How to manage VMs (snap/2.9/CLI)
If you have already created a VM host, you will want to create and delete virtual machines (VMs); this article will explain:
How to add a VM
To compose a basic VM:
    "system_id": "73yxmc",
How to set resources while adding a VM
Where $RESOURCES is a space-separated list of six constraints:
  1. cores= requested cores
  2. cpu_speed= requested minimum cpu speed in MHz
  3. memory= requested memory in MB
  4. architecture= See Architecture below
  5. storage= See Storage below
  6. interfaces= See Interfaces below
How to set the architecture while adding a VM
Then, for example:
How to set storage parameters while adding a VM
For example, let’s examine how to compose a machine with the following two disks:
  1. 32 GB disk from storage pool pool1
  2. 64 GB disk from storage pool pool2
where we want the first disk to be a bootable root partition / and the second to be a home directory.
First, create the VM:
MAAS will create a VM with 2 disks, /dev/vda (32 GB) and /dev/vdb (64 GB). After MAAS enlists, commissions and acquires the machine, you can edit the disks before deploying to suit your needs. For example, we’ll set a boot, root, and home partition.
We’ll start by deleting the / partition MAAS created because we want a separate /boot partition to demonstrate how yo.
maas admin partition mount $SYSTEM_ID $DISK1_ID $BOOT_PARTITION_ID     "mount_point=/boot"
How to specify interfaces while adding a VM
interfaces=eth0:space=maas;eth1:space=storage
MAAS automatically converts the ip constraint to a VLAN constraint (matching the VLAN which corresponds to the subnet can be found – e.g. 172.16.99.0/24.) and assigns the IP address to the newly-composed machine upon allocation.
See the Machines MAAS API documentation for a list of all constraint keys.
How to find a VM host ID
maas $PROFILE vm-hosts read | jq '.[] | select (.name=="MyVMHost") | .name, .id'
Example output:
"MyVMHost"
1
How to delete a VM
After you delete a machine, its resources will be available for other VMs.
