maas-dhcpd and maas-rackd are not shown under either service nor snap services.
What MAAS version are you running?
Can you verify whether there are any errors cropping up in your MAAS logs that might suggest why these services haven’t started?
MAAS 3.4.1-14343-g.a552d2522
rackd.log
2024-02-28 16:32:07 twisted.internet.unix: [info] (Port '/var/snap/maas/common/maas/dhcpd.sock' Closed)
2024-02-28 16:32:08 provisioningserver.rpc.clusterservice: [info] Lost all connections to region controllers. Stopping service(s) dhcpd.
2024-03-05 01:44:35 twisted.internet.unix: [info] (Port '/var/snap/maas/common/maas/dhcpd.sock' Closed)
2024-03-05 01:44:35 provisioningserver.rpc.clusterservice: [info] Lost all connections to region controllers. Stopping service(s) dhcpd.
2024-03-12 16:59:46 twisted.internet.unix: [info] (Port '/var/snap/maas/common/maas/dhcpd.sock' Closed)
2024-03-12 16:59:46 provisioningserver.rpc.clusterservice: [info] Lost all connections to region controllers. Stopping service(s) dhcpd.
2024-03-12 23:24:47 twisted.internet.unix: [info] (Port '/var/snap/maas/common/maas/dhcpd.sock' Closed)
2024-03-12 23:24:47 provisioningserver.rpc.clusterservice: [info] Lost all connections to region controllers. Stopping service(s) dhcpd.
2024-03-13 20:39:46 twisted.internet.unix: [info] (Port '/var/snap/maas/common/maas/dhcpd.sock' Closed)
2024-03-13 20:39:46 provisioningserver.rpc.clusterservice: [info] Lost all connections to region controllers. Stopping service(s) dhcpd.
2024-03-20 09:59:47 twisted.internet.unix: [info] (Port '/var/snap/maas/common/maas/dhcpd.sock' Closed)
2024-03-20 09:59:47 provisioningserver.rpc.clusterservice: [info] Lost all connections to region controllers. Stopping service(s) dhcpd.
2024-03-20 11:06:11 twisted.internet.unix: [info] (Port '/var/snap/maas/common/maas/dhcpd.sock' Closed)
2024-03-20 11:10:15 twisted.internet.unix: [info] (Port '/var/snap/maas/common/maas/dhcpd.sock' Closed)
2024-03-20 11:11:14 twisted.internet.unix: [info] (Port '/var/snap/maas/common/maas/dhcpd.sock' Closed)
2024-03-20 11:11:56 twisted.internet.unix: [info] (Port '/var/snap/maas/common/maas/dhcpd.sock' Closed)
2024-03-20 11:44:43 twisted.internet.unix: [info] (Port '/var/snap/maas/common/maas/dhcpd.sock' Closed)
2024-03-20 11:56:11 twisted.internet.unix: [info] (Port '/var/snap/maas/common/maas/dhcpd.sock' Closed)
2024-03-20 12:06:14 twisted.internet.unix: [info] (Port '/var/snap/maas/common/maas/dhcpd.sock' Closed)
2024-03-20 12:18:14 twisted.internet.unix: [info] (Port '/var/snap/maas/common/maas/dhcpd.sock' Closed)
regiond.log and rackd.log does not provide any helpful information.
Can you please also check journalctl -u dhcpd?
$ journalctl -u dhcpd
-- No entries --
$ service dhcpd status
Unit dhcpd.service could not be found.
sudo systemctl status maas-dhcpd.service
Perhaps?
There are no services such as ‘isc-dhcp-server’, ‘maas-dhcpd’, ‘dhcpd’…etc.
Nevermind, Finally the problem has been resolved by snap remove maas --purge and then reinstalling MAAS based on the same PostgreSQL database.
