Hi @sparkiegeek, thank you. I totally missed the block-device section. That could help if manual assignment is needed.
Regarding the auto-defined tags, after some double checking, it seems that the commissioning step 50-maas-01-commissioning is generating incorrect storage info such as a random serial and it’s missing the rpm for the virtual disk (behind raid controller) and the HDDs.
The commissioning step maas-lshw generates the correct info, but is not used for some reason. I have added screenshot of storage after commission and outputs from both 50-maas-01-commissioning and maas-lshw below.
What is MAAS doing wrong here and how can I fix it?
Virtual disk/RAID controller sda
"id": "sda",
"device": "8:0",
"model": "MR9341-4i",
"type": "scsi",
"read_only": false,
"size": 239511535616,
"removable": false,
"numa_node": 0,
"device_path": "pci-0000:af:00.0-scsi-0:2:0:0",
"block_size": 4096,
"firmware_version": "4.68",
"rpm": 0,
"serial": "600605b00f3de51025a8b05005448efc",
"device_id": "wwn-0x600605b00f3de51025a8b05005448efc",
"partitions": []
lshw
<node id="scsi:0" claimed="true" class="storage">
<physid>af</physid>
<logicalname>scsi0</logicalname>
<node id="disk" claimed="true" class="disk" handle="SCSI:00:02:00:00">
<description>SCSI Disk</description>
<product>MR9341-4i</product>
<vendor>AVAGO</vendor>
<physid>2.0.0</physid>
<businfo>scsi@0:2.0.0</businfo>
<logicalname>/dev/sda</logicalname>
<dev>8:0</dev>
<version>4.68</version>
<serial>00fc8e440550b0a82510e53d0fb00506</serial>
<size units="bytes">239511535616</size>
<configuration>
<setting id="ansiversion" value="5" />
<setting id="logicalsectorsize" value="512" />
<setting id="sectorsize" value="4096" />
</configuration>
<hints>
<hint name="bus.icon" value="scsi" />
<hint name="icon" value="disc" />
</hints>
</node>
</node>
HDD sdb
"id": "sdb",
"device": "8:16",
"model": "ST16000NM001G-2K",
"type": "scsi",
"read_only": false,
"size": 16000900661248,
"removable": false,
"numa_node": 0,
"device_path": "pci-0000:3b:00.0-sas-exp0x500304801eed80ff-phy0-lun-0",
"block_size": 4096,
"firmware_version": "SN02",
"rpm": 0,
"serial": "5000c500c38dd1d1",
"device_id": "wwn-0x5000c500c38dd1d1",
"partitions": []
lshw
<node id="scsi:1" claimed="true" class="storage">
<physid>b0</physid>
<logicalname>scsi5</logicalname>
<node id="disk:0" claimed="true" class="disk" handle="SCSI:05:00:00:00">
<description>ATA Disk</description>
<product>ST16000NM001G-2K</product>
<physid>0.0.0</physid>
<businfo>scsi@5:0.0.0</businfo>
<logicalname>/dev/sdb</logicalname>
<dev>8:16</dev>
<version>SN02</version>
<serial>ZL21LG4J</serial>
<size units="bytes">16000900661248</size>
<capacity units="bytes">16000900661248</capacity>
<configuration>
<setting id="ansiversion" value="6" />
</configuration>
<capabilities>
<capability id="7200rpm" >7200 rotations per minute</capability>
</capabilities>
<hints>
</hints>
</node>
</node>
NVMe nvme0n1
"id": "nvme0n1",
"device": "259:0",
"model": "Micron_9300_MTFDHAL3T2TDR",
"type": "nvme",
"read_only": false,
"size": 3200631791616,
"removable": false,
"wwn": "eui.000000000000000100a0750128fbee3c",
"numa_node": 0,
"device_path": "pci-0000:18:00.0-nvme-1",
"block_size": 512,
"firmware_version": "11300DN0",
"rpm": 0,
"serial": "202628FBEE3C",
"device_id": "nvme-eui.000000000000000100a0750128fbee3c",
"partitions": []
lshw
<node id="storage" claimed="true" class="storage" handle="PCI:0000:18:00.0" modalias="pci:v00001344d000051B2sv00001344sd00004000bc01sc08i02">
<description>Non-Volatile memory controller</description>
<product>Micron Technology Inc</product>
<vendor>Micron Technology Inc</vendor>
<physid>0</physid>
<subproduct>Micron Technology Inc</subproduct>
<subvendor>Micron Technology Inc</subvendor>
<businfo>pci@0000:18:00.0</businfo>
<version>02</version>
<width units="bits">64</width>
<clock units="Hz">33000000</clock>
<configuration>
<setting id="driver" value="nvme" />
<setting id="latency" value="0" />
</configuration>
<capabilities>
<capability id="storage" />
<capability id="pm" >Power Management</capability>
<capability id="msi" >Message Signalled Interrupts</capability>
<capability id="msix" >MSI-X</capability>
<capability id="pciexpress" >PCI Express</capability>
<capability id="nvm_express" />
<capability id="bus_master" >bus mastering</capability>
<capability id="cap_list" >PCI capabilities listing</capability>
<capability id="rom" >extension ROM</capability>
</capabilities>
<resources>
<resource type="irq" value="82" />
<resource type="memory" value="aae20000-aae23fff" />
<resource type="memory" value="aae00000-aae1ffff" />
</resources>
<hints>
<hint name="pci.class" value="0x108" />
<hint name="pci.device" value="0x51B2" />
<hint name="pci.subdevice" value="0x4000" />
<hint name="pci.subvendor" value="0x1344" />
<hint name="pci.vendor" value="0x1344" />
</hints>
<node id="nvme0" claimed="true" class="storage">
<description>NVMe device</description>
<product>Micron_9300_MTFDHAL3T2TDR</product>
<physid>0</physid>
<logicalname>/dev/nvme0</logicalname>
<version>11300DN0</version>
<serial>202628FBEE3C</serial>
<configuration>
<setting id="nqn" value="nqn.2016-08.com.micron:nvme:nvm-subsystem-sn-202628FBEE3C" />
<setting id="state" value="live" />
</configuration>
<node id="namespace" claimed="true" class="disk">
<description>NVMe namespace</description>
<physid>1</physid>
<logicalname>/dev/nvme0n1</logicalname>
<size units="bytes">3200631791616</size>
<configuration>
<setting id="sectorsize" value="512" />
</configuration>
<hints>
</hints>
</node>
</node>
</node>
</node>
