MAAS logs considerable runtime information to standard log files, useful when things don’t work as expected. Prior to version 3.5, MAAS used custom log files for different components of the MAAS architecture. In version 3.5, all logging has been transferred to the standard systemd logs. This page gives a summary of how to access runtime logging for both version groups.
MAAS 3.5 log commands
Pebble (snap-only)
journalctl -u snap.maas.pebble -t maas.pebble
Regiond (ex-regiond.log)
For the snap, use:
journalctl -u snap.maas.pebble -t maas-regiond
For the debian packages, use:
journalctl -u maas-regiond
Rackd (ex-rackd.log)
For the snap, use::
journalctl -u snap.maas.pebble -t maas-rackd
journalctl -u maas-rackd
MAAS Agent
For the snap, use::
journalctl -u snap.maas.pebble -t maas-agent
journalctl -u maas-agent
maas.log
For the snap, use::
journalctl -u snap.maas.pebble -t maas-log
journalctl -u maas-syslog -t maas-log
API server
For the snap, use::
journalctl -u snap.maas.pebble -t maas-apiserver
journalctl -u maas-apiserver
Temporal
For the snap, use::
journalctl -u snap.maas.pebble -t maas-temporal
journalctl -u maas-temporal
HTTP (nginx)
For the snap, use::
journalctl -u snap.maas.pebble -t maas-http
journalctl -u maas-http
Proxy (squid)
For the snap, use::
journalctl -u snap.maas.pebble -t maas-proxy
journalctl -u maas-proxy
NTP (chrony)
For the snap, use::
journalctl -u snap.maas.pebble -t chronyd
journalctl -u chrony
DNS (bind9)
For the snap, use::
journalctl -u snap.maas.pebble -t named
journalctl -u named
Syslog (rsyslog)
For the snap, use::
journalctl -u snap.maas.pebble -t maas-machine
- Fields to filter over:
- MAAS_MACHINE_IP
- MAAS_MACHINE_HOSTNAME
- MAAS_MACHINE_SYSLOG_TAG
- MAAS_MACHINE_PID (to filter over remote machine process IDs)
- MAAS_MACHINE_TIMESTAMP (to troubleshoot possible time sync issues)
For example, if using the snap, use a command like this:
journalctl -u snap.maas.pebble -t maas-machine --since "-15m" MAAS_MACHINE_HOSTNAME=ace-cougar MAAS_MACHINE_SYSLOG_TAG=systemd
On the other hand, if using debian packages, use a command similar to:
journalctl -u maas-syslog -t maas-machine --since "-15m" MAAS_MACHINE_HOSTNAME=ace-cougar MAAS_MACHINE_SYSLOG_TAG=systemd
DHCP (dhcpd, dhcpd6)
For the snap, use::
journalctl -u snap.maas.pebble -t dhcpd
journalctl -u maas-dhcpd
Pre-3.5 log commands
Supervisor (snap-only)
For the snap, use:
less /var/snap/maas/common/log/supervisor-run.log
journalctl -u snap.maas.supervisor
Regiond
For the snap, use:
less /var/snap/maas/common/log/regiond.log
less /var/log/maas/regiond.log
Rackd
For the snap, use::
less /var/snap/maas/common/log/rackd.log
less /var/log/maas/rackd.log
maas.log
For the snap, use::
less /var/snap/maas/common/log/maas.log
less /var/log/maas/maas.log
HTTP (nginx)
For the snap, use::
less /var/snap/maas/common/log/http/access.log (or error.log)
less /var/snap/maas/common/log/nginx.log
less /var/log/maas/http/access.log (or error.log)
Proxy (squid)
For the snap, use::
less /var/snap/maas/common/log/proxy/access.log (or cache.log or storage.log)
less /var/log/maas/proxy/access.log (or cache.log or storage.log)
NTP (chrony)
DNS (bind9)
For the snap, use::
less /var/snap/maas/common/log/named.log
journalctl -u named
Syslog (rsyslog)
For the snap, use::
less /var/snap/maas/common/log/rsyslog.log
less /var/snap/maas/common/log/rsyslog/MACHINE_HOSTNAME/DATE/messages
less /var/log/maas/rsyslog/MACHINE_HOSTNAME/DATE/messages
For the snap, use::
less /var/snap/maas/common/log/dhcpd.log
journalctl -u dhcpd
