The best place to get help with your MAAS issue is on the MAAS Discourse forum . There, you can interact with the MAAS team as well as search for issues similar to your own.
You might also try the Ask Ubuntu web site.
How to report a bug
MAAS bugs are reported via Launchpad. We’ll provide the link in a moment, but first, some necessary prerequisites.
Filing a good bug report makes all the difference in how quickly we can triage and address your problem. This brief how-to guide will walk you through the steps of filing a bug. Some of these steps are necessary preparation, and the better you prepare before you file, the better the bug report.
Note that in the examples that follow, a >>
symbol indicates the newest line added to the draft report. It isn’t necessary for you to type these characters.
Step 1: Understand what’s required
You need to gather or prepare some information before you file your bug report. Here is the short list of pre-filing tasks that will smooth the process:
- Prepare a concise summary
- Identify your version and build first
- Explain whether you’re using the UI, CLI, or API
- Explain what happens
- Explain how to reproduce your issue
- Take screenshots, if relevant
- Locate and capture logfiles, if at all possible
Open a text editor with a new file, so you can capture and refine this information in advance.
Keep your bug summary short and concise. We recommend something of the form:
<something specific happens> with MAAS <involved feature(s)>
or
MAAS <behaves some unexpected way> when I <try to use a particular feature>
For example:
>>MAAS fails to PXE boot IBM LPAR machines as KVM hosts
Add this information to your text file.
We need to know the version and build (and packaging format) that you’re running.
If you're using a snap
If you’re using a snap, execute snap list maas
at the command line, which will return some lines like this:
maas 3.0.0~beta2-9796-g.2182ab55f 13292 latest/edge canonical✓ -
We want the know the Version
field; in this case, that’s 3.0.0~beta2-9796-g.2182ab55f
. Add a line like this to your text file:
MAAS fails to PXE boot IBM LPAR machine as VM host
>>I'm using snap version/build 3.0.0~beta2-9796-g.2182ab55f.
If you're using a debian package
If you’re using a deb, execute apt list maas
at the command line, and enter whatever it returns into your text file, as in the snap example above, being sure to specify:
I'm using debian package version/build...
Using CLI, UI, or API?
Next, you’ll need to specify which interface you’re using, and generally what command(s) you were attempting. For example:
>>I tried to create a VM host using a previously discovered IBM LPAR machine,
using the MAAS UI.
Being as concise and specific as you can, explain what seemed to go wrong. For example:
using the MAAS UI.
>>I was able to select the machine under "Add KVM," define its parameters,
and select a project. I was also able to push "Authenticate," and the
expected commissioning process began. After the machine powered on, though,
the commissioning process timed out trying to PXE boot the machine. Looking
at the machine, it had indeed been powered on, but nothing happened after that.
In addition to the explanation above, you should create a step-by-step list of what you did to reproduce the problem. For example:
I tried to create a VM host using a previously discovered IBM LPAR machine, using the MAAS UI.
>>Steps to reproduce:
1. Confirm that at least one IBM LPAR 700 model is discovered and in the
Ready state (see screenshot-1).
2. Select the KVM tab (see screenshot-2).
3. Press the "Add KVM" button.
4. Select the KVM host type according to your network (I selected "<selection>").
5. Enter a name for the KVM host (I entered "<entered-name>").
6. Enter a bridge address to reach the KVM host (I entered "<power-address>").
7. Enter the appropriate password.
8. Press the "Authenticate" button.
9. On the project screen which pops up, select the "default" project.
10. Press the "Add KVM" button.
11. Return to the machine list and find the machine you just added as a KVM.
It should show "Powering on."
12. Watch until the machine enters the "Performing PXE boot" stage.
13. Wait for the machine to time out without reaching "Loading ephemeral"
stage, as normal.
14. Examine the logfiles (see attached logfiles).
Take relevant screenshots
If you think it will help – especially when using the UI – try and capture screenshots of any unexpected results or ambiguous actions. Your goal isn’t to document your experience in pictures, but to provide a visual reference where verbal descriptions fall short. Name these so you can sync them with your explanation (e.g., “screenshot-1”). You’ll attach them later on in the process.
If at all possible, capture at least the following logfiles, for the time period surrounding your error situation:
- maas.log
- regiond.log
- rackd.log
- the rsyslog file of the affected machine(s), if it exists.
On snap, these files are located as follows:
- /var/snap/maas/common/log/maas.log
- /var/snap/maas/common/log/regiond.log
- /var/snap/maas/common/log/rackd.log
- /var/snap/maas/common/log/rsyslog/$MACHINE_NAME/$RELEVANT_DATE/messages
If you’re using packages, you’ll find the files in these locations:
- /var/log/maas/maas.log
- /var/log/maas/regiond.log
- /var/log/maas/rackd.log
- /var/log/maas/rsyslog/$MACHINE_NAME/$RELEVANT_DATE/messages
The sosreport tool is a potential shortcut. It’s an automated information-gathering utility that will create a tarball containing MAAS log files, MAAS configuration files and a dump of the MAAS database. It is available in the Ubuntu archives:
sudo apt install -y sosreport
sudo sosreport -o maas
The tarball will end up in /tmp but you can change the location. See the sosreport man page for details. If there are things you do not wish to share publicly, feel free to edit the tarball.
Step 2: Filing your bug
Have your prepared text file handy. In our example, it looks like this:
Steps to reproduce:
stage, as normal.
To file a bug, go to the launchpad bug report page. You’ll see a screen similar to this one:
Enter your concise summary in the “Summary:” line:
Press enter to get to the next screen:
Paste the rest of your text file into the “Further information” box:
Attach your screenshots and logfiles by opening the “Extra options” section and browsing for your attachments. Ideally, you’d attach the files one at a time, with a comprehensible description.
When you’re done, simply choose “Submit Bug Report” and check your work on the screen that follows:
If you want, you can view a sample bug with precisely these parameters.
