*Errors or typos? Topics missing? Hard to read? Let us know.
Administrators can manage MAAS resource pools to group machines in sensible ways. All MAAS installations have a resource pool named “default,” to which MAAS automatically adds new machines.
Add a resource pool
To add a resource pool to MAAS:
In the MAAS 3.4 UI, choose Organisation > Pools > Add pool; enter Name and Description; select Save pool.
With the UI in all other versions of MAAS, choose Resource > Add pool; enter Name and Description; select Add pool.
Via the MAAS CLI, use the following command:
maas $PROFILE resource-pools create name=$NAME description="$DESCRIPTION"
Delete a resource pool
If you delete a resource pool, all machines that belong to that resource pool will return to the default pool. There is no confirmation dialogue; pools are deleted immediately. To delete a resource pool:
In the MAAS 3.4 UI, choose Organisation > Pools > trash can > Delete.
With the UI in all other versions of MAAS, choose Resource > (trash can) > Delete.
Add a machine to a pool
To add a machine to a resource pool:
In the MAAS 3.4 UI, choose Machines > (machine) > Categorise > Set pool > Select pool > Resource pool > Set pool.
With the UI in all other versions of MAAS, choose Machines > (machine) > Configuration (resource pool) > Save changes.
Remove a machine from a pool
To remove a machine from a resource pool:
In the MAAS 3.4 UI, choose Machines > (machine) > Categorise > Set pool > Select pool > Resource pool >“default” > Set pool.
With the UI in all other versions of MAAS, choose Machines > (machine) > Configuration > “default” > Save changes.
maas $PROFILE machine update $SYSTEM_ID pool="default"
Add a VM host to a pool
To add a VM host to a resource pool:
- In the MAAS 3.4 UI, choose KVM > LXD > (VM host) > KVM host settings > Resource pool > Save changes.
With the UI in all other versions of MAAS, you can add a VM host to a resource pool when you create a new VM host, or you can edit the VM host’s configuration:
- Via the MAAS CLI, use the following command:
Remove a VM host from a pool
To remove a VM host from a resource pool:
In the MAAS 3.4 UI, choose KVM > LXD > (VM host) > KVM host settings > Resource pool > “default” > Save changes.
With the UI in all other versions of MAAS, edit the VM host’s configuration and assign it to the “default” resource pool:
List resource pools (CLI)
List a single pool
Update a pool
The
descriptionfield is optional.
