How to secure MAAS (deb/3.0/UI)
As a MAAS administrator, you have the critical responsibility of hardening your installation to help repudiate attacks and malicious actors. While there are too many variables to make meaningful suggestions for your deployed machines, there are a number of steps you can take to improve the overall security of your MASS setup. This article provides a few suggestions.
Six questions you may have:
  1. How do I setup a firewall for MAAS?
  2. How do I configure a TLS-terminating load balancer (and what’s the impact on my MAAS setup?)
  3. How do I use logs to identify security issues?
  4. How do I implement PostgreSQL security?
  5. What else can I do to harden MAAS?
  6. Whom do I contact for MAAS security consulting?
Use a firewall
Port(s) Description
Consider setting your firewall
on your rack and region controllers to disallow communication on all ports except those used by MAAS. For example, assuming you have installed ufw, you could execute:
sudo ufw enable
sudo ufw allow 5240
sudo ufw allow 5248
sudo ufw allow 5241:5247/tcp
sudo ufw allow 5241:5247/udp
sudo ufw allow 5250:5270/tcp
sudo ufw allow 5250:5270/udp
Recognise that your particular configuration and version may vary, so consult the appropriate firewall manual pages for your specific MAAS host system.
One of the best steps you can take to improve both security and availability of your MAAS installation is to install TLS-terminating load balancer. For MAAS, we recommend using HAProxy
. This section explains how to set one up.
In the context of MAAS, a load balancer
distributes the incoming Web UI and API requests across multiple region controllers. This reduces both load on MAAS and wait times for user requests. Typically, this is known as a high-availability (HA) configuration, although there are two other HA configurations that can be enabled for MAAS: one for BMC access (for powering on machines), and one for DHCP, which enables primary and secondary DHCP instances that manage the same VLAN.
TLS is meant to provide privacy and data integrity between two or more applications. Privacy is provided by symmetric cryptography
, based on a shared secret and uniquely-generated keys negotiated at the start of a session (during the TLS handshake ). Identity of each app can be authenticated, though this feature can be optional. Authenticity of messages is ensured by using message authentication codes to detect tampering.
PEM file
sudo apt-get update
sudo apt-get install haproxy
option forwardfor
option http-server-close
frontend maas
    retries 3
    option redispatch
    default_backend maas
backend maas
    timeout server 90s
    balance source
    hash-type consistent
Note that you can also enable HAProxy logging
if desired. This logging is an optional feature of the HAProxy tool and is thus left to your discretion.
  1. firewall logs
  2. Web server logs
  3. MAAS log files
  4. system log files
This section will offer some advice, as well as links to more detailed information on these categories.
Firewall logs
The Ubuntu firewall, UFW
, is a front-end for iptables , so the UFW log output is very similar to what you’ll encounter in iptables itself. If you want to secure your MAAS installation, it’s very important to periodically review your UFW logs, found in /var/log/ufw*.
Learning to recognise issues in the UFW/iptables log is an art form, so we’re not going to give an extended tutorial here. Still, there are some key indicators that might help you spot security issues.
You can also compare attempts on unusual port numbers against well-known hacker tools . For instance, repeated attempts against port 12361 might mean that someone is attempting to attack with the Whack-a-mole exploit.
Review the IP addresses that are being rejected and dropped. Try to identify them with a ping -a <IP address>. Spoofed addresses won’t have an owner (and you can block them). Real addresses have a whois entry, so it’s possible you can contact the ISP to report and resolve this issue.
There are many other firewall log analysis techniques, and a number of good open-source and commercial log analysis programs. If you decide to analyse directly, though, you’re basically looking for blocked connection issues, connections to (potentially) open ports you’re not using, and suspicious-looking outbound connections.
Web server logs
Detecting malicious activity directed toward your Web server is best done with a log analysis tool. If you want to review the raw logs directly, you can look for them in two places:
  1. /var/log/httpd/, /var/log/apache, or /var/log/apache2 (in the case of Apache), or
  2. the path given in /etc/nginx/nginx.conf or given in your site configuration file, which itself is found at the path /etc/nginx/sites-available (in the case of nginx – look for the access_log directive).
  1. multiple requests in less than one second, or some other appropriate time-frame.
  2. multiple secure/login page accesses in a one-minute window, especially when they fail.
  3. attempts to access non-existent pages using different paths or query parameters (e.g., 135.25.48.19:5250/maas/index.html).
  4. look out for SQL injection attacks, for example:
    3.5.30729)”
  5. attempts to run a Web shell, for instance:
MAAS log files
Presently, your primary use of MAAS log files to improve security is to periodically check log files for login failures. You can check for this activity in the regiond.log file, found at /var/log/maas/regiond.log. For reference, a valid login request looks like this entry:
Safari/537.36)````
Safari/537.36)````
System log files
As mentioned, this subject is far too complex for a detailed tutorial in this section. For more information, try the Ubuntu journalctl manpage or another, similar source
Implement PostgreSQL security
PostgreSQL contains secrets, and should be encrypted for maximum protection. You should consider full disk encryption
. Also recommended is TLS encryption between MAAS and PostgreSQL .
Good passwords
File permissions
After:
Shared secrets
If you need help implementing MAAS security, please contact us. We will be happy to assist you in arranging security consulting appropriate to your needs.
