I have an home lab with a hp proliant dl 360 G7. Its commissioning fails in two scripts. I would be very grateful if anyone could point me in the right direction for solving the issues. Thanks in advance!
- 30-maas-01-bmc-config fails with the following error
Unknown section `None'
INFO: Loading IPMI kernel modules...
INFO: Checking for HP Moonshot...
INFO: Checking for Redfish...
ERROR: Redfish configuration failed. Missing SMBIOS data
INFO: Checking for IPMI...
INFO: IPMI detected!
INFO: Reading current IPMI BMC values...
INFO: Configuring IPMI Lan_Channel...
INFO: Configuring IPMI Lan_Channel_Auth...
INFO: Lan_Channel_Auth settings unavailable!
WARNING: No K_g BMC key found or configured, communication with BMC will not use a session key!
INFO: Configuring IPMI Serial_Channel...
INFO: Configuring IPMI SOL_Conf...
INFO: Found existing IPMI user "maas"!
INFO: Configuring IPMI BMC user "maas"...
INFO: IPMI user number - User3
INFO: IPMI user privilege level - Administrator
INFO: IPMI Version - LAN_2_0
INFO: IPMI boot type - auto
INFO: Attempting to enable preconfigured static IP on BMC...
ERROR: IPMI Command '['bmc-config', '--commit', '--key-pair=None:IP_Address_Source=Static']' returned non-zero exit status 1.
File "/tmp/user_data.sh.SwE8V8/scripts/commissioning/30-maas-01-bmc-config", line 1126, in detect_and_configure
**bmc.get_credentials(),
File "/tmp/user_data.sh.SwE8V8/scripts/commissioning/30-maas-01-bmc-config", line 660, in get_credentials
ip_address, mac_address = self.get_bmc_ip()
File "/tmp/user_data.sh.SwE8V8/scripts/commissioning/30-maas-01-bmc-config", line 628, in get_bmc_ip
self._bmc_set(section_name, "IP_Address_Source", "Static")
File "/tmp/user_data.sh.SwE8V8/scripts/commissioning/30-maas-01-bmc-config", line 271, in _bmc_set
check_call(
File "/usr/lib/python3.10/subprocess.py", line 369, in check_call
raise CalledProcessError(retcode, cmd)
subprocess.CalledProcessError: Command '['bmc-config', '--commit', '--key-pair=None:IP_Address_Source=Static']' returned non-zero exit status 1.
INFO: Checking for Facebook Wedge...
INFO: No BMC automatically detected!
- 50-maas-01-commissioning failures fails with the following output
"api_extensions": [
"resources",
"resources_cpu_socket",
"resources_gpu",
"resources_numa",
"resources_v2",
"resources_disk_sata",
"resources_network_firmware",
"resources_disk_id",
"resources_usb_pci",
"resources_cpu_threads_numa",
"resources_cpu_core_die",
"api_os",
"resources_system",
"resources_pci_iommu",
"resources_network_usb",
"resources_disk_address"
"api_version": "1.0",
"environment": {
"kernel": "Linux",
"kernel_architecture": "x86_64",
"kernel_version": "5.15.0-69-generic",
"os_name": "ubuntu",
"os_version": "22.04",
"server": "maas-machine-resources",
"server_name": "maas-enlisting-node",
"server_version": "5.8"
"resources": {
"cpu": {
"architecture": "x86_64",
"sockets": [
"name": "Intel(R) Xeon(R) CPU E5649 @ 2.53GHz",
"vendor": "GenuineIntel",
"socket": 0,
"cache": [
"level": 1,
"type": "Data",
"size": 32768
"level": 1,
"type": "Instruction",
"size": 32768
"level": 2,
"type": "Unified",
"size": 262144
"level": 3,
"type": "Unified",
"size": 12582912
"cores": [
"core": 0,
"die": 0,
"threads": [
"id": 0,
"numa_node": 0,
"thread": 0,
"online": true,
"isolated": false
"id": 12,
"numa_node": 0,
"thread": 1,
"online": true,
"isolated": false
"frequency": 1927
"core": 1,
"die": 0,
"threads": [
"id": 20,
"numa_node": 0,
"thread": 0,
"online": true,
"isolated": false
"id": 8,
"numa_node": 0,
"thread": 1,
"online": true,
"isolated": false
"frequency": 1690
"core": 2,
"die": 0,
"threads": [
"id": 16,
"numa_node": 0,
"thread": 0,
"online": true,
"isolated": false
"id": 4,
"numa_node": 0,
"thread": 1,
"online": true,
"isolated": false
"frequency": 1600
"core": 8,
"die": 0,
"threads": [
"id": 14,
"numa_node": 0,
"thread": 0,
"online": true,
"isolated": false
"id": 2,
"numa_node": 0,
"thread": 1,
"online": true,
"isolated": false
"frequency": 1600
"core": 9,
"die": 0,
"threads": [
"id": 10,
"numa_node": 0,
"thread": 0,
"online": true,
"isolated": false
"id": 22,
"numa_node": 0,
"thread": 1,
"online": true,
"isolated": false
"frequency": 1599
"core": 10,
"die": 0,
"threads": [
"id": 18,
"numa_node": 0,
"thread": 0,
"online": true,
"isolated": false
"id": 6,
"numa_node": 0,
"thread": 1,
"online": true,
"isolated": false
"frequency": 1600
"frequency": 1669,
"frequency_minimum": 1600,
"frequency_turbo": 2533
"socket": 1,
"cache": [
"level": 1,
"type": "Data",
"size": 32768
"level": 1,
"size": 32768
"level": 2,
"type": "Unified",
"size": 262144
"level": 3,
"type": "Unified",
"size": 12582912
"cores": [
"core": 0,
"die": 0,
"threads": [
"id": 1,
"numa_node": 1,
"thread": 0,
"online": true,
"isolated": false
"id": 13,
"numa_node": 1,
"thread": 1,
"online": true,
"isolated": false
"frequency": 1884
"core": 1,
"die": 0,
"threads": [
"id": 21,
"numa_node": 1,
"thread": 0,
"online": true,
"isolated": false
"id": 9,
"numa_node": 1,
"thread": 1,
"online": true,
"isolated": false
"frequency": 2291
"core": 2,
"die": 0,
"threads": [
"id": 17,
"numa_node": 1,
"thread": 0,
"online": true,
"isolated": false
"id": 5,
"numa_node": 1,
"thread": 1,
"online": true,
"isolated": false
"frequency": 2004
"core": 8,
"die": 0,
"threads": [
"id": 15,
"numa_node": 1,
"thread": 0,
"online": true,
"isolated": false
"id": 3,
"numa_node": 1,
"thread": 1,
"online": true,
"isolated": false
"frequency": 1865
"core": 9,
"die": 0,
"threads": [
"id": 11,
"numa_node": 1,
"thread": 0,
"online": true,
"isolated": false
"id": 23,
"numa_node": 1,
"thread": 1,
"online": true,
"isolated": false
"frequency": 2034
"core": 10,
"die": 0,
"threads": [
"id": 19,
"numa_node": 1,
"thread": 0,
"online": true,
"isolated": false
"id": 7,
"numa_node": 1,
"thread": 1,
"online": true,
"isolated": false
"frequency": 2039
"frequency": 2019,
"total": 24
"memory": {
"nodes": [
"numa_node": 0,
"hugepages_used": 0,
"hugepages_total": 0,
"used": 1226637312,
"total": 36507222016
"numa_node": 1,
"used": 698531840,
"hugepages_size": 2097152,
"used": 4013355008,
"total": 70866960384
"gpu": {
"cards": [
"numa_node": 0,
"pci_address": "0000:01:03.0",
"vendor": "Advanced Micro Devices, Inc. [AMD/ATI]",
"vendor_id": "1002",
"product": "ES1000",
"product_id": "515e"
"total": 1
"network": {
"cards": [
"driver": "bnx2",
"driver_version": "5.15.0-69-generic",
"ports": [
"id": "enp3s0f0",
"address": "e4:11:5b:d6:86:94",
"port": 0,
"protocol": "ethernet",
"supported_modes": [
"10baseT/Half",
"10baseT/Full",
"100baseT/Half",
"100baseT/Full",
"1000baseT/Full"
"supported_ports": [
"twisted pair"
"port_type": "twisted pair",
"auto_negotiation": true,
"link_detected": true,
"link_speed": 100,
"link_duplex": "full"
"numa_node": 0,
"pci_address": "0000:03:00.0",
"vendor": "Broadcom Inc. and subsidiaries",
"vendor_id": "14e4",
"product": "NetXtreme II BCM5709 Gigabit Ethernet",
"product_id": "1639",
"firmware_version": "bc 5.2.3 NCSI 2.0.12"
"driver": "bnx2",
"ports": [
"id": "enp3s0f1",
"address": "e4:11:5b:d6:86:96",
"port": 0,
"10baseT/Half",
"10baseT/Full",
"100baseT/Half",
"100baseT/Full",
"1000baseT/Full"
"twisted pair"
"link_detected": false
"numa_node": 0,
"pci_address": "0000:03:00.1",
"driver": "bnx2",
"ports": [
"id": "enp4s0f0",
"address": "e4:11:5b:d6:86:7c",
"port": 0,
"10baseT/Half",
"10baseT/Full",
"100baseT/Half",
"100baseT/Full",
"1000baseT/Full"
"twisted pair"
"numa_node": 0,
"pci_address": "0000:04:00.0",
"driver": "bnx2",
"ports": [
"id": "enp4s0f1",
"address": "e4:11:5b:d6:86:7e",
"port": 0,
"10baseT/Half",
"10baseT/Full",
"100baseT/Half",
"100baseT/Full",
"1000baseT/Full"
"twisted pair"
"numa_node": 0,
"pci_address": "0000:04:00.1",
"total": 4
"storage": {
"disks": [
"id": "sda",
"device": "8:0",
"model": "LOGICAL VOLUME",
"type": "scsi",
"read_only": false,
"size": 587128266752,
"removable": false,
"numa_node": 0,
"device_path": "pci-0000:05:00.0-scsi-0:1:0:0",
"block_size": 512,
"firmware_version": "6.64",
"rpm": 1,
"serial": "600508b1001c29d18ef1c59c2c542ef0",
"device_id": "wwn-0x600508b1001c29d18ef1c59c2c542ef0",
"partitions": [
"id": "sda1",
"device": "8:1",
"read_only": false,
"size": 586102603776,
"partition": 1
"id": "sda2",
"device": "8:2",
"read_only": false,
"size": 1024,
"partition": 2
"id": "sda5",
"device": "8:5",
"read_only": false,
"size": 1023410176,
"partition": 5
"total": 4
"usb": {
"devices": [
"bus_address": 4,
"device_address": 2,
"interfaces": [
"class": "Human Interface Device",
"class_id": 3,
"driver": "usbhid",
"number": 0,
"subclass": "Boot Interface Subclass",
"subclass_id": 1
"class_id": 3,
"driver": "usbhid",
"number": 1,
"subclass": "",
"subclass_id": 0
"vendor": "GreenAsia Inc.",
"vendor_id": "0e8f",
"product": "USB KB V11",
"product_id": "0022",
"speed": 1.5
"bus_address": 6,
"interfaces": [
"class_id": 3,
"driver": "usbhid",
"number": 0,
"subclass_id": 1
"class_id": 3,
"driver": "usbhid",
"number": 1,
"subclass_id": 1
"vendor": "HP, Inc",
"vendor_id": "03f0",
"product": "Virtual Keyboard",
"product_id": "7029",
"speed": 12
"total": 2
"pci": {
"devices": [
"driver": "",
"driver_version": "",
"numa_node": 0,
"pci_address": "0000:00:00.0",
"vendor": "Intel Corporation",
"vendor_id": "8086",
"product": "5520 I/O Hub to ESI Port",
"product_id": "3406",
"iommu_group": 0,
"vpd": {}
"driver": "pcieport",
"numa_node": 0,
"pci_address": "0000:00:01.0",
"product": "5520/5500/X58 I/O Hub PCI Express Root Port 1",
"product_id": "3408",
"iommu_group": 0,
"vpd": {}
"numa_node": 0,
"product": "5520/5500/X58 I/O Hub PCI Express Root Port 2",
"product_id": "3409",
"iommu_group": 0,
"vpd": {}
"numa_node": 0,
"pci_address": "0000:00:03.0",
"product": "5520/5500/X58 I/O Hub PCI Express Root Port 3",
"product_id": "340a",
"iommu_group": 0,
"vpd": {}
"numa_node": 0,
"pci_address": "0000:00:04.0",
"product": "5520/X58 I/O Hub PCI Express Root Port 4",
"product_id": "340b",
"iommu_group": 0,
"vpd": {}
"numa_node": 0,
"pci_address": "0000:00:05.0",
"product": "5520/X58 I/O Hub PCI Express Root Port 5",
"product_id": "340c",
"iommu_group": 0,
"vpd": {}
"numa_node": 0,
"pci_address": "0000:00:06.0",
"product": "5520/X58 I/O Hub PCI Express Root Port 6",
"product_id": "340d",
"iommu_group": 0,
"vpd": {}
"numa_node": 0,
"pci_address": "0000:00:07.0",
"product": "5520/5500/X58 I/O Hub PCI Express Root Port 7",
"product_id": "340e",
"iommu_group": 0,
"vpd": {}
"numa_node": 0,
"pci_address": "0000:00:08.0",
"product": "5520/5500/X58 I/O Hub PCI Express Root Port 8",
"product_id": "340f",
"iommu_group": 0,
"vpd": {}
"numa_node": 0,
"pci_address": "0000:00:09.0",
"product": "7500/5520/5500/X58 I/O Hub PCI Express Root Port 9",
"product_id": "3410",
"iommu_group": 0,
"vpd": {}
"numa_node": 0,
"pci_address": "0000:00:0a.0",
"product": "7500/5520/5500/X58 I/O Hub PCI Express Root Port 10",
"product_id": "3411",
"iommu_group": 0,
"vpd": {}
"driver": "",
"numa_node": 0,
"pci_address": "0000:00:0d.0",
"product": "",
"product_id": "343a",
"iommu_group": 0,
"vpd": {}
"driver": "",
"numa_node": 0,
"pci_address": "0000:00:0d.1",
"product": "",
"product_id": "343b",
"iommu_group": 0,
"vpd": {}
"driver": "",
"numa_node": 0,
"pci_address": "0000:00:0d.2",
"product": "",
"product_id": "343c",
"iommu_group": 0,
"vpd": {}
"driver": "",
"numa_node": 0,
"pci_address": "0000:00:0d.3",
"product": "",
"product_id": "343d",
"iommu_group": 0,
"vpd": {}
"driver": "",
"numa_node": 0,
"pci_address": "0000:00:0d.4",
"product": "7500/5520/5500/X58 Physical Layer Port 0",
"product_id": "3418",
"iommu_group": 0,
"vpd": {}
"driver": "",
"numa_node": 0,
"pci_address": "0000:00:0d.5",
"product": "7500/5520/5500 Physical Layer Port 1",
"product_id": "3419",
"iommu_group": 0,
"vpd": {}
"driver": "",
"numa_node": 0,
"pci_address": "0000:00:0d.6",
"product": "",
"product_id": "341a",
"iommu_group": 0,
"vpd": {}
"driver": "",
"numa_node": 0,
"pci_address": "0000:00:0e.0",
"product": "",
"product_id": "341c",
"iommu_group": 0,
"vpd": {}
"driver": "",
"numa_node": 0,
"pci_address": "0000:00:0e.1",
"product": "",
"product_id": "341d",
"iommu_group": 0,
"vpd": {}
"driver": "",
"numa_node": 0,
"pci_address": "0000:00:0e.2",
"product": "",
"product_id": "341e",
"iommu_group": 0,
"vpd": {}
"driver": "",
"numa_node": 0,
"pci_address": "0000:00:0e.3",
"product": "",
"product_id": "341f",
"iommu_group": 0,
"vpd": {}
"driver": "",
"numa_node": 0,
"pci_address": "0000:00:0e.4",
"product": "",
"product_id": "3439",
"iommu_group": 0,
"vpd": {}
"driver": "",
"numa_node": 0,
"pci_address": "0000:00:14.0",
"product": "7500/5520/5500/X58 I/O Hub System Management Registers",
"product_id": "342e",
"iommu_group": 0,
"vpd": {}
"driver": "",
"numa_node": 0,
"pci_address": "0000:00:14.1",
"product": "7500/5520/5500/X58 I/O Hub GPIO and Scratch Pad Registers",
"product_id": "3422",
"iommu_group": 0,
"vpd": {}
"driver": "",
"numa_node": 0,
"pci_address": "0000:00:14.2",
"product": "7500/5520/5500/X58 I/O Hub Control Status and RAS Registers",
"product_id": "3423",
"iommu_group": 0,
"vpd": {}
"numa_node": 0,
"pci_address": "0000:00:1c.0",
"product": "82801JI (ICH10 Family) PCI Express Root Port 1",
"product_id": "3a40",
"iommu_group": 0,
"vpd": {}
"numa_node": 0,
"pci_address": "0000:00:1c.4",
"product": "82801JI (ICH10 Family) PCI Express Root Port 5",
"product_id": "3a48",
"iommu_group": 0,
"vpd": {}
"driver": "uhci_hcd",
"numa_node": 0,
"pci_address": "0000:00:1d.0",
"product": "82801JI (ICH10 Family) USB UHCI Controller #1",
"product_id": "3a34",
"iommu_group": 0,
"vpd": {}
"numa_node": 0,
"pci_address": "0000:00:1d.1",
"product": "82801JI (ICH10 Family) USB UHCI Controller #2",
"product_id": "3a35",
"iommu_group": 0,
"vpd": {}
"numa_node": 0,
"pci_address": "0000:00:1d.2",
"product": "82801JI (ICH10 Family) USB UHCI Controller #3",
"product_id": "3a36",
"iommu_group": 0,
"vpd": {}
"numa_node": 0,
"pci_address": "0000:00:1d.3",
"product": "82801JI (ICH10 Family) USB UHCI Controller #6",
"product_id": "3a39",
"iommu_group": 0,
"vpd": {}
"driver": "ehci-pci",
"numa_node": 0,
"pci_address": "0000:00:1d.7",
"product": "82801JI (ICH10 Family) USB2 EHCI Controller #1",
"product_id": "3a3a",
"iommu_group": 0,
"vpd": {}
"driver": "",
"numa_node": 0,
"pci_address": "0000:00:1e.0",
"product": "82801 PCI Bridge",
"product_id": "244e",
"iommu_group": 0,
"vpd": {}
"driver": "lpc_ich",
"numa_node": 0,
"pci_address": "0000:00:1f.0",
"product": "82801JIB (ICH10) LPC Interface Controller",
"product_id": "3a18",
"iommu_group": 0,
"vpd": {}
"driver": "",
"numa_node": 0,
"product_id": "515e",
"iommu_group": 0,
"vpd": {}
"driver": "",
"numa_node": 0,
"pci_address": "0000:02:00.0",
"vendor": "Hewlett-Packard Company",
"vendor_id": "103c",
"product": "Integrated Lights-Out Standard Slave Instrumentation & System Support",
"product_id": "3306",
"iommu_group": 0,
"vpd": {}
"driver": "hpilo",
"driver_version": "1.5.0",
"numa_node": 0,
"pci_address": "0000:02:00.2",
"product": "Integrated Lights-Out Standard Management Processor Support and Messaging",
"product_id": "3307",
"iommu_group": 0,
"vpd": {}
"numa_node": 0,
"pci_address": "0000:02:00.4",
"product": "Integrated Lights-Out Standard Virtual USB Controller",
"product_id": "3300",
"iommu_group": 0,
"vpd": {}
"driver": "bnx2",
"numa_node": 0,
"iommu_group": 0,
"vpd": {
"product_name": "HP NC382i Multifunction Gigabit Server Adapter",
"entries": {
"EC": "N/A",
"MN": "103C",
"PN": "N/A",
"SN": "0123456789"
"driver": "bnx2",
"numa_node": 0,
"iommu_group": 0,
"vpd": {
"entries": {
"EC": "N/A",
"MN": "103C",
"PN": "N/A",
"SN": "0123456789"
"driver": "bnx2",
"numa_node": 0,
"iommu_group": 0,
"vpd": {
"entries": {
"EC": "N/A",
"MN": "103C",
"PN": "N/A",
"SN": "0123456789"
"driver": "bnx2",
"numa_node": 0,
"iommu_group": 0,
"vpd": {
"entries": {
"EC": "N/A",
"MN": "103C",
"PN": "N/A",
"SN": "0123456789"
"driver": "hpsa",
"driver_version": "3.4.20-200",
"numa_node": 0,
"pci_address": "0000:05:00.0",
"product": "Smart Array G6 controllers",
"product_id": "323a",
"iommu_group": 0,
"vpd": {}
"driver": "",
"numa_node": 0,
"pci_address": "0000:3e:00.0",
"product": "Xeon 5600 Series QuickPath Architecture Generic Non-core Registers",
"product_id": "2c70",
"iommu_group": 0,
"vpd": {}
"driver": "",
"numa_node": 0,
"pci_address": "0000:3e:00.1",
"product": "Xeon 5600 Series QuickPath Architecture System Address Decoder",
"product_id": "2d81",
"iommu_group": 0,
"vpd": {}
"driver": "",
"numa_node": 0,
"pci_address": "0000:3e:02.0",
"product": "Xeon 5600 Series QPI Link 0",
"product_id": "2d90",
"iommu_group": 0,
"vpd": {}
"driver": "",
"numa_node": 0,
"pci_address": "0000:3e:02.1",
"product": "Xeon 5600 Series QPI Physical 0",
"product_id": "2d91",
"iommu_group": 0,
"vpd": {}
"driver": "",
"numa_node": 0,
"pci_address": "0000:3e:02.2",
"product": "Xeon 5600 Series Mirror Port Link 0",
"product_id": "2d92",
"iommu_group": 0,
"vpd": {}
"driver": "",
"numa_node": 0,
"pci_address": "0000:3e:02.3",
"product": "Xeon 5600 Series Mirror Port Link 1",
"product_id": "2d93",
"iommu_group": 0,
"vpd": {}
"driver": "",
"numa_node": 0,
"pci_address": "0000:3e:02.4",
"product": "Xeon 5600 Series QPI Link 1",
"product_id": "2d94",
"iommu_group": 0,
"vpd": {}
"driver": "",
"numa_node": 0,
"pci_address": "0000:3e:02.5",
"product": "Xeon 5600 Series QPI Physical 1",
"product_id": "2d95",
"iommu_group": 0,
"vpd": {}
"driver": "",
"numa_node": 0,
"pci_address": "0000:3e:03.0",
"product": "Xeon 5600 Series Integrated Memory Controller Registers",
"product_id": "2d98",
"iommu_group": 0,
"vpd": {}
"driver": "",
"numa_node": 0,
"pci_address": "0000:3e:03.1",
"product": "Xeon 5600 Series Integrated Memory Controller Target Address Decoder",
"product_id": "2d99",
"iommu_group": 0,
"vpd": {}
"driver": "",
"numa_node": 0,
"pci_address": "0000:3e:03.2",
"product": "Xeon 5600 Series Integrated Memory Controller RAS Registers",
"product_id": "2d9a",
"iommu_group": 0,
"vpd": {}
"driver": "",
"numa_node": 0,
"pci_address": "0000:3e:03.4",
"product": "Xeon 5600 Series Integrated Memory Controller Test Registers",
"product_id": "2d9c",
"iommu_group": 0,
"vpd": {}
"driver": "",
"numa_node": 0,
"pci_address": "0000:3e:04.0",
"product": "Xeon 5600 Series Integrated Memory Controller Channel 0 Control",
"product_id": "2da0",
"iommu_group": 0,
"vpd": {}
"driver": "",
"numa_node": 0,
"pci_address": "0000:3e:04.1",
"product": "Xeon 5600 Series Integrated Memory Controller Channel 0 Address",
"product_id": "2da1",
"iommu_group": 0,
"vpd": {}
"driver": "",
"numa_node": 0,
"pci_address": "0000:3e:04.2",
"product": "Xeon 5600 Series Integrated Memory Controller Channel 0 Rank",
"product_id": "2da2",
"iommu_group": 0,
"vpd": {}
"driver": "",
"numa_node": 0,
"pci_address": "0000:3e:04.3",
"product": "Xeon 5600 Series Integrated Memory Controller Channel 0 Thermal Control",
"product_id": "2da3",
"iommu_group": 0,
"vpd": {}
"driver": "",
"numa_node": 0,
"pci_address": "0000:3e:05.0",
"product": "Xeon 5600 Series Integrated Memory Controller Channel 1 Control",
"product_id": "2da8",
"iommu_group": 0,
"vpd": {}
"driver": "",
"numa_node": 0,
"pci_address": "0000:3e:05.1",
"product": "Xeon 5600 Series Integrated Memory Controller Channel 1 Address",
"product_id": "2da9",
"iommu_group": 0,
"vpd": {}
"driver": "",
"numa_node": 0,
"pci_address": "0000:3e:05.2",
"product": "Xeon 5600 Series Integrated Memory Controller Channel 1 Rank",
"product_id": "2daa",
"iommu_group": 0,
"vpd": {}
"driver": "",
"numa_node": 0,
"pci_address": "0000:3e:05.3",
"product": "Xeon 5600 Series Integrated Memory Controller Channel 1 Thermal Control",
"product_id": "2dab",
"iommu_group": 0,
"vpd": {}
"driver": "",
"numa_node": 0,
"pci_address": "0000:3e:06.0",
"product": "Xeon 5600 Series Integrated Memory Controller Channel 2 Control",
"product_id": "2db0",
"iommu_group": 0,
"vpd": {}
"driver": "",
"numa_node": 0,
"pci_address": "0000:3e:06.1",
"product": "Xeon 5600 Series Integrated Memory Controller Channel 2 Address",
"product_id": "2db1",
"iommu_group": 0,
"vpd": {}
"driver": "",
"numa_node": 0,
"pci_address": "0000:3e:06.2",
"product": "Xeon 5600 Series Integrated Memory Controller Channel 2 Rank",
"product_id": "2db2",
"iommu_group": 0,
"vpd": {}
"driver": "",
"numa_node": 0,
"pci_address": "0000:3e:06.3",
"product": "Xeon 5600 Series Integrated Memory Controller Channel 2 Thermal Control",
"product_id": "2db3",
"iommu_group": 0,
"vpd": {}
"driver": "",
"numa_node": 0,
"pci_address": "0000:3f:00.0",
"iommu_group": 0,
"vpd": {}
"driver": "",
"numa_node": 0,
"pci_address": "0000:3f:00.1",
"iommu_group": 0,
"vpd": {}
"driver": "",
"numa_node": 0,
"pci_address": "0000:3f:02.0",
"iommu_group": 0,
"vpd": {}
"driver": "",
"numa_node": 0,
"pci_address": "0000:3f:02.1",
"iommu_group": 0,
"vpd": {}
"driver": "",
"numa_node": 0,
"pci_address": "0000:3f:02.2",
"iommu_group": 0,
"vpd": {}
"driver": "",
"numa_node": 0,
"pci_address": "0000:3f:02.3",
"iommu_group": 0,
"vpd": {}
"driver": "",
"numa_node": 0,
"pci_address": "0000:3f:02.4",
"iommu_group": 0,
"vpd": {}
"driver": "",
"numa_node": 0,
"pci_address": "0000:3f:02.5",
"iommu_group": 0,
"vpd": {}
"driver": "",
"numa_node": 0,
"pci_address": "0000:3f:03.0",
"iommu_group": 0,
"vpd": {}
"driver": "",
"numa_node": 0,
"pci_address": "0000:3f:03.1",
"iommu_group": 0,
"vpd": {}
"driver": "",
"numa_node": 0,
"pci_address": "0000:3f:03.2",
"iommu_group": 0,
"vpd": {}
"driver": "",
"numa_node": 0,
"pci_address": "0000:3f:03.4",
"iommu_group": 0,
"vpd": {}
"driver": "",
"numa_node": 0,
"pci_address": "0000:3f:04.0",
"iommu_group": 0,
"vpd": {}
"driver": "",
"numa_node": 0,
"pci_address": "0000:3f:04.1",
"iommu_group": 0,
"vpd": {}
"driver": "",
"numa_node": 0,
"pci_address": "0000:3f:04.2",
"iommu_group": 0,
"vpd": {}
"driver": "",
"numa_node": 0,
"pci_address": "0000:3f:04.3",
"iommu_group": 0,
"vpd": {}
"driver": "",
"numa_node": 0,
"pci_address": "0000:3f:05.0",
"iommu_group": 0,
"vpd": {}
"driver": "",
"numa_node": 0,
"pci_address": "0000:3f:05.1",
"iommu_group": 0,
"vpd": {}
"driver": "",
"numa_node": 0,
"pci_address": "0000:3f:05.2",
"iommu_group": 0,
"vpd": {}
"driver": "",
"numa_node": 0,
"pci_address": "0000:3f:05.3",
"iommu_group": 0,
"vpd": {}
"driver": "",
"numa_node": 0,
"pci_address": "0000:3f:06.0",
"iommu_group": 0,
"vpd": {}
"driver": "",
"numa_node": 0,
"pci_address": "0000:3f:06.1",
"iommu_group": 0,
"vpd": {}
"driver": "",
"numa_node": 0,
"pci_address": "0000:3f:06.2",
"iommu_group": 0,
"vpd": {}
"driver": "",
"numa_node": 0,
"pci_address": "0000:3f:06.3",
"iommu_group": 0,
"vpd": {}
"total": 92
"system": {
"uuid": "37333336-3637-5a43-4a31-353030484a35",
"vendor": "HP",
"product": "ProLiant DL360 G7",
"family": "ProLiant",
"version": "",
"sku": "633776-421",
"serial": "CZJ1500HJ5",
"type": "physical",
"firmware": {
"vendor": "HP",
"date": "08/16/2015",
"version": "P68"
"chassis": {
"vendor": "HP",
"type": "Rack Mount Chassis",
"version": ""
"motherboard": {
"vendor": "",
"product": "",
"serial": "",
"version": ""
"networks": {
"enp3s0f0": {
"addresses": [
"family": "inet",
"address": "192.168.1.158",
"netmask": "24",
"scope": "global"
"family": "inet6",
"address": "fe80::e611:5bff:fed6:8694",
"netmask": "64",
"scope": "link"
"counters": {
"bytes_received": 523123999,
"bytes_sent": 12416410,
"packets_received": 344933,
"packets_sent": 174660
"hwaddr": "e4:11:5b:d6:86:94",
"mtu": 1500,
"state": "up",
"type": "broadcast",
"bond": null,
"bridge": null,
"vlan": null,
"ovn": null
"enp3s0f1": {
"addresses": [],
"counters": {
"bytes_received": 0,
"bytes_sent": 0,
"packets_received": 0,
"packets_sent": 0
"hwaddr": "e4:11:5b:d6:86:96",
"mtu": 1500,
"state": "up",
"bond": null,
"bridge": null,
"vlan": null,
"ovn": null
"enp4s0f0": {
"addresses": [],
"counters": {
"bytes_sent": 0,
"packets_sent": 0
"hwaddr": "e4:11:5b:d6:86:7c",
"mtu": 1500,
"state": "up",
"bond": null,
"bridge": null,
"vlan": null,
"ovn": null
"enp4s0f1": {
"addresses": [],
"counters": {
"bytes_sent": 0,
"packets_sent": 0
"hwaddr": "e4:11:5b:d6:86:7e",
"mtu": 1500,
"state": "up",
"bond": null,
"bridge": null,
"vlan": null,
"ovn": null
"lo": {
"addresses": [
"family": "inet",
"address": "127.0.0.1",
"netmask": "8",
"scope": "local"
"family": "inet6",
"address": "::1",
"netmask": "128",
"scope": "local"
"counters": {
"bytes_received": 17301,
"bytes_sent": 17301,
"packets_received": 192,
"packets_sent": 192
"hwaddr": "",
"mtu": 65536,
"state": "up",
"type": "loopback",
"bond": null,
"bridge": null,
"vlan": null,
"ovn": null
