How to manage users, groups and entitlements
MAAS 3.8 introduces a new relationship-based access control (ReBAC) system for managing users, groups, and permissions. This replaces the previous Canonical RBAC integration, which is deprecated in 3.8 and removed in MAAS 4.0.
This guide explains how the access control model works and how to use user groups and entitlements to control access to MAAS resources. For full CLI command syntax, see the user-group CLI reference.
How access control works
MAAS access control is built around three concepts:
  • Users - individual accounts that authenticate with MAAS.
  • Groups - collections of users. Permissions are always granted to groups, not to individual users.
  • Entitlements - permissions assigned to a group for a specific resource. An entitlement defines what a group can do with a resource.
The access model follows the chain: user → group → entitlement → resource. A user has a permission only if they belong to a group that holds the corresponding entitlement.
Default groups
MAAS creates two built-in groups:
Group Description
Administrators Full access to all resources.
Users Can view available machines, deploy them, and view global entities.
When you create a user through the users endpoint or the createadmin command, MAAS automatically assigns them to the appropriate default group: admins are added to Administrators and regular users to Users. You can modify or delete these default groups. If you delete and recreate the default groups with the same name, MAAS will still automatically assign users to them based on their admin status.
Entitlements and permissions
Entitlements are scoped to a resource type and a resource ID:
Resource type Resource ID Scope
maas Always 0 Global - applies across all resource pools.
pool The resource pool ID Per-pool - applies only to the specified pool.
Permission inheritance
Permissions follow two inheritance rules:
  1. Higher permissions imply lower ones. For any resource, can_edit_* implies can_view_*. For machines specifically, the full hierarchy is:
    can_edit_machines
    ├── can_deploy_machines
    │   └── can_view_machines
    │       └── can_view_available_machines
    ├── can_view_machines
    Other resources follow the same can_edit_* → can_view_* pattern (e.g., can_edit_global_entities implies can_view_global_entities).
  2. MAAS-level machine permissions cascade to pools. If a group has can_view_machines on the maas resource, it automatically has can_view_machines on every resource pool. Pool-level entitlements grant additional access for specific pools only.
Available entitlements
Global (maas) entitlements
Entitlement Description
can_edit_machines Edit machines in every resource pool.
can_deploy_machines Deploy machines in every resource pool.
can_view_machines View all machines in every resource pool.
can_view_available_machines View owned and unowned (available) machines in every resource pool.
can_edit_global_entities Edit domains, DNS records, fabrics, resource pool metadata, spaces, subnets, tags, static routes, and VLANs.
can_view_global_entities View global entities.
can_edit_controllers Edit controllers.
can_view_controllers View controllers.
can_edit_identities Edit users, user groups, permissions, and OIDC providers.
can_view_identities View users, user groups, permissions, and OIDC providers.
can_edit_configurations Edit configurations.
can_view_configurations View configurations.
can_edit_notifications Edit notifications.
can_view_notifications View all notifications.
can_edit_boot_entities Edit boot resources and boot sources.
can_view_boot_entities View boot resources and boot sources.
can_edit_license_keys Edit license keys.
can_view_license_keys View license keys.
can_view_devices View all devices.
can_view_ipaddresses View all IP addresses.
Per-pool (pool) entitlements
can_edit_machines Edit machines in the specified resource pool.
can_deploy_machines Deploy machines in the specified resource pool.
can_view_machines View all machines in the specified resource pool.
can_view_available_machines View owned and unowned (available) machines in the specified resource pool.
Common tasks
Create a group and assign members
  • CLI:
    GROUP_ID=$(maas $PROFILE user-groups create name=developers description="Dev team" | jq '.id')
    maas $PROFILE user-group add-member $GROUP_ID username=alice
    maas $PROFILE user-group add-member $GROUP_ID username=bob
Grant a group access to a specific resource pool
Assuming that the resource pool with ID 2 exists, you can grant a group permissions for that pool. For example, to allow members of group $GROUP_ID to deploy machines in pool 2:
  • CLI:
    maas $PROFILE user-group add-entitlement $GROUP_ID resource_type=pool resource_id=2 entitlement=can_deploy_machines
Grant global read-only access
  • CLI:
    maas $PROFILE user-group add-entitlement $GROUP_ID resource_type=maas resource_id=0 entitlement=can_view_machines
    maas $PROFILE user-group add-entitlement $GROUP_ID resource_type=maas resource_id=0 entitlement=can_view_global_entities
Review a group’s permissions
  • CLI:
    maas $PROFILE user-group list-members $GROUP_ID
    maas $PROFILE user-group list-entitlements $GROUP_ID
Deleting a group removes all of its entitlements. Members are not deleted: they remain as MAAS users.
