region controller’s database, from where the rack controller proxies them to the individual machines. It’s important to note that for ESXi images, network configuration includes only:
- DHCP
- Static/auto IP assignments
- Aliases
- VLANs
- Bonds – bonds are mapped to NIC teaming as follows:
- balance-rr – portid
- active-backup – explicit
- 802.3ad – iphash, LACP rate and XMIT hash policy settings ignored
See CLI Image Management for information on advanced image management.
Boot sources
https://images.maas.io/ephemeral-v3/daily/
The above URL points to the ‘daily’ stream (for the v3 format). See Local image mirror for some explanation regarding the availability of other streams.
