How to manage regions (deb/3.0/UI)
Add a new region host
sudo systemctl restart bind9
  1. /var/log/maas/regiond.log
  2. /var/log/maas/maas.log
  3. /var/log/syslog
Increasing the number of workers will also increase the number of required database connections by 11 per extra worker. This may required PostgreSQL to have an increased number of allowed connections; please see the high availability article for more information on increasing the connections.
num_workers: 8
