I have a MAAS installed on a machine with two NICs, one for public and one for private network. Currently, I’ve blocked all external traffic for MAAS ports but I still prefer If I can set IP or NIC for MAAS to bind. So Any suggestions on how to do it? BTW MAAS has been installed via snap (version stable/3.0)
Hi, currently MAAS doesn’t provide a way to specify on which interfaces to bind services.
Ideally, the maas machine shouldn’t directly exposed on the internet, but if this is your case setting up a firewall to disallow external access as you did is your best option.
Another option could be to run MAAS in a container or VM with an interface directly connected to the internal NIC (via linux bridge or MACVLAN), in which case MAAS would only see the internal network.
