How to upgrade from PostgreSQL v14 to v16
Starting with MAAS 3.6, you must upgrade PostgreSQL from version 14 to version 16. This guide will explain the process.
Create a data backup
Backup all existing data: optional, but strongly advised.
    sudo -u postgres pg_dumpall > backup.sql
Perform the upgrade
If you’re running PostgreSQL v14 on your MAAS machine, you must upgrade before installing MAAS version 3.6.
Install PostgreSQL 16.
    sudo apt update
    sudo apt install -y postgresql-common
    sudo /usr/share/postgresql-common/pgdg/apt.postgresql.org.sh
    sudo apt-get install -y postgresql-16 postgresql-server-dev-16
Create and initialize a PostgreSQL 16 instance
Follow the PostgreSQL setup documentation, as server configurations vary.
Halt the old server
Migrate the configuration files
The pg_upgrade command will write some files in the directory of execution. This command must be run by the postgres user, so run it a permitted directory (such as /tmp).
    cd /tmp
    # copy the data, bin and config files from the new to the old version
    sudo -u postgres /usr/lib/postgresql/16/bin/pg_upgrade \
    --old-datadir=/var/lib/postgresql/14/main \
    --new-datadir=/var/lib/postgresql/16/main \
    --old-bindir=/usr/lib/postgresql/14/bin \
    --new-bindir=/usr/lib/postgresql/16/bin \
    --old-options '-c config_file=/etc/postgresql/14/main/postgresql.conf' \
    --new-options '-c config_file=/etc/postgresql/16/main/postgresql.conf'
Reconfigure the server ports
The current version of PostgreSQL should generally use port 5432.
    sudo vim /etc/postgresql/16/main/postgresql.conf # Set port to 5432
    sudo vim /etc/postgresql/14/main/postgresql.conf # Set port to 5433
Activate the new server and verify version
Always check to make sure you are running the version you expect.
    sudo -u postgres psql -c "SELECT version();"
Complete the upgrade
Vacuum the database to clean it up before using it routinely.
    sudo -u postgres /usr/lib/postgresql/16/bin/vacuumdb --all --analyze-in-stages
Delete the old version
First, remove the old packages:
    sudo apt remove -y postgresql-14 postgresql-server-dev-14
Finally, delete configuration files and data from the old version:
    sudo rm -rf /etc/postgresql/14/
    sudo -u postgres /tmp/delete_old_cluster.sh
This completes the upgrade from PostgreSQL v14 to v16.
This command didn’t worked for me since the data directory for version 16 wasn’t existing.
Instead, I ran
pg_upgradecluster 14 main
and after successful verification of upgrade, I ran
pg_dropcluster 14 main
These documented commands are overly complex when the Debian packaging for PostgreSQL provides a simple 2-step command as also shown above. It’s much faster and simpler, I am not sure why we are documenting the complex version.
This document and the 12-to-14 document should be updated. Additionally ideally MAAS would simply punch out to generic docs rather than duplicating them, e.g. if we wanted to account for non-Ubuntu postgres installs or something. Though these commands are basically for the Ubuntu package anyway.
It also pops up these suggested commands and to read /usr/share/doc/postgresql-common/README.Debian.gz during the distro upgrade process.
