This guide explains how to use Terraform to enlist, commission, and deploy a host-DPU pair in MAAS. By the end, you will have a host machine and its attached DPU running Ubuntu, with the DPU properly initialized and ready for workloads.
What is a host-DPU pair?
A data processing unit (DPU) is a PCIe-attached device that offloads networking, storage, and security tasks from the host CPU. From MAAS’s perspective, the host and the DPU are two separate machines that must be provisioned in order. The DPU is powered by the host, so the host must be running before MAAS can commission the DPU.
The Terraform plan described here automates this sequencing: it provisions the host first, waits for deployment to complete, then commissions and deploys the DPU. After the DPU is deployed, the plan power-cycles the host to complete DPU initialization.
Requirements
- MAAS 3.7 or later (DPU support was introduced in 3.7)
- Terraform 1.4.0 or later
- canonical/maas Terraform provider
~> 2.7.3with DPU support - Both the DPU and machine BMC must have Redfish enabled and the account you use must have sufficient permissions.
The Terraform plan
Save the following as main.tf in a new directory, then follow the steps in Deploy the host-DPU pair.
terraform {
required_version = ">= 1.4.0"
required_providers {
maas = {
source = "canonical/maas"
version = "~> 2.7.3"
# == Machine parameters ========================================================
variable "maas_snap_channel" {
description = "MAAS snap channel used by the local-exec power-cycle step"
type = string
default = "3.7/stable"
variable "host_hostname" {
description = "Hostname for the host machine"
type = string
default = "host-0"
variable "host_pxe_mac" {
description = "PXE MAC address of the host machine"
type = string
variable "host_power_address" {
description = "BMC IP address of the host machine"
type = string
variable "host_power_user" {
description = "BMC username for the host machine"
type = string
variable "host_power_pass" {
description = "BMC password for the host machine"
type = string
sensitive = true
variable "dpu_hostname" {
description = "Hostname for the DPU"
type = string
default = "dpu-0"
variable "dpu_pxe_mac" {
description = "PXE MAC address of the DPU"
type = string
variable "dpu_power_address" {
description = "BMC IP address of the DPU"
type = string
variable "dpu_power_user" {
description = "BMC username for the DPU"
type = string
variable "dpu_power_pass" {
description = "BMC password for the DPU"
type = string
sensitive = true
variable "distro_series" {
description = "Ubuntu release to deploy on both host and DPU (e.g. 'noble', 'jammy')"
type = string
default = "noble"
# == Host machine ==============================================================
resource "maas_machine" "host" {
hostname = var.host_hostname
architecture = "amd64/generic"
power_type = "redfish"
pxe_mac_address = var.host_pxe_mac
power_parameters = jsonencode({
power_address = var.host_power_address
power_user = var.host_power_user
power_pass = var.host_power_pass
resource "maas_instance" "host_deployment" {
allocate_params {
system_id = maas_machine.host.id
deploy_params {
distro_series = var.distro_series
# == DPU =======================================================================
# The DPU is commissioned only after the host is deployed.
resource "maas_machine" "dpu" {
hostname = var.dpu_hostname
architecture = "arm64/generic"
min_hwe_kernel = "hwe-22.04"
pxe_mac_address = var.dpu_pxe_mac
power_address = var.dpu_power_address
power_user = var.dpu_power_user
power_pass = var.dpu_power_pass
is_dpu = true
depends_on = [maas_instance.host_deployment]
resource "maas_instance" "dpu_deployment" {
allocate_params {
system_id = maas_machine.dpu.id
deploy_params {
# Power-cycle the host after DPU deployment to initialize the DPU properly.
# The MAAS CLI is installed temporarily via snap for this step only.
provisioner "local-exec" {
command = <<-EOT
snap install maas --channel=${var.maas_snap_channel}
maas login local-exec $MAAS_API_URL $MAAS_API_KEY
maas local-exec machine power-cycle ${maas_machine.host.id}
while [[ "$(maas local-exec machine query-power-state ${maas_machine.host.id} | jq -r '.state')" != "on" ]]; do
echo "Waiting for host machine to power on..."
sleep 5
done
maas logout local-exec
snap remove maas --purge
EOT
# == Outputs ===================================================================
output "host_system_id" {
value = maas_machine.host.id
description = "MAAS system ID of the host machine"
output "dpu_system_id" {
value = maas_machine.dpu.id
description = "MAAS system ID of the DPU"
The plan declares four resources:
| Resource | Purpose |
maas_machine.host |
Enlists and commissions the host machine |
maas_instance.host_deployment |
Deploys Ubuntu on the host |
maas_machine.dpu |
Enlists and commissions the DPU (after host deployment) |
maas_instance.dpu_deployment |
Deploys Ubuntu on the DPU, then power-cycles the host |
All machine-specific values are variables, so the plan works for any host-DPU pair without editing the file.
Gather the required information
Before running the plan, collect the following for both machines:
| Value | Where to find it |
| MAAS API URL | MAAS UI address, e.g. http://<host>:5240/MAAS |
| MAAS API key | MAAS UI > Your profile > Details > API key |
| PXE MAC address | Label on the NIC, or from the BMC’s network summary |
| BMC IP address | Your network inventory or BMC management interface |
| BMC username/password | Your hardware credentials |
Set the MAAS credentials as environment variables. The provider reads them automatically:
export MAAS_API_URL="http://<MAAS>:5240/MAAS"
export MAAS_API_KEY="<KEY>"
1. Initialize Terraform
Create a directory for your plan, save the main.tf content from above into it, then initialize:
mkdir dpu-host-pair && cd dpu-host-pair
# save main.tf here
terraform init
2. Set variables
Create a terraform.tfvars file with the non-sensitive values:
host_hostname = "host-0"
host_pxe_mac = "<HOST MAC>"
host_power_address = "<HOST BMC IP>"
host_power_user = "<HOST BMC user>"
dpu_hostname = "dpu-0"
dpu_pxe_mac = "<DPU MAC>"
dpu_power_address = "<DPU BMC IP>"
dpu_power_user = "<DPU BMC user>"
distro_series = "noble"
Export the sensitive credentials as environment variables so they never appear in shell history:
export TF_VAR_host_power_pass="<HOST BMC password>"
export TF_VAR_dpu_power_pass="<DPU BMC password>"
3. Preview the changes
Run plan to see what Terraform will create before committing. Terraform reads terraform.tfvars and the TF_VAR_ environment variables automatically:
terraform plan
Review the output. Terraform will list four resources to be created.
4. Apply
When satisfied, apply the plan:
terraform apply
Terraform will prompt for confirmation; type yes and press Enter.
What happens during apply
Terraform works through the four resources in dependency order:
- Host commissioning: MAAS enrolls the host and runs commissioning scripts. This typically takes a few minutes.
- Host deployment: MAAS installs Ubuntu on the host. Once complete, the host is running and the DPU is reachable.
- DPU commissioning: MAAS enrolls the DPU and runs commissioning scripts.
- DPU deployment: MAAS installs Ubuntu on the DPU. After deployment, a local-exec step power-cycles the host to complete DPU initialization.
You can follow progress in the terminal output:
maas_machine.host: Creating...
maas_machine.host: Still creating... [10m00s elapsed]
maas_machine.host: Creation complete after 12m30s [id=abc123]
maas_instance.host_deployment: Creating...
maas_instance.dpu_deployment: Creation complete after 8m10s [id=xyz789]
Apply complete! Resources: 4 added, 0 changed, 0 destroyed.
Total provisioning time is typically 25–40 minutes, depending on your hardware and network speed.
Verify the deployment
Once terraform apply completes:
- Open the MAAS UI and go to Hardware > Machines.
- Confirm that both
host-0(or your custom hostname) anddpu-0appear with status Deployed. - To inspect commissioning and deployment logs for either machine, click on its name and open the Logs tab.
Optional variables
The plan exposes additional variables with sensible defaults:
| Variable | Default | Description |
host_hostname |
host-0 |
Hostname assigned to the host machine in MAAS |
dpu_hostname |
dpu-0 |
Hostname assigned to the DPU in MAAS |
distro_series |
noble |
Ubuntu release deployed on both machines |
maas_snap_channel |
3.7/stable |
Snap channel used by the power-cycle post-provisioner |
Override any of these in terraform.tfvars, for example:
host_hostname = "blade-01"
dpu_hostname = "dpu-blade-01"
distro_series = "jammy"
