MAAS uses resource pools to group machines and VM hosts for better allocation. New machines default to the “default” pool.
Learn more about Resource pools
Add a resource pool
UI:
- MAAS 3.4: Organisation > Pools > Add pool > Enter Name & Description > Save pool.
- Earlier versions: Resource > Add pool > Enter Name & Description > Add pool.
CLI:
maas $PROFILE resource-pools create name=$NAME description="$DESCRIPTION"
Delete a resource pool
UI:
- MAAS 3.4: Organisation > Pools > (trash can) > Delete.
- Earlier versions: Resource > (trash can) > Delete.
CLI:
Add a machine to a pool
UI:
- MAAS 3.4 forward: Machines > Select machine > Categorise > Set pool > Select Resource pool > Set pool.
- Earlier versions: Machines > Select machine > Configuration > Set Resource pool > Save changes.
CLI:
Remove a machine from a pool
UI:
- MAAS 3.4: Same as “Add a machine to a pool,” but select “default” as the resource pool.
- Earlier versions: Machines > (machine) > Configuration > Set pool to “default” > Save changes.
CLI:
maas $PROFILE machine update $SYSTEM_ID pool="default"
List resource pools
CLI:
View a single pool
CLI:
Update a pool
CLI:
descriptionis optional.
