How to import images (deb/3.0/CLI)
You can tell MAAS to sync images hourly, at the region level. See Boot image sources) for more details. We highly recommended synching images hourly. Syncing at the rack controller level (from regiond) occurs every 5 min and cannot be disabled.
Eight questions you may have:
  1. How do I get started with the MAAS CLI?
  2. How do I list boot sources?
  3. How do I select images?
  4. How do I list image selections?
  5. How do I import newly-selected images?
  6. How do I list currently available images?
  7. How do I delete a boot source?
  8. How do I edit a boot source?
List boot sources
Select images
    subarches="*" labels="*"
Hardware enablement (HWE)
    subarches="hwe-x" labels="*"
List image selections
Import newly-selected images
Delete a boot source
Edit a boot source
Update the boot source:
Add a boot source
The general syntax is:
Using a local image mirror
  1. URL=https://$MIRROR/maas/images/ephemeral-v3/stable/
  2. KEYRING_FILE=/usr/share/keyrings/ubuntu-cloudimage-keyring.gpg
  1. URL=https://images.maas.io/ephemeral-v3/stable/
