Does anyone have an idea on how I can test upgrading MAAS with data from my production instance?
Hi @zmance .
Could you clarify what do you mean by “test”?
Hi @zmance
You can create a backup of your existing MAAS installation, then upgrade to a new version and in case of any issues you can always restore from the backup.
Yes, it’s enough to make the snapshot of maas and dump the db
