When commissioning for the first time my servers seem to fail at updating to the regiond controller, leaving the status of the machine as commissioning:
[ 51.765913] cloud-init[2220]: Downloading and extracting http://10-10-13-0--24.maas-internal:5248/MAAS/metadata/2012-03-01/maas-scripts to /tmp/user_data.sh.0Aekty/scripts
[ 51.984773] cloud-init[2220]: Starting commissioning scripts...
Starting LLDP daemon...
[ OK ] Started LLDP daemon.
Stopping LLDP daemon...
[ OK ] Stopped LLDP daemon.
[ 79.545482] x86/PAT: ipmi-locate:3834 map pfn expected mapping type uncached-minus for [mem 0x7b504000-0x7b504fff], got write-back
[ 79.568987] x86/PAT: ipmi-locate:3834 map pfn expected mapping type uncached-minus for [mem 0x7b504000-0x7b504fff], got write-back
[ 79.592482] x86/PAT: ipmi-locate:3834 map pfn expected mapping type uncached-minus for [mem 0x7b504000-0x7b504fff], got write-back
[ 79.615977] x86/PAT: ipmi-locate:3834 map pfn expected mapping type uncached-minus for [mem 0x7b504000-0x7b504fff], got write-back
Starting Time & Date Service...
[ OK ] Started Time & Date Service.
[ 441.240097] cloud-init[2220]: Installing apt packages for 20-maas-01-install-lldpd
[ 441.240264] cloud-init[2220]: Starting 20-maas-01-install-lldpd
[ 441.240362] cloud-init[2220]: Finished 20-maas-01-install-lldpd: 0
[ 441.240450] cloud-init[2220]: Starting 20-maas-02-dhcp-unconfigured-ifaces
[ 441.240551] cloud-init[2220]: Finished 20-maas-02-dhcp-unconfigured-ifaces: 0
[ 441.240640] cloud-init[2220]: Starting 20-maas-03-machine-resources
[ 441.240725] cloud-init[2220]: Finished 20-maas-03-machine-resources: 0
[ 441.240811] cloud-init[2220]: Installing apt packages for 30-maas-01-bmc-config
[ 441.240897] cloud-init[2220]: Starting 30-maas-01-bmc-config
[ 441.240983] cloud-init[2220]: BMC credentials reconfigured by 30-maas-01-bmc-config
[ 441.241072] cloud-init[2220]: request to http://10-10-13-0--24.maas-internal:5248/MAAS/metadata/latest/by-id/myggp3/?op=get_preseed failed. sleeping 1.: HTTP Error 500: Internal Server Error
[ 441.241162] cloud-init[2220]: request to http://10-10-13-0--24.maas-internal:5248/MAAS/metadata/latest/by-id/myggp3/?op=get_preseed failed. sleeping 1.: HTTP Error 500: Internal Server Error
running MAAS 3.2.7 and using a separate controller.
does anyone have any tips how to solve this?
Or is there maybe a log file on the regiond controller where these errors are logged? I couldn`t find anything useful in the /var/log directory of the regiond controller.
