Images are Always Queued for Download
I am trying to set up MAAS in the following configuration
I have not set up the rack controller yet. I am on the Region controller UI, trying to set it up through the first-time log in prompts. The images never download even though the region controller has internet access.
Even setting up the rack controller and connecting it to the region controller doesn’t change anything (as seen below):
If I add any image, it goes to the ‘Queued for download’ state and if I try to delete it, I get the following error:
I am using the MAAS snap through the web UI on a Ubuntu 24.04 server (for both region and rack controllers) with the root partition having almost 80 GB free on both controllers. I can ping google.com and maas.io from both controllers.
Both controllers have the same MAAS version:
$ snap list maas
Name  Version                  Rev    Tracking    Publisher   Notes
maas  3.5.3-16341-g.7adb035d6  38185  3.5/stable  canonical✓  -
Logs:
I ran journalctl -u snap.maas.pebble.service to get the following.
Feb 25 19:57:41 region-controller maas.pebble[3563]: 2025-02-25T19:57:41.297Z [pebble] Change 75 task (Start service "temporal") failed: cannot start service: exited quickly with code 1
Feb 25 19:57:42 region-controller maas-log[4197]: maas.service_monitor: [error] Service 'temporal' failed to start: Pebble change 75 failed with an error: cannot perform the following tasks:#012- Start service "temporal" (cannot start service: exited quickly with code 1)
Feb 25 19:57:42 region-controller maas-log[4197]: maas.neighbour: [info] enp65s0 (physical) on region-controller: IP address 10.228.21.168 moved from c0:18:50:cb:18:f0 to c0:18:50:cb:18:ef
Feb 25 19:57:44 region-controller maas-temporal-worker[23657]: Task exception was never retrieved
Feb 25 19:57:44 region-controller maas-temporal-worker[23657]: future: <Task finished name='Task-2' coro=<Worker.run() done, defined at /snap/maas/38185/lib/python3.10/site-packages/maasserver/workflow/worker/worker.py:99> exception=RuntimeError('Failed client connect: Server connection error: tonic::transport::Error(Transport, hyper::Error(Connect, ConnectError("tcp connect error", Os { code: 111, kind: ConnectionRefused, message: "Connection refused" })))')>
Feb 25 19:57:44 region-controller maas-temporal-worker[23657]: Traceback (most recent call last):
Feb 25 19:57:44 region-controller maas-temporal-worker[23657]:   File "/snap/maas/38185/lib/python3.10/site-packages/maasserver/workflow/worker/worker.py", line 100, in run
Feb 25 19:57:44 region-controller maas-temporal-worker[23657]:     self._client = self._client or await get_client_async()
Feb 25 19:57:44 region-controller maas-temporal-worker[23657]:   File "/snap/maas/38185/lib/python3.10/site-packages/maasserver/utils/asynchronous.py", line 263, in wrapped
Feb 25 19:57:44 region-controller maas-temporal-worker[23657]:     raise e
Feb 25 19:57:44 region-controller maas-temporal-worker[23657]:   File "/snap/maas/38185/lib/python3.10/site-packages/maasserver/utils/asynchronous.py", line 259, in wrapped
Feb 25 19:57:44 region-controller maas-temporal-worker[23657]:     return await fn(*args, **kwargs)
Feb 25 19:57:44 region-controller maas-temporal-worker[23657]:   File "/snap/maas/38185/lib/python3.10/site-packages/maasserver/workflow/worker/worker.py", line 45, in get_client_async
Feb 25 19:57:44 region-controller maas-temporal-worker[23657]:     return await Client.connect(
Feb 25 19:57:44 region-controller maas-temporal-worker[23657]:   File "/snap/maas/38185/usr/lib/python3/dist-packages/temporalio/client.py", line 148, in connect
Feb 25 19:57:44 region-controller maas-temporal-worker[23657]:     await temporalio.service.ServiceClient.connect(connect_config),
Feb 25 19:57:44 region-controller maas-temporal-worker[23657]:   File "/snap/maas/38185/usr/lib/python3/dist-packages/temporalio/service.py", line 158, in connect
Feb 25 19:57:44 region-controller maas-temporal-worker[23657]:     return await _BridgeServiceClient.connect(config)
Feb 25 19:57:44 region-controller maas-temporal-worker[23657]:   File "/snap/maas/38185/usr/lib/python3/dist-packages/temporalio/service.py", line 685, in connect
Feb 25 19:57:44 region-controller maas-temporal-worker[23657]:     await client._connected_client()
Feb 25 19:57:44 region-controller maas-temporal-worker[23657]:   File "/snap/maas/38185/usr/lib/python3/dist-packages/temporalio/service.py", line 698, in _connected_client
Feb 25 19:57:44 region-controller maas-temporal-worker[23657]:     self._bridge_client = await temporalio.bridge.client.Client.connect(
Feb 25 19:57:44 region-controller maas-temporal-worker[23657]:   File "/snap/maas/38185/usr/lib/python3/dist-packages/temporalio/bridge/client.py", line 78, in connect
Feb 25 19:57:44 region-controller maas-temporal-worker[23657]:     await temporalio.bridge.temporal_sdk_bridge.connect_client(
Feb 25 19:57:44 region-controller maas-temporal-worker[23657]: RuntimeError: Failed client connect: Server connection error: tonic::transport::Error(Transport, hyper::Error(Connect, ConnectError("tcp connect error", Os { code: 111, kind: ConnectionRefused, message: "Connection refused" })))
Feb 25 19:57:45 region-controller maas.pebble[3563]: 2025-02-25T19:57:45.120Z [pebble] Service "temporal-worker" stopped unexpectedly with code 0
Feb 25 19:57:45 region-controller maas.pebble[3563]: 2025-02-25T19:57:45.120Z [pebble] Service "temporal-worker" on-success action is "restart", waiting ~500ms before restart (backoff 1)
Feb 25 19:57:45 region-controller maas.pebble[3563]: 2025-02-25T19:57:45.641Z [pebble] Service "temporal-worker" starting: sh -c "exec systemd-cat -t maas-temporal-worker $SNAP/bin/run-temporal-worker"
Feb 25 19:57:45 region-controller maas-log[4197]: maas.neighbour: [info] enp65s0 (physical) on region-controller: IP address 10.228.21.168 moved from c0:18:50:cb:18:ef to c0:18:50:cb:18:f0
Feb 25 19:57:49 region-controller maas-log[4197]: maas.neighbour: [info] enp65s0 (physical) on region-controller: IP address 10.228.21.168 moved from c0:18:50:cb:18:f0 to c0:18:50:cb:18:ef
Feb 25 19:57:52 region-controller maas-log[4197]: maas.neighbour: [info] enp65s0 (physical) on region-controller: IP address 10.228.21.168 moved from c0:18:50:cb:18:ef to c0:18:50:cb:18:f0
Feb 25 19:57:55 region-controller maas-log[4197]: maas.neighbour: [info] enp65s0 (physical) on region-controller: IP address 10.228.21.168 moved from c0:18:50:cb:18:f0 to c0:18:50:cb:18:ef
Feb 25 19:57:58 region-controller maas-log[4197]: maas.neighbour: [info] enp65s0 (physical) on region-controller: IP address 10.228.21.168 moved from c0:18:50:cb:18:ef to c0:18:50:cb:18:f0
Feb 25 19:58:01 region-controller maas-log[4197]: maas.neighbour: [info] enp65s0 (physical) on region-controller: IP address 10.228.21.168 moved from c0:18:50:cb:18:f0 to c0:18:50:cb:18:ef
Feb 25 19:58:04 region-controller maas-log[4197]: maas.neighbour: [info] enp65s0 (physical) on region-controller: IP address 10.228.21.168 moved from c0:18:50:cb:18:ef to c0:18:50:cb:18:f0
Feb 25 19:58:07 region-controller maas-log[4197]: maas.neighbour: [info] enp65s0 (physical) on region-controller: IP address 10.228.21.168 moved from c0:18:50:cb:18:f0 to c0:18:50:cb:18:ef
Feb 25 19:58:10 region-controller maas-log[4197]: maas.neighbour: [info] enp65s0 (physical) on region-controller: IP address 10.228.21.168 moved from c0:18:50:cb:18:ef to c0:18:50:cb:18:f0
Feb 25 19:58:11 region-controller maas.pebble[3563]: 2025-02-25T19:58:11.141Z [pebble] GET /v1/services?names=bind9 152.771µs 200
Feb 25 19:58:11 region-controller maas.pebble[3563]: 2025-02-25T19:58:11.141Z [pebble] GET /v1/services?names=ntp 122.403µs 200
Feb 25 19:58:11 region-controller maas.pebble[3563]: 2025-02-25T19:58:11.141Z [pebble] GET /v1/services?names=http 36.299µs 200
Feb 25 19:58:11 region-controller maas.pebble[3563]: 2025-02-25T19:58:11.141Z [pebble] GET /v1/services?names=syslog 76.485µs 200
Feb 25 19:58:11 region-controller maas.pebble[3563]: 2025-02-25T19:58:11.141Z [pebble] GET /v1/services?names=temporal-worker 74.752µs 200
Feb 25 19:58:11 region-controller maas.pebble[3563]: 2025-02-25T19:58:11.141Z [pebble] GET /v1/services?names=temporal 121.891µs 200
Feb 25 19:58:11 region-controller maas-log[4197]: maas.service_monitor: [info] Service 'maas-temporal' is not on, it will be started.
Feb 25 19:58:11 region-controller maas.pebble[3563]: 2025-02-25T19:58:11.163Z [pebble] POST /v1/services 6.841646ms 202
Feb 25 19:58:11 region-controller maas.pebble[3563]: 2025-02-25T19:58:11.163Z [pebble] GET /v1/services?names=proxy 5.978325ms 200
Feb 25 19:58:11 region-controller maas.pebble[3563]: 2025-02-25T19:58:11.169Z [pebble] Service "temporal" starting: sh -c "exec systemd-cat -t maas-temporal $SNAP/bin/run-temporal"
Feb 25 19:58:11 region-controller maas-temporal[24288]: 2025/02/25 19:58:11 Loading config; env=production,zone=,configDir=/var/snap/maas/38185/temporal
Feb 25 19:58:11 region-controller maas-temporal[24288]: 2025/02/25 19:58:11 Loading config files=[/var/snap/maas/38185/temporal/production.yaml]
Feb 25 19:58:11 region-controller maas-temporal[24288]: {"level":"error","ts":"2025-02-25T19:58:11.261Z","msg":"error returned","component":"fx","name":"go.temporal.io/server/common/membership/ringpop.provideHostInfoProvider()","kind":"provide","module":"","error":"received non-nil error from function \"go.temporal.io/server/common/membership/ringpop\".provideHostInfoProvider (/build/temporal-8dYnj9/temporal-1.22.5/src/common/membership/ringpop/fx.go:55): broadcastAddress required when listening on all interfaces (0.0.0.0/[::])","errorVerbose":"received non-nil error from function \"go.temporal.io/server/common/membership/ringpop\".provideHostInfoProvider\n\t/build/temporal-8dYnj9/temporal-1.22.5/src/common/membership/ringpop/fx.go:55:\nbroadcastAddress required when listening on all interfaces (0.0.0.0/[::])","logging-call-at":"fx.go:1122","stacktrace":"go.temporal.io/server/common/log.(*zapLogger).Error\n\t/build/temporal-8dYnj9/temporal-1.22.5/src/common/log/zap_logger.go:156\ngo.temporal.io/server/temporal.(*fxLogAdapter).LogEvent\n\t/build/temporal-8dYnj9/temporal-1.22.5/src/temporal/fx.go:1122\ngo.uber.org/fx.(*module).provide.func1\n\t/build/temporal-8dYnj9/temporal-1.22.5/src/vendor/go.uber.org/fx/module.go:160\ngo.uber.org/dig.(*constructorNode).Call.func1\n\t/build/temporal-8dYnj9/temporal-1.22.5/src/vendor/go.uber.org/dig/constructor.go:161\ngo.uber.org/dig.(*constructorNode).Call\n\t/build/temporal-8dYnj9/temporal-1.22.5/src/vendor/go.uber.org/dig/constructor.go:182\ngo.uber.org/dig.paramSingle.Build\n\t/build/temporal-8dYnj9/temporal-1.22.5/src/vendor/go.uber.org/dig/param.go:287\ngo.uber.org/dig.paramList.BuildList\n\t/build/temporal-8dYnj9/temporal-1.22.5/src/vendor/go.uber.org/dig/param.go:150\ngo.uber.org/dig.(*constructorNode).Call\n\t/build/temporal-8dYnj9/temporal-1.22.5/src/vendor/go.uber.org/dig/constructor.go:150\ngo.uber.org/dig.paramSingle.Build\n\t/build/temporal-8dYnj9/temporal-1.22.5/src/vendor/go.uber.org/dig/param.go:287\ngo.uber.org/dig.paramList.BuildList\n\t/build/temporal-8dYnj9/temporal-1.22.5/src/vendor/go.uber.org/dig/param.go:150\ngo.uber.org/dig.(*constructorNode).Call\n\t/build/temporal-8dYnj9/temporal-1.22.5/src/vendor/go.uber.org/dig/constructor.go:150\ngo.uber.org/dig.paramSingle.Build\n\t/build/temporal-8dYnj9/temporal-1.22.5/src/vendor/go.uber.org/dig/param.go:287\ngo.uber.org/dig.paramList.BuildList\n\t/build/temporal-8dYnj9/temporal-1.22.5/src/vendor/go.uber.org/dig/param.go:150\ngo.uber.org/dig.(*constructorNode).Call\n\t/build/temporal-8dYnj9/temporal-1.22.5/src/vendor/go.uber.org/dig/constructor.go:150\ngo.uber.org/dig.paramGroupedSlice.callGroupProviders\n\t/build/temporal-8dYnj9/temporal-1.22.5/src/vendor/go.uber.org/dig/param.go:609\ngo.uber.org/dig.paramGroupedSlice.Build\n\t/build/temporal-8dYnj9/temporal-1.22.5/src/vendor/go.uber.org/dig/param.go:639\ngo.uber.org/dig.paramObjectField.Build\n\t/build/temporal-8dYnj9/temporal-1.22.5/src/vendor/go.uber.org/dig/param.go:484\ngo.uber.org/dig.paramObject.Build\n\t/build/temporal-8dYnj9/temporal-1.22.5/src/vendor/go.uber.org/dig/param.go:412\ngo.uber.org/dig.paramList.BuildList\n\t/build/temporal-8dYnj9/temporal-1.22.5/src/vendor/go.uber.org/dig/param.go:150\ngo.uber.org/dig.(*constructorNode).Call\n\t/build/temporal-8dYnj9/temporal-1.22.5/src/vendor/go.uber.org/dig/constructor.go:150\ngo.uber.org/dig.paramSingle.Build\n\t/build/temporal-8dYnj9/temporal-1.22.5/src/vendor/go.uber.org/dig/param.go:287\ngo.uber.org/dig.paramList.BuildList\n\t/build/temporal-8dYnj9/temporal-1.22.5/src/vendor/go.uber.org/dig/param.go:150\ngo.uber.org/dig.(*Scope).Invoke\n\t/build/temporal-8dYnj9/temporal-1.22.5/src/vendor/go.uber.org/dig/invoke.go:122\ngo.uber.org/dig.(*Container).Invoke\n\t/build/temporal-8dYnj9/temporal-1.22.5/src/vendor/go.uber.org/dig/invoke.go:82\ngo.uber.org/fx.runInvoke\n\t/build/temporal-8dYnj9/temporal-1.22.5/src/vendor/go.uber.org/fx/invoke.go:108\ngo.uber.org/fx.(*module).executeInvoke\n\t/build/temporal-8dYnj9/temporal-1.22.5/src/vendor/go.uber.org/fx/module.go:279\ngo.uber.org/fx.(*module).executeInvokes\n\t/build/temporal-8dYnj9/temporal-1.22.5/src/vendor/go.uber.org/fx/module.go:265\ngo.uber.org/fx.New\n\t/build/temporal-8dYnj9/temporal-1.22.5/src/vendor/go.uber.org/fx/app.go:502\ngo.temporal.io/server/temporal.HistoryServiceProvider\n\t/build/temporal-8dYnj9/temporal-1.22.5/src/temporal/fx.go:377\nreflect.Value.call\n\t/usr/lib/go-1.20/src/reflect/value.go:586\nreflect.Value.Call\n\t/usr/lib/go-1.20/src/reflect/value.go:370\ngo.uber.org/dig.defaultInvoker\n\t/build/temporal-8dYnj9/temporal-1.22.5/src/vendor/go.uber.org/dig/container.go:238\ngo.uber.org/dig.(*constructorNode).Call\n\t/build/temporal-8dYnj9/temporal-1.22.5/src/vendor/go.uber.org/dig/constructor.go:180\ngo.uber.org/dig.paramGroupedSlice.callGroupProviders\n\t/build/temporal-8dYnj9/temporal-1.22.5/src/vendor/go.uber.org/dig/param.go:609\ngo.uber.org/dig.paramGroupedSlice.Build\n\t/build/temporal-8dYnj9/temporal-1.22.5/src/vendor/go.uber.org/dig/param.go:639\ngo.uber.org/dig.paramObjectField.Build\n\t/build/temporal-8dYnj9/temporal-1.22.5/src/vendor/go.uber.org/dig/param.go:484\ngo.uber.org/dig.paramObject.Build\n\t/build/temporal-8dYnj9/temporal-1.22.5/src/vendor/go.uber.org/dig/param.go:412\ngo.uber.org/dig.paramList.BuildList\n\t/build/temporal-8dYnj9/temporal-1.22.5/src/vendor/go.uber.org/dig/param.go:150\ngo.uber.org/dig.(*constructorNode).Call\n\t/build/temporal-8dYnj9/temporal-1.22.5/src/vendor/go.uber.org/dig/constructor.go:150\ngo.uber.org/dig.paramSingle.Build\n\t/build/temporal-8dYnj9/temporal-1.22.5/src/vendor/go.uber.org/dig/param.go:287\ngo.uber.org/dig.paramList.BuildList\n\t/build/temporal-8dYnj9/temporal-1.22.5/src/vendor/go.uber.org/dig/param.go:150\ngo.uber.org/dig.(*Scope).Invoke\n\t/build/temporal-8dYnj9/temporal-1.22.5/src/vendor/go.uber.org/dig/invoke.go:122\ngo.uber.org/dig.(*Container).Invoke\n\t/build/temporal-8dYnj9/temporal-1.22.5/src/vendor/go.uber.org/dig/invoke.go:82\ngo.uber.org/fx.runInvoke\n\t/build/temporal-8dYnj9/temporal-1.22.5/src/vendor/go.uber.org/fx/invoke.go:108\ngo.uber.org/fx.(*module).executeInvoke\n\t/build/temporal-8dYnj9/temporal-1.22.5/src/vendor/go.uber.org/fx/module.go:279\ngo.uber.org/fx.(*module).executeInvokes\n\t/build/temporal-8dYnj9/temporal-1.22.5/src/vendor/go.uber.org/fx/module.go:265\ngo.uber.org/fx.New\n\t/build/temporal-8dYnj9/temporal-1.22.5/src/vendor/go.uber.org/fx/app.go:502\ngo.temporal.io/server/temporal.NewServerFx\n\t/build/temporal-8dYnj9/temporal-1.22.5/src/temporal/fx.go:161\ngo.temporal.io/server/temporal.NewServer\n\t/build/temporal-8dYnj9/temporal-1.22.5/src/temporal/server.go:69\nmain.buildCLI.func2\n\t/build/temporal-8dYnj9/temporal-1.22.5/src/cmd/server/main.go:189\ngithub.com/urfave/cli/v2.(*Command).Run\n\t/build/temporal-8dYnj9/temporal-1.22.5/src/vendor/github.com/urfave/cli/v2/command.go:163\ngithub.com/urfave/cli/v2.(*App).RunContext\n\t/build/temporal-8dYnj9/temporal-1.22.5/src/vendor/github.com/urfave/cli/v2/app.go:313\ngithub.com/urfave/cli/v2.(*App).Run\n\t/build/temporal-8dYnj9/temporal-1.22.5/src/vendor/github.com/urfave/cli/v2/app.go:224\nmain.main\n\t/build/temporal-8dYnj9/temporal-1.22.5/src/cmd/server/main.go:55\nruntime.main\n\t/usr/lib/go-1.20/src/runtime/proc.go:250"}
Feb 25 19:58:11 region-controller maas-temporal[24288]: {"level":"error","ts":"2025-02-25T19:58:11.261Z","msg":"invoke failed","component":"fx","error":"could not build arguments for function \"go.temporal.io/server/common/deadlock\".glob..func1 (/build/temporal-8dYnj9/temporal-1.22.5/src/common/deadlock/fx.go:35): failed to build *deadlock.deadlockDetector: could not build arguments for function \"go.temporal.io/server/common/deadlock\".NewDeadlockDetector (/build/temporal-8dYnj9/temporal-1.22.5/src/common/deadlock/deadlock.go:82): could not build value group common.Pingable[group=\"deadlockDetectorRoots\"]: could not build arguments for function \"reflect\".makeFuncStub (/usr/lib/go-1.20/src/reflect/asm_amd64.s:28): failed to build shard.Controller: could not build arguments for function \"go.temporal.io/server/service/history/shard\".glob..func1 (/build/temporal-8dYnj9/temporal-1.22.5/src/service/history/shard/fx.go:36): failed to build *shard.ControllerImpl: could not build arguments for function \"go.temporal.io/server/service/history/shard\".ControllerProvider (/build/temporal-8dYnj9/temporal-1.22.5/src/service/history/shard/controller_impl.go:91): failed to build membership.HostInfoProvider: received non-nil error from function \"go.temporal.io/server/common/membership/ringpop\".provideHostInfoProvider (/build/temporal-8dYnj9/temporal-1.22.5/src/common/membership/ringpop/fx.go:55): broadcastAddress required when listening on all interfaces (0.0.0.0/[::])","errorVerbose":"could not build arguments for function \"go.temporal.io/server/common/deadlock\".glob..func1\n\t/build/temporal-8dYnj9/temporal-1.22.5/src/common/deadlock/fx.go:35:\nfailed to build *deadlock.deadlockDetector:\ncould not build arguments for function \"go.temporal.io/server/common/deadlock\".NewDeadlockDetector\n\t/build/temporal-8dYnj9/temporal-1.22.5/src/common/deadlock/deadlock.go:82:\ncould not build value group common.Pingable[group=\"deadlockDetectorRoots\"]:\ncould not build arguments for function \"reflect\".makeFuncStub\n\t/usr/lib/go-1.20/src/reflect/asm_amd64.s:28:\nfailed to build shard.Controller:\ncould not build arguments for function \"go.temporal.io/server/service/history/shard\".glob..func1\n\t/build/temporal-8dYnj9/temporal-1.22.5/src/service/history/shard/fx.go:36:\nfailed to build *shard.ControllerImpl:\ncould not build arguments for function \"go.temporal.io/server/service/history/shard\".ControllerProvider\n\t/build/temporal-8dYnj9/temporal-1.22.5/src/service/history/shard/controller_impl.go:91:\nfailed to build membership.HostInfoProvider:\nreceived non-nil error from function \"go.temporal.io/server/common/membership/ringpop\".provideHostInfoProvider\n\t/build/temporal-8dYnj9/temporal-1.22.5/src/common/membership/ringpop/fx.go:55:\nbroadcastAddress required when listening on all interfaces (0.0.0.0/[::])","stack":"go.temporal.io/server/common/deadlock.init\n\t/build/temporal-8dYnj9/temporal-1.22.5/src/common/deadlock/fx.go:35\nruntime.doInit\n\t/usr/lib/go-1.20/src/runtime/proc.go:6506\nruntime.doInit\n\t/usr/lib/go-1.20/src/runtime/proc.go:6483\nruntime.doInit\n\t/usr/lib/go-1.20/src/runtime/proc.go:6483\nruntime.doInit\n\t/usr/lib/go-1.20/src/runtime/proc.go:6483\nruntime.main\n\t/usr/lib/go-1.20/src/runtime/proc.go:233\n","function":"go.temporal.io/server/common/deadlock.glob..func1()","module":"","logging-call-at":"fx.go:1139","stacktrace":"go.temporal.io/server/common/log.(*zapLogger).Error\n\t/build/temporal-8dYnj9/temporal-1.22.5/src/common/log/zap_logger.go:156\ngo.temporal.io/server/temporal.(*fxLogAdapter).LogEvent\n\t/build/temporal-8dYnj9/temporal-1.22.5/src/temporal/fx.go:1139\ngo.uber.org/fx.(*module).executeInvoke\n\t/build/temporal-8dYnj9/temporal-1.22.5/src/vendor/go.uber.org/fx/module.go:280\ngo.uber.org/fx.(*module).executeInvokes\n\t/build/temporal-8dYnj9/temporal-1.22.5/src/vendor/go.uber.org/fx/module.go:265\ngo.uber.org/fx.New\n\t/build/temporal-8dYnj9/temporal-1.22.5/src/vendor/go.uber.org/fx/app.go:502\ngo.temporal.io/server/temporal.HistoryServiceProvider\n\t/build/temporal-8dYnj9/temporal-1.22.5/src/temporal/fx.go:377\nreflect.Value.call\n\t/usr/lib/go-1.20/src/reflect/value.go:586\nreflect.Value.Call\n\t/usr/lib/go-1.20/src/reflect/value.go:370\ngo.uber.org/dig.defaultInvoker\n\t/build/temporal-8dYnj9/temporal-1.22.5/src/vendor/go.uber.org/dig/container.go:238\ngo.uber.org/dig.(*constructorNode).Call\n\t/build/temporal-8dYnj9/temporal-1.22.5/src/vendor/go.uber.org/dig/constructor.go:180\ngo.uber.org/dig.paramGroupedSlice.callGroupProviders\n\t/build/temporal-8dYnj9/temporal-1.22.5/src/vendor/go.uber.org/dig/param.go:609\ngo.uber.org/dig.paramGroupedSlice.Build\n\t/build/temporal-8dYnj9/temporal-1.22.5/src/vendor/go.uber.org/dig/param.go:639\ngo.uber.org/dig.paramObjectField.Build\n\t/build/temporal-8dYnj9/temporal-1.22.5/src/vendor/go.uber.org/dig/param.go:484\ngo.uber.org/dig.paramObject.Build\n\t/build/temporal-8dYnj9/temporal-1.22.5/src/vendor/go.uber.org/dig/param.go:412\ngo.uber.org/dig.paramList.BuildList\n\t/build/temporal-8dYnj9/temporal-1.22.5/src/vendor/go.uber.org/dig/param.go:150\ngo.uber.org/dig.(*constructorNode).Call\n\t/build/temporal-8dYnj9/temporal-1.22.5/src/vendor/go.uber.org/dig/constructor.go:150\ngo.uber.org/dig.paramSingle.Build\n\t/build/temporal-8dYnj9/temporal-1.22.5/src/vendor/go.uber.org/dig/param.go:287\ngo.uber.org/dig.paramList.BuildList\n\t/build/temporal-8dYnj9/temporal-1.22.5/src/vendor/go.uber.org/dig/param.go:150\ngo.uber.org/dig.(*Scope).Invoke\n\t/build/temporal-8dYnj9/temporal-1.22.5/src/vendor/go.uber.org/dig/invoke.go:122\ngo.uber.org/dig.(*Container).Invoke\n\t/build/temporal-8dYnj9/temporal-1.22.5/src/vendor/go.uber.org/dig/invoke.go:82\ngo.uber.org/fx.runInvoke\n\t/build/temporal-8dYnj9/temporal-1.22.5/src/vendor/go.uber.org/fx/invoke.go:108\ngo.uber.org/fx.(*module).executeInvoke\n\t/build/temporal-8dYnj9/temporal-1.22.5/src/vendor/go.uber.org/fx/module.go:279\ngo.uber.org/fx.(*module).executeInvokes\n\t/build/temporal-8dYnj9/temporal-1.22.5/src/vendor/go.uber.org/fx/module.go:265\ngo.uber.org/fx.New\n\t/build/temporal-8dYnj9/temporal-1.22.5/src/vendor/go.uber.org/fx/app.go:502\ngo.temporal.io/server/temporal.NewServerFx\n\t/build/temporal-8dYnj9/temporal-1.22.5/src/temporal/fx.go:161\ngo.temporal.io/server/temporal.NewServer\n\t/build/temporal-8dYnj9/temporal-1.22.5/src/temporal/server.go:69\nmain.buildCLI.func2\n\t/build/temporal-8dYnj9/temporal-1.22.5/src/cmd/server/main.go:189\ngithub.com/urfave/cli/v2.(*Command).Run\n\t/build/temporal-8dYnj9/temporal-1.22.5/src/vendor/github.com/urfave/cli/v2/command.go:163\ngithub.com/urfave/cli/v2.(*App).RunContext\n\t/build/temporal-8dYnj9/temporal-1.22.5/src/vendor/github.com/urfave/cli/v2/app.go:313\ngithub.com/urfave/cli/v2.(*App).Run\n\t/build/temporal-8dYnj9/temporal-1.22.5/src/vendor/github.com/urfave/cli/v2/app.go:224\nmain.main\n\t/build/temporal-8dYnj9/temporal-1.22.5/src/cmd/server/main.go:55\nruntime.main\n\t/usr/lib/go-1.20/src/runtime/proc.go:250"}
Feb 25 19:58:11 region-controller maas-temporal[24288]: {"level":"error","ts":"2025-02-25T19:58:11.262Z","msg":"error returned","component":"fx","name":"go.temporal.io/server/temporal.HistoryServiceProvider()","kind":"provide","module":"","error":"received non-nil error from function \"go.temporal.io/server/temporal\".HistoryServiceProvider (/build/temporal-8dYnj9/temporal-1.22.5/src/temporal/fx.go:367): could not build arguments for function \"go.temporal.io/server/common/deadlock\".glob..func1 (/build/temporal-8dYnj9/temporal-1.22.5/src/common/deadlock/fx.go:35): failed to build *deadlock.deadlockDetector: could not build arguments for function \"go.temporal.io/server/common/deadlock\".NewDeadlockDetector (/build/temporal-8dYnj9/temporal-1.22.5/src/common/deadlock/deadlock.go:82): could not build value group common.Pingable[group=\"deadlockDetectorRoots\"]: could not build arguments for function \"reflect\".makeFuncStub (/usr/lib/go-1.20/src/reflect/asm_amd64.s:28): failed to build shard.Controller: could not build arguments for function \"go.temporal.io/server/service/history/shard\".glob..func1 (/build/temporal-8dYnj9/temporal-1.22.5/src/service/history/shard/fx.go:36): failed to build *shard.ControllerImpl: could not build arguments for function \"go.temporal.io/server/service/history/shard\".ControllerProvider (/build/temporal-8dYnj9/temporal-1.22.5/src/service/history/shard/controller_impl.go:91): failed to build membership.HostInfoProvider: received non-nil error from function \"go.temporal.io/server/common/membership/ringpop\".provideHostInfoProvider (/build/temporal-8dYnj9/temporal-1.22.5/src/common/membership/ringpop/fx.go:55): broadcastAddress required when listening on all interfaces (0.0.0.0/[::])","errorVerbose":"received non-nil error from function \"go.temporal.io/server/temporal\".HistoryServiceProvider\n\t/build/temporal-8dYnj9/temporal-1.22.5/src/temporal/fx.go:367:\ncould not build arguments for function \"go.temporal.io/server/common/deadlock\".glob..func1\n\t/build/temporal-8dYnj9/temporal-1.22.5/src/common/deadlock/fx.go:35:\nfailed to build *deadlock.deadlockDetector:\ncould not build arguments for function \"go.temporal.io/server/common/deadlock\".NewDeadlockDetector\n\t/build/temporal-8dYnj9/temporal-1.22.5/src/common/deadlock/deadlock.go:82:\ncould not build value group common.Pingable[group=\"deadlockDetectorRoots\"]:\ncould not build arguments for function \"reflect\".makeFuncStub\n\t/usr/lib/go-1.20/src/reflect/asm_amd64.s:28:\nfailed to build shard.Controller:\ncould not build arguments for function \"go.temporal.io/server/service/history/shard\".glob..func1\n\t/build/temporal-8dYnj9/temporal-1.22.5/src/service/history/shard/fx.go:36:\nfailed to build *shard.ControllerImpl:\ncould not build arguments for function \"go.temporal.io/server/service/history/shard\".ControllerProvider\n\t/build/temporal-8dYnj9/temporal-1.22.5/src/service/history/shard/controller_impl.go:91:\nfailed to build membership.HostInfoProvider:\nreceived non-nil error from function \"go.temporal.io/server/common/membership/ringpop\".provideHostInfoProvider\n\t/build/temporal-8dYnj9/temporal-1.22.5/src/common/membership/ringpop/fx.go:55:\nbroadcastAddress required when listening on all interfaces (0.0.0.0/[::])","logging-call-at":"fx.go:1122","stacktrace":"go.temporal.io/server/common/log.(*zapLogger).Error\n\t/build/temporal-8dYnj9/temporal-1.22.5/src/common/log/zap_logger.go:156\ngo.temporal.io/server/temporal.(*fxLogAdapter).LogEvent\n\t/build/temporal-8dYnj9/temporal-1.22.5/src/temporal/fx.go:1122\ngo.uber.org/fx.(*module).provide.func1\n\t/build/temporal-8dYnj9/temporal-1.22.5/src/vendor/go.uber.org/fx/module.go:160\ngo.uber.org/dig.(*constructorNode).Call.func1\n\t/build/temporal-8dYnj9/temporal-1.22.5/src/vendor/go.uber.org/dig/constructor.go:161\ngo.uber.org/dig.(*constructorNode).Call\n\t/build/temporal-8dYnj9/temporal-1.22.5/src/vendor/go.uber.org/dig/constructor.go:182\ngo.uber.org/dig.paramGroupedSlice.callGroupProviders\n\t/build/temporal-8dYnj9/temporal-1.22.5/src/vendor/go.uber.org/dig/param.go:609\ngo.uber.org/dig.paramGroupedSlice.Build\n\t/build/temporal-8dYnj9/temporal-1.22.5/src/vendor/go.uber.org/dig/param.go:639\ngo.uber.org/dig.paramObjectField.Build\n\t/build/temporal-8dYnj9/temporal-1.22.5/src/vendor/go.uber.org/dig/param.go:484\ngo.uber.org/dig.paramObject.Build\n\t/build/temporal-8dYnj9/temporal-1.22.5/src/vendor/go.uber.org/dig/param.go:412\ngo.uber.org/dig.paramList.BuildList\n\t/build/temporal-8dYnj9/temporal-1.22.5/src/vendor/go.uber.org/dig/param.go:150\ngo.uber.org/dig.(*constructorNode).Call\n\t/build/temporal-8dYnj9/temporal-1.22.5/src/vendor/go.uber.org/dig/constructor.go:150\ngo.uber.org/dig.paramSingle.Build\n\t/build/temporal-8dYnj9/temporal-1.22.5/src/vendor/go.uber.org/dig/param.go:287\ngo.uber.org/dig.paramList.BuildList\n\t/build/temporal-8dYnj9/temporal-1.22.5/src/vendor/go.uber.org/dig/param.go:150\ngo.uber.org/dig.(*Scope).Invoke\n\t/build/temporal-8dYnj9/temporal-1.22.5/src/vendor/go.uber.org/dig/invoke.go:122\ngo.uber.org/dig.(*Container).Invoke\n\t/build/temporal-8dYnj9/temporal-1.22.5/src/vendor/go.uber.org/dig/invoke.go:82\ngo.uber.org/fx.runInvoke\n\t/build/temporal-8dYnj9/temporal-1.22.5/src/vendor/go.uber.org/fx/invoke.go:108\ngo.uber.org/fx.(*module).executeInvoke\n\t/build/temporal-8dYnj9/temporal-1.22.5/src/vendor/go.uber.org/fx/module.go:279\ngo.uber.org/fx.(*module).executeInvokes\n\t/build/temporal-8dYnj9/temporal-1.22.5/src/vendor/go.uber.org/fx/module.go:265\ngo.uber.org/fx.New\n\t/build/temporal-8dYnj9/temporal-1.22.5/src/vendor/go.uber.org/fx/app.go:502\ngo.temporal.io/server/temporal.NewServerFx\n\t/build/temporal-8dYnj9/temporal-1.22.5/src/temporal/fx.go:161\ngo.temporal.io/server/temporal.NewServer\n\t/build/temporal-8dYnj9/temporal-1.22.5/src/temporal/server.go:69\nmain.buildCLI.func2\n\t/build/temporal-8dYnj9/temporal-1.22.5/src/cmd/server/main.go:189\ngithub.com/urfave/cli/v2.(*Command).Run\n\t/build/temporal-8dYnj9/temporal-1.22.5/src/vendor/github.com/urfave/cli/v2/command.go:163\ngithub.com/urfave/cli/v2.(*App).RunContext\n\t/build/temporal-8dYnj9/temporal-1.22.5/src/vendor/github.com/urfave/cli/v2/app.go:313\ngithub.com/urfave/cli/v2.(*App).Run\n\t/build/temporal-8dYnj9/temporal-1.22.5/src/vendor/github.com/urfave/cli/v2/app.go:224\nmain.main\n\t/build/temporal-8dYnj9/temporal-1.22.5/src/cmd/server/main.go:55\nruntime.main\n\t/usr/lib/go-1.20/src/runtime/proc.go:250"}
Feb 25 19:58:11 region-controller maas-temporal[24288]: {"level":"error","ts":"2025-02-25T19:58:11.262Z","msg":"invoke failed","component":"fx","error":"could not build arguments for function \"go.temporal.io/server/temporal\".ServerLifetimeHooks (/build/temporal-8dYnj9/temporal-1.22.5/src/temporal/fx.go:881): failed to build *temporal.ServerImpl: could not build arguments for function \"go.temporal.io/server/temporal\".NewServerFxImpl (/build/temporal-8dYnj9/temporal-1.22.5/src/temporal/server_impl.go:64): could not build value group *temporal.ServicesMetadata[group=\"services\"]: received non-nil error from function \"go.temporal.io/server/temporal\".HistoryServiceProvider (/build/temporal-8dYnj9/temporal-1.22.5/src/temporal/fx.go:367): could not build arguments for function \"go.temporal.io/server/common/deadlock\".glob..func1 (/build/temporal-8dYnj9/temporal-1.22.5/src/common/deadlock/fx.go:35): failed to build *deadlock.deadlockDetector: could not build arguments for function \"go.temporal.io/server/common/deadlock\".NewDeadlockDetector (/build/temporal-8dYnj9/temporal-1.22.5/src/common/deadlock/deadlock.go:82): could not build value group common.Pingable[group=\"deadlockDetectorRoots\"]: could not build arguments for function \"reflect\".makeFuncStub (/usr/lib/go-1.20/src/reflect/asm_amd64.s:28): failed to build shard.Controller: could not build arguments for function \"go.temporal.io/server/service/history/shard\".glob..func1 (/build/temporal-8dYnj9/temporal-1.22.5/src/service/history/shard/fx.go:36): failed to build *shard.ControllerImpl: could not build arguments for function \"go.temporal.io/server/service/history/shard\".ControllerProvider (/build/temporal-8dYnj9/temporal-1.22.5/src/service/history/shard/controller_impl.go:91): failed to build membership.HostInfoProvider: received non-nil error from function \"go.temporal.io/server/common/membership/ringpop\".provideHostInfoProvider (/build/temporal-8dYnj9/temporal-1.22.5/src/common/membership/ringpop/fx.go:55): broadcastAddress required when listening on all interfaces (0.0.0.0/[::])","errorVerbose":"could not build arguments for function \"go.temporal.io/server/temporal\".ServerLifetimeHooks\n\t/build/temporal-8dYnj9/temporal-1.22.5/src/temporal/fx.go:881:\nfailed to build *temporal.ServerImpl:\ncould not build arguments for function \"go.temporal.io/server/temporal\".NewServerFxImpl\n\t/build/temporal-8dYnj9/temporal-1.22.5/src/temporal/server_impl.go:64:\ncould not build value group *temporal.ServicesMetadata[group=\"services\"]:\nreceived non-nil error from function \"go.temporal.io/server/temporal\".HistoryServiceProvider\n\t/build/temporal-8dYnj9/temporal-1.22.5/src/temporal/fx.go:367:\ncould not build arguments for function \"go.temporal.io/server/common/deadlock\".glob..func1\n\t/build/temporal-8dYnj9/temporal-1.22.5/src/common/deadlock/fx.go:35:\nfailed to build *deadlock.deadlockDetector:\ncould not build arguments for function \"go.temporal.io/server/common/deadlock\".NewDeadlockDetector\n\t/build/temporal-8dYnj9/temporal-1.22.5/src/common/deadlock/deadlock.go:82:\ncould not build value group common.Pingable[group=\"deadlockDetectorRoots\"]:\ncould not build arguments for function \"reflect\".makeFuncStub\n\t/usr/lib/go-1.20/src/reflect/asm_amd64.s:28:\nfailed to build shard.Controller:\ncould not build arguments for function \"go.temporal.io/server/service/history/shard\".glob..func1\n\t/build/temporal-8dYnj9/temporal-1.22.5/src/service/history/shard/fx.go:36:\nfailed to build *shard.ControllerImpl:\ncould not build arguments for function \"go.temporal.io/server/service/history/shard\".ControllerProvider\n\t/build/temporal-8dYnj9/temporal-1.22.5/src/service/history/shard/controller_impl.go:91:\nfailed to build membership.HostInfoProvider:\nreceived non-nil error from function \"go.temporal.io/server/common/membership/ringpop\".provideHostInfoProvider\n\t/build/temporal-8dYnj9/temporal-1.22.5/src/common/membership/ringpop/fx.go:55:\nbroadcastAddress required when listening on all interfaces (0.0.0.0/[::])","stack":"go.temporal.io/server/temporal.init\n\t/build/temporal-8dYnj9/temporal-1.22.5/src/temporal/fx.go:154\nruntime.doInit\n\t/usr/lib/go-1.20/src/runtime/proc.go:6506\nruntime.doInit\n\t/usr/lib/go-1.20/src/runtime/proc.go:6483\nruntime.main\n\t/usr/lib/go-1.20/src/runtime/proc.go:233\n","function":"go.temporal.io/server/temporal.ServerLifetimeHooks()","module":"","logging-call-at":"fx.go:1139","stacktrace":"go.temporal.io/server/common/log.(*zapLogger).Error\n\t/build/temporal-8dYnj9/temporal-1.22.5/src/common/log/zap_logger.go:156\ngo.temporal.io/server/temporal.(*fxLogAdapter).LogEvent\n\t/build/temporal-8dYnj9/temporal-1.22.5/src/temporal/fx.go:1139\ngo.uber.org/fx.(*module).executeInvoke\n\t/build/temporal-8dYnj9/temporal-1.22.5/src/vendor/go.uber.org/fx/module.go:280\ngo.uber.org/fx.(*module).executeInvokes\n\t/build/temporal-8dYnj9/temporal-1.22.5/src/vendor/go.uber.org/fx/module.go:265\ngo.uber.org/fx.New\n\t/build/temporal-8dYnj9/temporal-1.22.5/src/vendor/go.uber.org/fx/app.go:502\ngo.temporal.io/server/temporal.NewServerFx\n\t/build/temporal-8dYnj9/temporal-1.22.5/src/temporal/fx.go:161\ngo.temporal.io/server/temporal.NewServer\n\t/build/temporal-8dYnj9/temporal-1.22.5/src/temporal/server.go:69\nmain.buildCLI.func2\n\t/build/temporal-8dYnj9/temporal-1.22.5/src/cmd/server/main.go:189\ngithub.com/urfave/cli/v2.(*Command).Run\n\t/build/temporal-8dYnj9/temporal-1.22.5/src/vendor/github.com/urfave/cli/v2/command.go:163\ngithub.com/urfave/cli/v2.(*App).RunContext\n\t/build/temporal-8dYnj9/temporal-1.22.5/src/vendor/github.com/urfave/cli/v2/app.go:313\ngithub.com/urfave/cli/v2.(*App).Run\n\t/build/temporal-8dYnj9/temporal-1.22.5/src/vendor/github.com/urfave/cli/v2/app.go:224\nmain.main\n\t/build/temporal-8dYnj9/temporal-1.22.5/src/cmd/server/main.go:55\nruntime.main\n\t/usr/lib/go-1.20/src/runtime/proc.go:250"}
Feb 25 19:58:11 region-controller maas-temporal[24288]: Unable to create server. Error: could not build arguments for function "go.temporal.io/server/temporal".ServerLifetimeHooks (/build/temporal-8dYnj9/temporal-1.22.5/src/temporal/fx.go:881): failed to build *temporal.ServerImpl: could not build arguments for function "go.temporal.io/server/temporal".NewServerFxImpl (/build/temporal-8dYnj9/temporal-1.22.5/src/temporal/server_impl.go:64): could not build value group *temporal.ServicesMetadata[group="services"]: received non-nil error from function "go.temporal.io/server/temporal".HistoryServiceProvider (/build/temporal-8dYnj9/temporal-1.22.5/src/temporal/fx.go:367): could not build arguments for function "go.temporal.io/server/common/deadlock".glob..func1 (/build/temporal-8dYnj9/temporal-1.22.5/src/common/deadlock/fx.go:35): failed to build *deadlock.deadlockDetector: could not build arguments for function "go.temporal.io/server/common/deadlock".NewDeadlockDetector (/build/temporal-8dYnj9/temporal-1.22.5/src/common/deadlock/deadlock.go:82): could not build value group common.Pingable[group="deadlockDetectorRoots"]: could not build arguments for function "reflect".makeFuncStub (/usr/lib/go-1.20/src/reflect/asm_amd64.s:28): failed to build shard.Controller: could not build arguments for function "go.temporal.io/server/service/history/shard".glob..func1 (/build/temporal-8dYnj9/temporal-1.22.5/src/service/history/shard/fx.go:36): failed to build *shard.ControllerImpl: could not build arguments for function "go.temporal.io/server/service/history/shard".ControllerProvider (/build/temporal-8dYnj9/temporal-1.22.5/src/service/history/shard/controller_impl.go:91): failed to build membership.HostInfoProvider: received non-nil error from function "go.temporal.io/server/common/membership/ringpop".provideHostInfoProvider (/build/temporal-8dYnj9/temporal-1.22.5/src/common/membership/ringpop/fx.go:55): broadcastAddress required when listening on all interfaces (0.0.0.0/[::]).
Feb 25 19:58:11 region-controller maas.pebble[3563]: 2025-02-25T19:58:11.272Z [pebble] Change 76 task (Start service "temporal") failed: cannot start service: exited quickly with code 1
Feb 25 19:58:12 region-controller maas-log[4197]: maas.service_monitor: [error] Service 'temporal' failed to start: Pebble change 76 failed with an error: cannot perform the following tasks:#012- Start service "temporal" (cannot start service: exited quickly with code 1)
Feb 25 19:58:13 region-controller maas-log[4197]: maas.neighbour: [info] enp65s0 (physical) on region-controller: IP address 10.228.21.168 moved from c0:18:50:cb:18:f0 to c0:18:50:cb:18:ef
Feb 25 19:58:16 region-controller maas-temporal-worker[24028]: Task exception was never retrieved
Feb 25 19:58:16 region-controller maas-temporal-worker[24028]: future: <Task finished name='Task-2' coro=<Worker.run() done, defined at /snap/maas/38185/lib/python3.10/site-packages/maasserver/workflow/worker/worker.py:99> exception=RuntimeError('Failed client connect: Server connection error: tonic::transport::Error(Transport, hyper::Error(Connect, ConnectError("tcp connect error", Os { code: 111, kind: ConnectionRefused, message: "Connection refused" })))')>
Feb 25 19:58:16 region-controller maas-temporal-worker[24028]: Traceback (most recent call last):
Feb 25 19:58:16 region-controller maas-temporal-worker[24028]:   File "/snap/maas/38185/lib/python3.10/site-packages/maasserver/workflow/worker/worker.py", line 100, in run
Feb 25 19:58:16 region-controller maas-temporal-worker[24028]:     self._client = self._client or await get_client_async()
Feb 25 19:58:16 region-controller maas-temporal-worker[24028]:   File "/snap/maas/38185/lib/python3.10/site-packages/maasserver/utils/asynchronous.py", line 263, in wrapped
Feb 25 19:58:16 region-controller maas-temporal-worker[24028]:     raise e
Feb 25 19:58:16 region-controller maas-temporal-worker[24028]:   File "/snap/maas/38185/lib/python3.10/site-packages/maasserver/utils/asynchronous.py", line 259, in wrapped
Feb 25 19:58:16 region-controller maas-temporal-worker[24028]:     return await fn(*args, **kwargs)
Feb 25 19:58:16 region-controller maas-temporal-worker[24028]:   File "/snap/maas/38185/lib/python3.10/site-packages/maasserver/workflow/worker/worker.py", line 45, in get_client_async
Feb 25 19:58:16 region-controller maas-temporal-worker[24028]:     return await Client.connect(
Feb 25 19:58:16 region-controller maas-temporal-worker[24028]:   File "/snap/maas/38185/usr/lib/python3/dist-packages/temporalio/client.py", line 148, in connect
Feb 25 19:58:16 region-controller maas-temporal-worker[24028]:     await temporalio.service.ServiceClient.connect(connect_config),
Feb 25 19:58:16 region-controller maas-temporal-worker[24028]:   File "/snap/maas/38185/usr/lib/python3/dist-packages/temporalio/service.py", line 158, in connect
Feb 25 19:58:16 region-controller maas-temporal-worker[24028]:     return await _BridgeServiceClient.connect(config)
Feb 25 19:58:16 region-controller maas-temporal-worker[24028]:   File "/snap/maas/38185/usr/lib/python3/dist-packages/temporalio/service.py", line 685, in connect
Feb 25 19:58:16 region-controller maas-temporal-worker[24028]:     await client._connected_client()
Feb 25 19:58:16 region-controller maas-temporal-worker[24028]:   File "/snap/maas/38185/usr/lib/python3/dist-packages/temporalio/service.py", line 698, in _connected_client
Feb 25 19:58:16 region-controller maas-temporal-worker[24028]:     self._bridge_client = await temporalio.bridge.client.Client.connect(
Feb 25 19:58:16 region-controller maas-temporal-worker[24028]:   File "/snap/maas/38185/usr/lib/python3/dist-packages/temporalio/bridge/client.py", line 78, in connect
Feb 25 19:58:16 region-controller maas-temporal-worker[24028]:     await temporalio.bridge.temporal_sdk_bridge.connect_client(
Feb 25 19:58:16 region-controller maas-temporal-worker[24028]: RuntimeError: Failed client connect: Server connection error: tonic::transport::Error(Transport, hyper::Error(Connect, ConnectError("tcp connect error", Os { code: 111, kind: ConnectionRefused, message: "Connection refused" })))
Feb 25 19:58:16 region-controller maas.pebble[3563]: 2025-02-25T19:58:16.571Z [pebble] Service "temporal-worker" stopped unexpectedly with code 0
Feb 25 19:58:16 region-controller maas.pebble[3563]: 2025-02-25T19:58:16.571Z [pebble] Service "temporal-worker" on-success action is "restart", waiting ~500ms before restart (backoff 1)
Feb 25 19:58:16 region-controller maas-log[4197]: maas.neighbour: [info] enp65s0 (physical) on region-controller: IP address 10.228.21.168 moved from c0:18:50:cb:18:ef to c0:18:50:cb:18:f0
Feb 25 19:58:17 region-controller maas.pebble[3563]: 2025-02-25T19:58:17.100Z [pebble] Service "temporal-worker" starting: sh -c "exec systemd-cat -t maas-temporal-worker $SNAP/bin/run-temporal-worker"
Feb 25 19:58:19 region-controller maas-log[4197]: maas.neighbour: [info] enp65s0 (physical) on region-controller: IP address 10.228.21.168 moved from c0:18:50:cb:18:f0 to c0:18:50:cb:18:ef
Feb 25 19:58:21 region-controller maas-log[4197]: maas.neighbour: [info] enp65s0 (physical) on region-controller: IP address 0.0.0.0 moved from 00:00:1a:1f:1f:34 to cc:28:aa:a6:8e:08
Feb 25 19:58:23 region-controller maas-log[4197]: maas.neighbour: [info] enp65s0 (physical) on region-controller: IP address 10.228.21.168 moved from c0:18:50:cb:18:ef to c0:18:50:cb:18:f0
Feb 25 19:58:26 region-controller maas-log[4197]: maas.neighbour: [info] enp65s0 (physical) on region-controller: IP address 10.228.21.168 moved from c0:18:50:cb:18:f0 to c0:18:50:cb:18:ef
Feb 25 19:58:29 region-controller maas-log[4197]: maas.neighbour: [info] enp65s0 (physical) on region-controller: IP address 10.228.21.168 moved from c0:18:50:cb:18:ef to c0:18:50:cb:18:f0
Feb 25 19:58:32 region-controller maas-log[4197]: maas.neighbour: [info] enp65s0 (physical) on region-controller: IP address 10.228.21.168 moved from c0:18:50:cb:18:f0 to c0:18:50:cb:18:ef
Feb 25 19:58:35 region-controller maas-log[4197]: maas.neighbour: [info] enp65s0 (physical) on region-controller: IP address 10.228.21.168 moved from c0:18:50:cb:18:ef to c0:18:50:cb:18:f0
Feb 25 19:58:38 region-controller maas-log[4197]: maas.neighbour: [info] enp65s0 (physical) on region-controller: IP address 10.228.21.168 moved from c0:18:50:cb:18:f0 to c0:18:50:cb:18:ef
Feb 25 19:58:41 region-controller maas.pebble[3563]: 2025-02-25T19:58:41.139Z [pebble] GET /v1/services?names=bind9 118.365µs 200
Feb 25 19:58:41 region-controller maas.pebble[3563]: 2025-02-25T19:58:41.139Z [pebble] GET /v1/services?names=ntp 96.834µs 200
Feb 25 19:58:41 region-controller maas.pebble[3563]: 2025-02-25T19:58:41.140Z [pebble] GET /v1/services?names=syslog 52.48µs 200
Feb 25 19:58:41 region-controller maas.pebble[3563]: 2025-02-25T19:58:41.140Z [pebble] GET /v1/services?names=http 46.899µs 200
Feb 25 19:58:41 region-controller maas.pebble[3563]: 2025-02-25T19:58:41.140Z [pebble] GET /v1/services?names=temporal-worker 34.235µs 200
Feb 25 19:58:41 region-controller maas.pebble[3563]: 2025-02-25T19:58:41.140Z [pebble] GET /v1/services?names=temporal 172.618µs 200
Feb 25 19:58:41 region-controller maas-log[4197]: maas.service_monitor: [info] Service 'maas-temporal' is not on, it will be started.
Feb 25 19:58:41 region-controller maas.pebble[3563]: 2025-02-25T19:58:41.158Z [pebble] POST /v1/services 10.259292ms 202
Feb 25 19:58:41 region-controller maas.pebble[3563]: 2025-02-25T19:58:41.165Z [pebble] GET /v1/services?names=proxy 13.208279ms 200
Feb 25 19:58:41 region-controller maas.pebble[3563]: 2025-02-25T19:58:41.165Z [pebble] Service "temporal" starting: sh -c "exec systemd-cat -t maas-temporal $SNAP/bin/run-temporal"
Feb 25 19:58:41 region-controller maas-temporal[24701]: 2025/02/25 19:58:41 Loading config; env=production,zone=,configDir=/var/snap/maas/38185/temporal
Feb 25 19:58:41 region-controller maas-temporal[24701]: 2025/02/25 19:58:41 Loading config files=[/var/snap/maas/38185/temporal/production.yaml]
Feb 25 19:58:41 region-controller maas-temporal[24701]: {"level":"error","ts":"2025-02-25T19:58:41.272Z","msg":"error returned","component":"fx","name":"go.temporal.io/server/common/membership/ringpop.provideHostInfoProvider()","kind":"provide","module":"","error":"received non-nil error from function \"go.temporal.io/server/common/membership/ringpop\".provideHostInfoProvider (/build/temporal-8dYnj9/temporal-1.22.5/src/common/membership/ringpop/fx.go:55): broadcastAddress required when listening on all interfaces (0.0.0.0/[::])","errorVerbose":"received non-nil error from function \"go.temporal.io/server/common/membership/ringpop\".provideHostInfoProvider\n\t/build/temporal-8dYnj9/temporal-1.22.5/src/common/membership/ringpop/fx.go:55:\nbroadcastAddress required when listening on all interfaces (0.0.0.0/[::])","logging-call-at":"fx.go:1122","stacktrace":"go.temporal.io/server/common/log.(*zapLogger).Error\n\t/build/temporal-8dYnj9/temporal-1.22.5/src/common/log/zap_logger.go:156\ngo.temporal.io/server/temporal.(*fxLogAdapter).LogEvent\n\t/build/temporal-8dYnj9/temporal-1.22.5/src/temporal/fx.go:1122\ngo.uber.org/fx.(*module).provide.func1\n\t/build/temporal-8dYnj9/temporal-1.22.5/src/vendor/go.uber.org/fx/module.go:160\ngo.uber.org/dig.(*constructorNode).Call.func1\n\t/build/temporal-8dYnj9/temporal-1.22.5/src/vendor/go.uber.org/dig/constructor.go:161\ngo.uber.org/dig.(*constructorNode).Call\n\t/build/temporal-8dYnj9/temporal-1.22.5/src/vendor/go.uber.org/dig/constructor.go:182\ngo.uber.org/dig.paramSingle.Build\n\t/build/temporal-8dYnj9/temporal-1.22.5/src/vendor/go.uber.org/dig/param.go:287\ngo.uber.org/dig.paramList.BuildList\n\t/build/temporal-8dYnj9/temporal-1.22.5/src/vendor/go.uber.org/dig/param.go:150\ngo.uber.org/dig.(*constructorNode).Call\n\t/build/temporal-8dYnj9/temporal-1.22.5/src/vendor/go.uber.org/dig/constructor.go:150\ngo.uber.org/dig.paramSingle.Build\n\t/build/temporal-8dYnj9/temporal-1.22.5/src/vendor/go.uber.org/dig/param.go:287\ngo.uber.org/dig.paramList.BuildList\n\t/build/temporal-8dYnj9/temporal-1.22.5/src/vendor/go.uber.org/dig/param.go:150\ngo.uber.org/dig.(*constructorNode).Call\n\t/build/temporal-8dYnj9/temporal-1.22.5/src/vendor/go.uber.org/dig/constructor.go:150\ngo.uber.org/dig.paramSingle.Build\n\t/build/temporal-8dYnj9/temporal-1.22.5/src/vendor/go.uber.org/dig/param.go:287\ngo.uber.org/dig.paramList.BuildList\n\t/build/temporal-8dYnj9/temporal-1.22.5/src/vendor/go.uber.org/dig/param.go:150\ngo.uber.org/dig.(*constructorNode).Call\n\t/build/temporal-8dYnj9/temporal-1.22.5/src/vendor/go.uber.org/dig/constructor.go:150\ngo.uber.org/dig.paramGroupedSlice.callGroupProviders\n\t/build/temporal-8dYnj9/temporal-1.22.5/src/vendor/go.uber.org/dig/param.go:609\ngo.uber.org/dig.paramGroupedSlice.Build\n\t/build/temporal-8dYnj9/temporal-1.22.5/src/vendor/go.uber.org/dig/param.go:639\ngo.uber.org/dig.paramObjectField.Build\n\t/build/temporal-8dYnj9/temporal-1.22.5/src/vendor/go.uber.org/dig/param.go:484\ngo.uber.org/dig.paramObject.Build\n\t/build/temporal-8dYnj9/temporal-1.22.5/src/vendor/go.uber.org/dig/param.go:412\ngo.uber.org/dig.paramList.BuildList\n\t/build/temporal-8dYnj9/temporal-1.22.5/src/vendor/go.uber.org/dig/param.go:150\ngo.uber.org/dig.(*constructorNode).Call\n\t/build/temporal-8dYnj9/temporal-1.22.5/src/vendor/go.uber.org/dig/constructor.go:150\ngo.uber.org/dig.paramSingle.Build\n\t/build/temporal-8dYnj9/temporal-1.22.5/src/vendor/go.uber.org/dig/param.go:287\ngo.uber.org/dig.paramList.BuildList\n\t/build/temporal-8dYnj9/temporal-1.22.5/src/vendor/go.uber.org/dig/param.go:150\ngo.uber.org/dig.(*Scope).Invoke\n\t/build/temporal-8dYnj9/temporal-1.22.5/src/vendor/go.uber.org/dig/invoke.go:122\ngo.uber.org/dig.(*Container).Invoke\n\t/build/temporal-8dYnj9/temporal-1.22.5/src/vendor/go.uber.org/dig/invoke.go:82\ngo.uber.org/fx.runInvoke\n\t/build/temporal-8dYnj9/temporal-1.22.5/src/vendor/go.uber.org/fx/invoke.go:108\ngo.uber.org/fx.(*module).executeInvoke\n\t/build/temporal-8dYnj9/temporal-1.22.5/src/vendor/go.uber.org/fx/module.go:279\ngo.uber.org/fx.(*module).executeInvokes\n\t/build/temporal-8dYnj9/temporal-1.22.5/src/vendor/go.uber.org/fx/module.go:265\ngo.uber.org/fx.New\n\t/build/temporal-8dYnj9/temporal-1.22.5/src/vendor/go.uber.org/fx/app.go:502\ngo.temporal.io/server/temporal.HistoryServiceProvider\n\t/build/temporal-8dYnj9/temporal-1.22.5/src/temporal/fx.go:377\nreflect.Value.call\n\t/usr/lib/go-1.20/src/reflect/value.go:586\nreflect.Value.Call\n\t/usr/lib/go-1.20/src/reflect/value.go:370\ngo.uber.org/dig.defaultInvoker\n\t/build/temporal-8dYnj9/temporal-1.22.5/src/vendor/go.uber.org/dig/container.go:238\ngo.uber.org/dig.(*constructorNode).Call\n\t/build/temporal-8dYnj9/temporal-1.22.5/src/vendor/go.uber.org/dig/constructor.go:180\ngo.uber.org/dig.paramGroupedSlice.callGroupProviders\n\t/build/temporal-8dYnj9/temporal-1.22.5/src/vendor/go.uber.org/dig/param.go:609\ngo.uber.org/dig.paramGroupedSlice.Build\n\t/build/temporal-8dYnj9/temporal-1.22.5/src/vendor/go.uber.org/dig/param.go:639\ngo.uber.org/dig.paramObjectField.Build\n\t/build/temporal-8dYnj9/temporal-1.22.5/src/vendor/go.uber.org/dig/param.go:484\ngo.uber.org/dig.paramObject.Build\n\t/build/temporal-8dYnj9/temporal-1.22.5/src/vendor/go.uber.org/dig/param.go:412\ngo.uber.org/dig.paramList.BuildList\n\t/build/temporal-8dYnj9/temporal-1.22.5/src/vendor/go.uber.org/dig/param.go:150\ngo.uber.org/dig.(*constructorNode).Call\n\t/build/temporal-8dYnj9/temporal-1.22.5/src/vendor/go.uber.org/dig/constructor.go:150\ngo.uber.org/dig.paramSingle.Build\n\t/build/temporal-8dYnj9/temporal-1.22.5/src/vendor/go.uber.org/dig/param.go:287\ngo.uber.org/dig.paramList.BuildList\n\t/build/temporal-8dYnj9/temporal-1.22.5/src/vendor/go.uber.org/dig/param.go:150\ngo.uber.org/dig.(*Scope).Invoke\n\t/build/temporal-8dYnj9/temporal-1.22.5/src/vendor/go.uber.org/dig/invoke.go:122\ngo.uber.org/dig.(*Container).Invoke\n\t/build/temporal-8dYnj9/temporal-1.22.5/src/vendor/go.uber.org/dig/invoke.go:82\ngo.uber.org/fx.runInvoke\n\t/build/temporal-8dYnj9/temporal-1.22.5/src/vendor/go.uber.org/fx/invoke.go:108\ngo.uber.org/fx.(*module).executeInvoke\n\t/build/temporal-8dYnj9/temporal-1.22.5/src/vendor/go.uber.org/fx/module.go:279\ngo.uber.org/fx.(*module).executeInvokes\n\t/build/temporal-8dYnj9/temporal-1.22.5/src/vendor/go.uber.org/fx/module.go:265\ngo.uber.org/fx.New\n\t/build/temporal-8dYnj9/temporal-1.22.5/src/vendor/go.uber.org/fx/app.go:502\ngo.temporal.io/server/temporal.NewServerFx\n\t/build/temporal-8dYnj9/temporal-1.22.5/src/temporal/fx.go:161\ngo.temporal.io/server/temporal.NewServer\n\t/build/temporal-8dYnj9/temporal-1.22.5/src/temporal/server.go:69\nmain.buildCLI.func2\n\t/build/temporal-8dYnj9/temporal-1.22.5/src/cmd/server/main.go:189\ngithub.com/urfave/cli/v2.(*Command).Run\n\t/build/temporal-8dYnj9/temporal-1.22.5/src/vendor/github.com/urfave/cli/v2/command.go:163\ngithub.com/urfave/cli/v2.(*App).RunContext\n\t/build/temporal-8dYnj9/temporal-1.22.5/src/vendor/github.com/urfave/cli/v2/app.go:313\ngithub.com/urfave/cli/v2.(*App).Run\n\t/build/temporal-8dYnj9/temporal-1.22.5/src/vendor/github.com/urfave/cli/v2/app.go:224\nmain.main\n\t/build/temporal-8dYnj9/temporal-1.22.5/src/cmd/server/main.go:55\nruntime.main\n\t/usr/lib/go-1.20/src/runtime/proc.go:250"}
Feb 25 19:58:41 region-controller maas-temporal[24701]: {"level":"error","ts":"2025-02-25T19:58:41.273Z","msg":"invoke failed","component":"fx","error":"could not build arguments for function \"go.temporal.io/server/common/deadlock\".glob..func1 (/build/temporal-8dYnj9/temporal-1.22.5/src/common/deadlock/fx.go:35): failed to build *deadlock.deadlockDetector: could not build arguments for function \"go.temporal.io/server/common/deadlock\".NewDeadlockDetector (/build/temporal-8dYnj9/temporal-1.22.5/src/common/deadlock/deadlock.go:82): could not build value group common.Pingable[group=\"deadlockDetectorRoots\"]: could not build arguments for function \"reflect\".makeFuncStub (/usr/lib/go-1.20/src/reflect/asm_amd64.s:28): failed to build shard.Controller: could not build arguments for function \"go.temporal.io/server/service/history/shard\".glob..func1 (/build/temporal-8dYnj9/temporal-1.22.5/src/service/history/shard/fx.go:36): failed to build *shard.ControllerImpl: could not build arguments for function \"go.temporal.io/server/service/history/shard\".ControllerProvider (/build/temporal-8dYnj9/temporal-1.22.5/src/service/history/shard/controller_impl.go:91): failed to build membership.HostInfoProvider: received non-nil error from function \"go.temporal.io/server/common/membership/ringpop\".provideHostInfoProvider (/build/temporal-8dYnj9/temporal-1.22.5/src/common/membership/ringpop/fx.go:55): broadcastAddress required when listening on all interfaces (0.0.0.0/[::])","errorVerbose":"could not build arguments for function \"go.temporal.io/server/common/deadlock\".glob..func1\n\t/build/temporal-8dYnj9/temporal-1.22.5/src/common/deadlock/fx.go:35:\nfailed to build *deadlock.deadlockDetector:\ncould not build arguments for function \"go.temporal.io/server/common/deadlock\".NewDeadlockDetector\n\t/build/temporal-8dYnj9/temporal-1.22.5/src/common/deadlock/deadlock.go:82:\ncould not build value group common.Pingable[group=\"deadlockDetectorRoots\"]:\ncould not build arguments for function \"reflect\".makeFuncStub\n\t/usr/lib/go-1.20/src/reflect/asm_amd64.s:28:\nfailed to build shard.Controller:\ncould not build arguments for function \"go.temporal.io/server/service/history/shard\".glob..func1\n\t/build/temporal-8dYnj9/temporal-1.22.5/src/service/history/shard/fx.go:36:\nfailed to build *shard.ControllerImpl:\ncould not build arguments for function \"go.temporal.io/server/service/history/shard\".ControllerProvider\n\t/build/temporal-8dYnj9/temporal-1.22.5/src/service/history/shard/controller_impl.go:91:\nfailed to build membership.HostInfoProvider:\nreceived non-nil error from function \"go.temporal.io/server/common/membership/ringpop\".provideHostInfoProvider\n\t/build/temporal-8dYnj9/temporal-1.22.5/src/common/membership/ringpop/fx.go:55:\nbroadcastAddress required when listening on all interfaces (0.0.0.0/[::])","stack":"go.temporal.io/server/common/deadlock.init\n\t/build/temporal-8dYnj9/temporal-1.22.5/src/common/deadlock/fx.go:35\nruntime.doInit\n\t/usr/lib/go-1.20/src/runtime/proc.go:6506\nruntime.doInit\n\t/usr/lib/go-1.20/src/runtime/proc.go:6483\nruntime.doInit\n\t/usr/lib/go-1.20/src/runtime/proc.go:6483\nruntime.doInit\n\t/usr/lib/go-1.20/src/runtime/proc.go:6483\nruntime.main\n\t/usr/lib/go-1.20/src/runtime/proc.go:233\n","function":"go.temporal.io/server/common/deadlock.glob..func1()","module":"","logging-call-at":"fx.go:1139","stacktrace":"go.temporal.io/server/common/log.(*zapLogger).Error\n\t/build/temporal-8dYnj9/temporal-1.22.5/src/common/log/zap_logger.go:156\ngo.temporal.io/server/temporal.(*fxLogAdapter).LogEvent\n\t/build/temporal-8dYnj9/temporal-1.22.5/src/temporal/fx.go:1139\ngo.uber.org/fx.(*module).executeInvoke\n\t/build/temporal-8dYnj9/temporal-1.22.5/src/vendor/go.uber.org/fx/module.go:280\ngo.uber.org/fx.(*module).executeInvokes\n\t/build/temporal-8dYnj9/temporal-1.22.5/src/vendor/go.uber.org/fx/module.go:265\ngo.uber.org/fx.New\n\t/build/temporal-8dYnj9/temporal-1.22.5/src/vendor/go.uber.org/fx/app.go:502\ngo.temporal.io/server/temporal.HistoryServiceProvider\n\t/build/temporal-8dYnj9/temporal-1.22.5/src/temporal/fx.go:377\nreflect.Value.call\n\t/usr/lib/go-1.20/src/reflect/value.go:586\nreflect.Value.Call\n\t/usr/lib/go-1.20/src/reflect/value.go:370\ngo.uber.org/dig.defaultInvoker\n\t/build/temporal-8dYnj9/temporal-1.22.5/src/vendor/go.uber.org/dig/container.go:238\ngo.uber.org/dig.(*constructorNode).Call\n\t/build/temporal-8dYnj9/temporal-1.22.5/src/vendor/go.uber.org/dig/constructor.go:180\ngo.uber.org/dig.paramGroupedSlice.callGroupProviders\n\t/build/temporal-8dYnj9/temporal-1.22.5/src/vendor/go.uber.org/dig/param.go:609\ngo.uber.org/dig.paramGroupedSlice.Build\n\t/build/temporal-8dYnj9/temporal-1.22.5/src/vendor/go.uber.org/dig/param.go:639\ngo.uber.org/dig.paramObjectField.Build\n\t/build/temporal-8dYnj9/temporal-1.22.5/src/vendor/go.uber.org/dig/param.go:484\ngo.uber.org/dig.paramObject.Build\n\t/build/temporal-8dYnj9/temporal-1.22.5/src/vendor/go.uber.org/dig/param.go:412\ngo.uber.org/dig.paramList.BuildList\n\t/build/temporal-8dYnj9/temporal-1.22.5/src/vendor/go.uber.org/dig/param.go:150\ngo.uber.org/dig.(*constructorNode).Call\n\t/build/temporal-8dYnj9/temporal-1.22.5/src/vendor/go.uber.org/dig/constructor.go:150\ngo.uber.org/dig.paramSingle.Build\n\t/build/temporal-8dYnj9/temporal-1.22.5/src/vendor/go.uber.org/dig/param.go:287\ngo.uber.org/dig.paramList.BuildList\n\t/build/temporal-8dYnj9/temporal-1.22.5/src/vendor/go.uber.org/dig/param.go:150\ngo.uber.org/dig.(*Scope).Invoke\n\t/build/temporal-8dYnj9/temporal-1.22.5/src/vendor/go.uber.org/dig/invoke.go:122\ngo.uber.org/dig.(*Container).Invoke\n\t/build/temporal-8dYnj9/temporal-1.22.5/src/vendor/go.uber.org/dig/invoke.go:82\ngo.uber.org/fx.runInvoke\n\t/build/temporal-8dYnj9/temporal-1.22.5/src/vendor/go.uber.org/fx/invoke.go:108\ngo.uber.org/fx.(*module).executeInvoke\n\t/build/temporal-8dYnj9/temporal-1.22.5/src/vendor/go.uber.org/fx/module.go:279\ngo.uber.org/fx.(*module).executeInvokes\n\t/build/temporal-8dYnj9/temporal-1.22.5/src/vendor/go.uber.org/fx/module.go:265\ngo.uber.org/fx.New\n\t/build/temporal-8dYnj9/temporal-1.22.5/src/vendor/go.uber.org/fx/app.go:502\ngo.temporal.io/server/temporal.NewServerFx\n\t/build/temporal-8dYnj9/temporal-1.22.5/src/temporal/fx.go:161\ngo.temporal.io/server/temporal.NewServer\n\t/build/temporal-8dYnj9/temporal-1.22.5/src/temporal/server.go:69\nmain.buildCLI.func2\n\t/build/temporal-8dYnj9/temporal-1.22.5/src/cmd/server/main.go:189\ngithub.com/urfave/cli/v2.(*Command).Run\n\t/build/temporal-8dYnj9/temporal-1.22.5/src/vendor/github.com/urfave/cli/v2/command.go:163\ngithub.com/urfave/cli/v2.(*App).RunContext\n\t/build/temporal-8dYnj9/temporal-1.22.5/src/vendor/github.com/urfave/cli/v2/app.go:313\ngithub.com/urfave/cli/v2.(*App).Run\n\t/build/temporal-8dYnj9/temporal-1.22.5/src/vendor/github.com/urfave/cli/v2/app.go:224\nmain.main\n\t/build/temporal-8dYnj9/temporal-1.22.5/src/cmd/server/main.go:55\nruntime.main\n\t/usr/lib/go-1.20/src/runtime/proc.go:250"}
Feb 25 19:58:41 region-controller maas-temporal[24701]: {"level":"error","ts":"2025-02-25T19:58:41.274Z","msg":"error returned","component":"fx","name":"go.temporal.io/server/temporal.HistoryServiceProvider()","kind":"provide","module":"","error":"received non-nil error from function \"go.temporal.io/server/temporal\".HistoryServiceProvider (/build/temporal-8dYnj9/temporal-1.22.5/src/temporal/fx.go:367): could not build arguments for function \"go.temporal.io/server/common/deadlock\".glob..func1 (/build/temporal-8dYnj9/temporal-1.22.5/src/common/deadlock/fx.go:35): failed to build *deadlock.deadlockDetector: could not build arguments for function \"go.temporal.io/server/common/deadlock\".NewDeadlockDetector (/build/temporal-8dYnj9/temporal-1.22.5/src/common/deadlock/deadlock.go:82): could not build value group common.Pingable[group=\"deadlockDetectorRoots\"]: could not build arguments for function \"reflect\".makeFuncStub (/usr/lib/go-1.20/src/reflect/asm_amd64.s:28): failed to build shard.Controller: could not build arguments for function \"go.temporal.io/server/service/history/shard\".glob..func1 (/build/temporal-8dYnj9/temporal-1.22.5/src/service/history/shard/fx.go:36): failed to build *shard.ControllerImpl: could not build arguments for function \"go.temporal.io/server/service/history/shard\".ControllerProvider (/build/temporal-8dYnj9/temporal-1.22.5/src/service/history/shard/controller_impl.go:91): failed to build membership.HostInfoProvider: received non-nil error from function \"go.temporal.io/server/common/membership/ringpop\".provideHostInfoProvider (/build/temporal-8dYnj9/temporal-1.22.5/src/common/membership/ringpop/fx.go:55): broadcastAddress required when listening on all interfaces (0.0.0.0/[::])","errorVerbose":"received non-nil error from function \"go.temporal.io/server/temporal\".HistoryServiceProvider\n\t/build/temporal-8dYnj9/temporal-1.22.5/src/temporal/fx.go:367:\ncould not build arguments for function \"go.temporal.io/server/common/deadlock\".glob..func1\n\t/build/temporal-8dYnj9/temporal-1.22.5/src/common/deadlock/fx.go:35:\nfailed to build *deadlock.deadlockDetector:\ncould not build arguments for function \"go.temporal.io/server/common/deadlock\".NewDeadlockDetector\n\t/build/temporal-8dYnj9/temporal-1.22.5/src/common/deadlock/deadlock.go:82:\ncould not build value group common.Pingable[group=\"deadlockDetectorRoots\"]:\ncould not build arguments for function \"reflect\".makeFuncStub\n\t/usr/lib/go-1.20/src/reflect/asm_amd64.s:28:\nfailed to build shard.Controller:\ncould not build arguments for function \"go.temporal.io/server/service/history/shard\".glob..func1\n\t/build/temporal-8dYnj9/temporal-1.22.5/src/service/history/shard/fx.go:36:\nfailed to build *shard.ControllerImpl:\ncould not build arguments for function \"go.temporal.io/server/service/history/shard\".ControllerProvider\n\t/build/temporal-8dYnj9/temporal-1.22.5/src/service/history/shard/controller_impl.go:91:\nfailed to build membership.HostInfoProvider:\nreceived non-nil error from function \"go.temporal.io/server/common/membership/ringpop\".provideHostInfoProvider\n\t/build/temporal-8dYnj9/temporal-1.22.5/src/common/membership/ringpop/fx.go:55:\nbroadcastAddress required when listening on all interfaces (0.0.0.0/[::])","logging-call-at":"fx.go:1122","stacktrace":"go.temporal.io/server/common/log.(*zapLogger).Error\n\t/build/temporal-8dYnj9/temporal-1.22.5/src/common/log/zap_logger.go:156\ngo.temporal.io/server/temporal.(*fxLogAdapter).LogEvent\n\t/build/temporal-8dYnj9/temporal-1.22.5/src/temporal/fx.go:1122\ngo.uber.org/fx.(*module).provide.func1\n\t/build/temporal-8dYnj9/temporal-1.22.5/src/vendor/go.uber.org/fx/module.go:160\ngo.uber.org/dig.(*constructorNode).Call.func1\n\t/build/temporal-8dYnj9/temporal-1.22.5/src/vendor/go.uber.org/dig/constructor.go:161\ngo.uber.org/dig.(*constructorNode).Call\n\t/build/temporal-8dYnj9/temporal-1.22.5/src/vendor/go.uber.org/dig/constructor.go:182\ngo.uber.org/dig.paramGroupedSlice.callGroupProviders\n\t/build/temporal-8dYnj9/temporal-1.22.5/src/vendor/go.uber.org/dig/param.go:609\ngo.uber.org/dig.paramGroupedSlice.Build\n\t/build/temporal-8dYnj9/temporal-1.22.5/src/vendor/go.uber.org/dig/param.go:639\ngo.uber.org/dig.paramObjectField.Build\n\t/build/temporal-8dYnj9/temporal-1.22.5/src/vendor/go.uber.org/dig/param.go:484\ngo.uber.org/dig.paramObject.Build\n\t/build/temporal-8dYnj9/temporal-1.22.5/src/vendor/go.uber.org/dig/param.go:412\ngo.uber.org/dig.paramList.BuildList\n\t/build/temporal-8dYnj9/temporal-1.22.5/src/vendor/go.uber.org/dig/param.go:150\ngo.uber.org/dig.(*constructorNode).Call\n\t/build/temporal-8dYnj9/temporal-1.22.5/src/vendor/go.uber.org/dig/constructor.go:150\ngo.uber.org/dig.paramSingle.Build\n\t/build/temporal-8dYnj9/temporal-1.22.5/src/vendor/go.uber.org/dig/param.go:287\ngo.uber.org/dig.paramList.BuildList\n\t/build/temporal-8dYnj9/temporal-1.22.5/src/vendor/go.uber.org/dig/param.go:150\ngo.uber.org/dig.(*Scope).Invoke\n\t/build/temporal-8dYnj9/temporal-1.22.5/src/vendor/go.uber.org/dig/invoke.go:122\ngo.uber.org/dig.(*Container).Invoke\n\t/build/temporal-8dYnj9/temporal-1.22.5/src/vendor/go.uber.org/dig/invoke.go:82\ngo.uber.org/fx.runInvoke\n\t/build/temporal-8dYnj9/temporal-1.22.5/src/vendor/go.uber.org/fx/invoke.go:108\ngo.uber.org/fx.(*module).executeInvoke\n\t/build/temporal-8dYnj9/temporal-1.22.5/src/vendor/go.uber.org/fx/module.go:279\ngo.uber.org/fx.(*module).executeInvokes\n\t/build/temporal-8dYnj9/temporal-1.22.5/src/vendor/go.uber.org/fx/module.go:265\ngo.uber.org/fx.New\n\t/build/temporal-8dYnj9/temporal-1.22.5/src/vendor/go.uber.org/fx/app.go:502\ngo.temporal.io/server/temporal.NewServerFx\n\t/build/temporal-8dYnj9/temporal-1.22.5/src/temporal/fx.go:161\ngo.temporal.io/server/temporal.NewServer\n\t/build/temporal-8dYnj9/temporal-1.22.5/src/temporal/server.go:69\nmain.buildCLI.func2\n\t/build/temporal-8dYnj9/temporal-1.22.5/src/cmd/server/main.go:189\ngithub.com/urfave/cli/v2.(*Command).Run\n\t/build/temporal-8dYnj9/temporal-1.22.5/src/vendor/github.com/urfave/cli/v2/command.go:163\ngithub.com/urfave/cli/v2.(*App).RunContext\n\t/build/temporal-8dYnj9/temporal-1.22.5/src/vendor/github.com/urfave/cli/v2/app.go:313\ngithub.com/urfave/cli/v2.(*App).Run\n\t/build/temporal-8dYnj9/temporal-1.22.5/src/vendor/github.com/urfave/cli/v2/app.go:224\nmain.main\n\t/build/temporal-8dYnj9/temporal-1.22.5/src/cmd/server/main.go:55\nruntime.main\n\t/usr/lib/go-1.20/src/runtime/proc.go:250"}
Feb 25 19:58:41 region-controller maas-temporal[24701]: {"level":"error","ts":"2025-02-25T19:58:41.274Z","msg":"invoke failed","component":"fx","error":"could not build arguments for function \"go.temporal.io/server/temporal\".ServerLifetimeHooks (/build/temporal-8dYnj9/temporal-1.22.5/src/temporal/fx.go:881): failed to build *temporal.ServerImpl: could not build arguments for function \"go.temporal.io/server/temporal\".NewServerFxImpl (/build/temporal-8dYnj9/temporal-1.22.5/src/temporal/server_impl.go:64): could not build value group *temporal.ServicesMetadata[group=\"services\"]: received non-nil error from function \"go.temporal.io/server/temporal\".HistoryServiceProvider (/build/temporal-8dYnj9/temporal-1.22.5/src/temporal/fx.go:367): could not build arguments for function \"go.temporal.io/server/common/deadlock\".glob..func1 (/build/temporal-8dYnj9/temporal-1.22.5/src/common/deadlock/fx.go:35): failed to build *deadlock.deadlockDetector: could not build arguments for function \"go.temporal.io/server/common/deadlock\".NewDeadlockDetector (/build/temporal-8dYnj9/temporal-1.22.5/src/common/deadlock/deadlock.go:82): could not build value group common.Pingable[group=\"deadlockDetectorRoots\"]: could not build arguments for function \"reflect\".makeFuncStub (/usr/lib/go-1.20/src/reflect/asm_amd64.s:28): failed to build shard.Controller: could not build arguments for function \"go.temporal.io/server/service/history/shard\".glob..func1 (/build/temporal-8dYnj9/temporal-1.22.5/src/service/history/shard/fx.go:36): failed to build *shard.ControllerImpl: could not build arguments for function \"go.temporal.io/server/service/history/shard\".ControllerProvider (/build/temporal-8dYnj9/temporal-1.22.5/src/service/history/shard/controller_impl.go:91): failed to build membership.HostInfoProvider: received non-nil error from function \"go.temporal.io/server/common/membership/ringpop\".provideHostInfoProvider (/build/temporal-8dYnj9/temporal-1.22.5/src/common/membership/ringpop/fx.go:55): broadcastAddress required when listening on all interfaces (0.0.0.0/[::])","errorVerbose":"could not build arguments for function \"go.temporal.io/server/temporal\".ServerLifetimeHooks\n\t/build/temporal-8dYnj9/temporal-1.22.5/src/temporal/fx.go:881:\nfailed to build *temporal.ServerImpl:\ncould not build arguments for function \"go.temporal.io/server/temporal\".NewServerFxImpl\n\t/build/temporal-8dYnj9/temporal-1.22.5/src/temporal/server_impl.go:64:\ncould not build value group *temporal.ServicesMetadata[group=\"services\"]:\nreceived non-nil error from function \"go.temporal.io/server/temporal\".HistoryServiceProvider\n\t/build/temporal-8dYnj9/temporal-1.22.5/src/temporal/fx.go:367:\ncould not build arguments for function \"go.temporal.io/server/common/deadlock\".glob..func1\n\t/build/temporal-8dYnj9/temporal-1.22.5/src/common/deadlock/fx.go:35:\nfailed to build *deadlock.deadlockDetector:\ncould not build arguments for function \"go.temporal.io/server/common/deadlock\".NewDeadlockDetector\n\t/build/temporal-8dYnj9/temporal-1.22.5/src/common/deadlock/deadlock.go:82:\ncould not build value group common.Pingable[group=\"deadlockDetectorRoots\"]:\ncould not build arguments for function \"reflect\".makeFuncStub\n\t/usr/lib/go-1.20/src/reflect/asm_amd64.s:28:\nfailed to build shard.Controller:\ncould not build arguments for function \"go.temporal.io/server/service/history/shard\".glob..func1\n\t/build/temporal-8dYnj9/temporal-1.22.5/src/service/history/shard/fx.go:36:\nfailed to build *shard.ControllerImpl:\ncould not build arguments for function \"go.temporal.io/server/service/history/shard\".ControllerProvider\n\t/build/temporal-8dYnj9/temporal-1.22.5/src/service/history/shard/controller_impl.go:91:\nfailed to build membership.HostInfoProvider:\nreceived non-nil error from function \"go.temporal.io/server/common/membership/ringpop\".provideHostInfoProvider\n\t/build/temporal-8dYnj9/temporal-1.22.5/src/common/membership/ringpop/fx.go:55:\nbroadcastAddress required when listening on all interfaces (0.0.0.0/[::])","stack":"go.temporal.io/server/temporal.init\n\t/build/temporal-8dYnj9/temporal-1.22.5/src/temporal/fx.go:154\nruntime.doInit\n\t/usr/lib/go-1.20/src/runtime/proc.go:6506\nruntime.doInit\n\t/usr/lib/go-1.20/src/runtime/proc.go:6483\nruntime.main\n\t/usr/lib/go-1.20/src/runtime/proc.go:233\n","function":"go.temporal.io/server/temporal.ServerLifetimeHooks()","module":"","logging-call-at":"fx.go:1139","stacktrace":"go.temporal.io/server/common/log.(*zapLogger).Error\n\t/build/temporal-8dYnj9/temporal-1.22.5/src/common/log/zap_logger.go:156\ngo.temporal.io/server/temporal.(*fxLogAdapter).LogEvent\n\t/build/temporal-8dYnj9/temporal-1.22.5/src/temporal/fx.go:1139\ngo.uber.org/fx.(*module).executeInvoke\n\t/build/temporal-8dYnj9/temporal-1.22.5/src/vendor/go.uber.org/fx/module.go:280\ngo.uber.org/fx.(*module).executeInvokes\n\t/build/temporal-8dYnj9/temporal-1.22.5/src/vendor/go.uber.org/fx/module.go:265\ngo.uber.org/fx.New\n\t/build/temporal-8dYnj9/temporal-1.22.5/src/vendor/go.uber.org/fx/app.go:502\ngo.temporal.io/server/temporal.NewServerFx\n\t/build/temporal-8dYnj9/temporal-1.22.5/src/temporal/fx.go:161\ngo.temporal.io/server/temporal.NewServer\n\t/build/temporal-8dYnj9/temporal-1.22.5/src/temporal/server.go:69\nmain.buildCLI.func2\n\t/build/temporal-8dYnj9/temporal-1.22.5/src/cmd/server/main.go:189\ngithub.com/urfave/cli/v2.(*Command).Run\n\t/build/temporal-8dYnj9/temporal-1.22.5/src/vendor/github.com/urfave/cli/v2/command.go:163\ngithub.com/urfave/cli/v2.(*App).RunContext\n\t/build/temporal-8dYnj9/temporal-1.22.5/src/vendor/github.com/urfave/cli/v2/app.go:313\ngithub.com/urfave/cli/v2.(*App).Run\n\t/build/temporal-8dYnj9/temporal-1.22.5/src/vendor/github.com/urfave/cli/v2/app.go:224\nmain.main\n\t/build/temporal-8dYnj9/temporal-1.22.5/src/cmd/server/main.go:55\nruntime.main\n\t/usr/lib/go-1.20/src/runtime/proc.go:250"}
Feb 25 19:58:41 region-controller maas-temporal[24701]: Unable to create server. Error: could not build arguments for function "go.temporal.io/server/temporal".ServerLifetimeHooks (/build/temporal-8dYnj9/temporal-1.22.5/src/temporal/fx.go:881): failed to build *temporal.ServerImpl: could not build arguments for function "go.temporal.io/server/temporal".NewServerFxImpl (/build/temporal-8dYnj9/temporal-1.22.5/src/temporal/server_impl.go:64): could not build value group *temporal.ServicesMetadata[group="services"]: received non-nil error from function "go.temporal.io/server/temporal".HistoryServiceProvider (/build/temporal-8dYnj9/temporal-1.22.5/src/temporal/fx.go:367): could not build arguments for function "go.temporal.io/server/common/deadlock".glob..func1 (/build/temporal-8dYnj9/temporal-1.22.5/src/common/deadlock/fx.go:35): failed to build *deadlock.deadlockDetector: could not build arguments for function "go.temporal.io/server/common/deadlock".NewDeadlockDetector (/build/temporal-8dYnj9/temporal-1.22.5/src/common/deadlock/deadlock.go:82): could not build value group common.Pingable[group="deadlockDetectorRoots"]: could not build arguments for function "reflect".makeFuncStub (/usr/lib/go-1.20/src/reflect/asm_amd64.s:28): failed to build shard.Controller: could not build arguments for function "go.temporal.io/server/service/history/shard".glob..func1 (/build/temporal-8dYnj9/temporal-1.22.5/src/service/history/shard/fx.go:36): failed to build *shard.ControllerImpl: could not build arguments for function "go.temporal.io/server/service/history/shard".ControllerProvider (/build/temporal-8dYnj9/temporal-1.22.5/src/service/history/shard/controller_impl.go:91): failed to build membership.HostInfoProvider: received non-nil error from function "go.temporal.io/server/common/membership/ringpop".provideHostInfoProvider (/build/temporal-8dYnj9/temporal-1.22.5/src/common/membership/ringpop/fx.go:55): broadcastAddress required when listening on all interfaces (0.0.0.0/[::]).
Feb 25 19:58:41 region-controller maas.pebble[3563]: 2025-02-25T19:58:41.286Z [pebble] Change 77 task (Start service "temporal") failed: cannot start service: exited quickly with code 1
Feb 25 19:58:41 region-controller maas-log[4197]: maas.neighbour: [info] enp65s0 (physical) on region-controller: IP address 10.228.21.168 moved from c0:18:50:cb:18:ef to c0:18:50:cb:18:f0
Feb 25 19:58:42 region-controller maas-log[4197]: maas.service_monitor: [error] Service 'temporal' failed to start: Pebble change 77 failed with an error: cannot perform the following tasks:#012- Start service "temporal" (cannot start service: exited quickly with code 1)
Feb 25 19:58:44 region-controller maas-log[4197]: maas.neighbour: [info] enp65s0 (physical) on region-controller: IP address 10.228.21.168 moved from c0:18:50:cb:18:f0 to c0:18:50:cb:18:ef
Feb 25 19:58:47 region-controller maas-log[4197]: maas.neighbour: [info] enp65s0 (physical) on region-controller: IP address 10.228.21.168 moved from c0:18:50:cb:18:ef to c0:18:50:cb:18:f0
Feb 25 19:58:47 region-controller maas-temporal-worker[24363]: Task exception was never retrieved
Feb 25 19:58:47 region-controller maas-temporal-worker[24363]: future: <Task finished name='Task-2' coro=<Worker.run() done, defined at /snap/maas/38185/lib/python3.10/site-packages/maasserver/workflow/worker/worker.py:99> exception=RuntimeError('Failed client connect: Server connection error: tonic::transport::Error(Transport, hyper::Error(Connect, ConnectError("tcp connect error", Os { code: 111, kind: ConnectionRefused, message: "Connection refused" })))')>
Feb 25 19:58:47 region-controller maas-temporal-worker[24363]: Traceback (most recent call last):
Feb 25 19:58:47 region-controller maas-temporal-worker[24363]:   File "/snap/maas/38185/lib/python3.10/site-packages/maasserver/workflow/worker/worker.py", line 100, in run
Feb 25 19:58:47 region-controller maas-temporal-worker[24363]:     self._client = self._client or await get_client_async()
Feb 25 19:58:47 region-controller maas-temporal-worker[24363]:   File "/snap/maas/38185/lib/python3.10/site-packages/maasserver/utils/asynchronous.py", line 263, in wrapped
Feb 25 19:58:47 region-controller maas-temporal-worker[24363]:     raise e
Feb 25 19:58:47 region-controller maas-temporal-worker[24363]:   File "/snap/maas/38185/lib/python3.10/site-packages/maasserver/utils/asynchronous.py", line 259, in wrapped
Feb 25 19:58:47 region-controller maas-temporal-worker[24363]:     return await fn(*args, **kwargs)
Feb 25 19:58:47 region-controller maas-temporal-worker[24363]:   File "/snap/maas/38185/lib/python3.10/site-packages/maasserver/workflow/worker/worker.py", line 45, in get_client_async
Feb 25 19:58:47 region-controller maas-temporal-worker[24363]:     return await Client.connect(
Feb 25 19:58:47 region-controller maas-temporal-worker[24363]:   File "/snap/maas/38185/usr/lib/python3/dist-packages/temporalio/client.py", line 148, in connect
Feb 25 19:58:47 region-controller maas-temporal-worker[24363]:     await temporalio.service.ServiceClient.connect(connect_config),
Feb 25 19:58:47 region-controller maas-temporal-worker[24363]:   File "/snap/maas/38185/usr/lib/python3/dist-packages/temporalio/service.py", line 158, in connect
Feb 25 19:58:47 region-controller maas-temporal-worker[24363]:     return await _BridgeServiceClient.connect(config)
Feb 25 19:58:47 region-controller maas-temporal-worker[24363]:   File "/snap/maas/38185/usr/lib/python3/dist-packages/temporalio/service.py", line 685, in connect
Feb 25 19:58:47 region-controller maas-temporal-worker[24363]:     await client._connected_client()
Feb 25 19:58:47 region-controller maas-temporal-worker[24363]:   File "/snap/maas/38185/usr/lib/python3/dist-packages/temporalio/service.py", line 698, in _connected_client
Feb 25 19:58:47 region-controller maas-temporal-worker[24363]:     self._bridge_client = await temporalio.bridge.client.Client.connect(
Feb 25 19:58:47 region-controller maas-temporal-worker[24363]:   File "/snap/maas/38185/usr/lib/python3/dist-packages/temporalio/bridge/client.py", line 78, in connect
Feb 25 19:58:47 region-controller maas-temporal-worker[24363]:     await temporalio.bridge.temporal_sdk_bridge.connect_client(
Feb 25 19:58:47 region-controller maas-temporal-worker[24363]: RuntimeError: Failed client connect: Server connection error: tonic::transport::Error(Transport, hyper::Error(Connect, ConnectError("tcp connect error", Os { code: 111, kind: ConnectionRefused, message: "Connection refused" })))
Feb 25 19:58:48 region-controller maas.pebble[3563]: 2025-02-25T19:58:48.055Z [pebble] Service "temporal-worker" stopped unexpectedly with code 0
Feb 25 19:58:48 region-controller maas.pebble[3563]: 2025-02-25T19:58:48.055Z [pebble] Service "temporal-worker" on-success action is "restart", waiting ~500ms before restart (backoff 1)
Feb 25 19:58:48 region-controller maas.pebble[3563]: 2025-02-25T19:58:48.594Z [pebble] Service "temporal-worker" starting: sh -c "exec systemd-cat -t maas-temporal-worker $SNAP/bin/run-temporal-worker"
Feb 25 19:58:50 region-controller maas-log[4197]: maas.neighbour: [info] enp65s0 (physical) on region-controller: IP address 10.228.21.168 moved from c0:18:50:cb:18:f0 to c0:18:50:cb:18:ef
Feb 25 19:58:53 region-controller maas-log[4197]: maas.neighbour: [info] enp65s0 (physical) on region-controller: IP address 10.228.21.168 moved from c0:18:50:cb:18:ef to c0:18:50:cb:18:f0
Please let me know if you need anything else.
Thank you!
Hey @harshkapadia
It looks like something is wrong with temporal and it can’t start. How did you setup maas? Have you done anything unusual during the setup?
I don’t think I did anything weird. I’ve tried to set up MAAS twice (in the config as seen in the first picture in the original post) and I’ve had the exact same issue both times.
I followed the MAAS installation guide to the T (except that I set up different region and rack controllers).
This is the guide I followed: MAAS | How to install MAAS
My first post on this forum prompted me to re-install OSs on those controllers and start over with MAAS, but to no avail, which is why I created this post.
Do you mind running
sudo snap run --shell maas -c "maas-region shell"
and then
import socket
from urllib.parse import urlparse
from maasserver.config import RegionConfiguration
def get_broadcast_address(self, maas_url):
    parsed = urlparse(maas_url)
    maas_ip = socket.gethostbyname(parsed.hostname)
    output = subprocess.getoutput(f"ip route get {maas_ip}")
    return output.split("src ")[1].split()[0]
with RegionConfiguration.open() as config:
    get_broadcast_address(config.maas_url)
Had to change that slightly to get it to run:
import subprocess
import socket
def get_broadcast_address(maas_url):
I got the output 10.228.21.94, which is the host IP address of my region controller.
Output of sudo cat /var/snap/maas/current/temporal/production.yaml?
From the region controller (/var/snap/maas/current/temporal/production.yaml):
log:
  stdout: true
  level: warn
persistence:
  defaultStore: default
  visibilityStore: visibility
  numHistoryShards: 4
  datastores:
    default:
      sql:
        user: "maas-db-user"
        password: "xxx"
        pluginName: "postgres12"
        databaseName: "maas-db"
        connectAddr: "localhost:5432"
        connectProtocol: "tcp"
        connectAttributes:
          search_path: "temporal"
          application_name: "maas-temporal-nfsbhe"
        maxConns: 5
        maxIdleConns: 5
        maxConnLifetime: "5m"
    visibility:
      sql:
        password: "xxx"
        connectAttributes:
          search_path: "temporal_visibility"
        maxConns: 1
        maxIdleConns: 1
global:
  membership:
    maxJoinDuration: 30s
    broadcastAddress: ""
  pprof:
    # disable pprof
    port: 0
  tls:
    refreshInterval: 0s
    internode:
      # This server section configures the TLS certificate that internal temporal
      # cluster nodes (history, matching, and internal-frontend) present to other
      # clients within the Temporal Cluster.
      server:
        requireClientAuth: true
        certFile: /var/snap/maas/38185/certificates/cluster.pem
        keyFile: /var/snap/maas/38185/certificates/cluster.key
        clientCaFiles:
          - /var/snap/maas/38185/certificates/cacerts.pem
      # This client section is used to configure the TLS clients within
      # the Temporal Cluster that connect to an Internode (history, matching, or
      # internal-frontend)
      client:
        serverName: maas
        disableHostVerification: false
        rootCaFiles:
    frontend:
      # This server section configures the TLS certificate that the Frontend
      # server presents to external clients.
      server:
        clientCaFiles:
      client:
        serverName: maas
        rootCaFiles:
  metrics:
    prometheus:
      framework: "tally"
      timerType: "histogram"
      # metrics are exposed via load balancer
      listenAddress: "127.0.0.1:9000"
services:
  frontend:
    rpc:
      grpcPort: 5271
      membershipPort: 5281
      bindOnIP: "0.0.0.0"
  matching:
    rpc:
      grpcPort: 5272
      membershipPort: 5282
      bindOnIP: "0.0.0.0"
  history:
    rpc:
      grpcPort: 5273
      membershipPort: 5283
      bindOnIP: "0.0.0.0"
  worker:
    rpc:
      grpcPort: 5274
      membershipPort: 5284
      bindOnIP: "0.0.0.0"
clusterMetadata:
  enableGlobalNamespace: false
  failoverVersionIncrement: 10
  masterClusterName: "active"
  currentClusterName: "active"
  clusterInformation:
    active:
      enabled: true
      initialFailoverVersion: 1
      rpcName: "frontend"
      rpcAddress: "localhost:7233"
dynamicConfigClient:
  filepath: "/var/snap/maas/38185/temporal/production-dynamic.yaml"
  pollInterval: "60s"
Yeah this is wrong. But I don’t know how you ended up with such empty string given that the code above produced a valid IP address. Can you show the content of sudo cat /var/snap/maas/current/regiond.conf?
Anyways, I’d say you can re-init MAAS to see if this file is properly generated or add
broadcast_address: 10.228.21.94
in your /var/snap/maas/current/regiond.conf, restart MAAS and ensure that the address is then automatically placed in your /var/snap/maas/current/temporal/production.yaml
From the region controller (/var/snap/maas/current/regiond.conf ):
database_host: localhost
database_name: maas-db
database_pass: xxx
database_user: maas-db-user
maas_url: http://10.228.21.94:5240/MAAS
How do I re-init MAAS? Also, how do I restart MAAS?
You can run the
sudo maas init ...
again.
Otherwise you can edit the regiond.conf manually and then
sudo snap restart maas
Just re-initializing MAAS solved the issue. (I now see the broadcast IP address in /var/snap/maas/current/temporal/production.yaml in the region controller.)
Images are now syncing.
I don’t know why it happened or how it got resolved.
Thank you so much for the help, @r00ta and @alemar99! Appreciate it!
In my situation racks showed that images were in sync but remote racks were not able to commission/pxe nodes/vms with he same error message you reported.
After removing the good old nginx reverse proxy used to encrypt region communication in old versions of maas and enabling TLS in MAAS directly with certbot, re initializing the racks fixed pxe for nodes being commissioned on remote locations.
