How to Run different provisioning scripts during deploy (tags?)
Is there a way to, maybe by tag, run different provisioning scripts?
Say I am deploying bionic.
If I have a ‘desktop-mate’ tag, maybe it will do
sudo add-apt-repository universe && sudo apt install ubuntu-mate-desktop^…
If I have a ‘upgrade’ command it will
sudo apt-get upgrade -y
Et cetera.
Possible?
Thanks!
perhaps the tags could be made available as env vars to the provisioning scripts?
Use case that you’re describing is better suited to third party software (could be a simple ansible type script) using the MAAS API to discover tags on machines and then invoking commands via SSH
